Question about Blodgett Oven 1048 DOUBLE NG Double Pizza Oven Deck Type Gas Ultra Rokite Decks 48 in W NG
Why blodgett double oven gas 1048 is not too hot?
The top oven flame is too low .we have to put the thermostat to highest just barley to cook
2 Suggested Answers
  • 195 Answers
SOURCE: how hard is it to replace the center deflector
Hi Due to the heat in th eoven all the screws will be very hard to get out some may even have to be cut off to get it out then drill holes to replace the broken screws
Posted on Dec 08, 2011
961 blodgett pizza oven leaks gas to burner after shut off
After what shut off? Main on/off valve? Thermostat? If thermostat off and still have flame, thermostat is defective.
Nov 02, 2016 | Blodgett Ovens
Brand new Blodgett Oven - Cookies over-cooked outside, raw inside.
bad thermostat,just because its new doesnt mean it cant have bad parts
May 15, 2015 | Blodgett DFG100 DOUBLE Convection Oven
Blodgett DFG-XCEL spark but no flame
You need at least 24 volts for the gas valve to open
Jan 21, 2014 | Blodgett DFG-100 Gas Single Oven
Diplomat adp 0511 grill has no gas or ignition
Gas ovens / stovetop that use gas and not electricity. These work by igniting gas and use actual flame on the the stovetop.
Newest cook top styles, such as the induction or halogen cook tops combine the same style to produce more even heating. Some of these ovens feature thermal limiters or thermostats that regulate the burner system.
I offer free advice bcuz God is so good!
GAS OVENS
The spark igniter tip is dirty (can clean it with either a little wire brush or a piece of fine sandpaper).
2) The Pilot flame is too low, and the tip of the igniter is not in the flame good enough. (the flame acts as a circuit when it touches the tip & completes the circuit).
3) The spark module is no good and needs to be replaced.(But 1 & 2 are your best bet).
spark module does not sense the flame when it's on. The spark igniter is also the flame sensor which provides feedback to the spark module.
Make sure the igniter is properly aligned with the burner lighting holes and it is clean. All lighting holes must be clean too. You can enlarge them using a drill bit one size bigger.
If it would not fix the problem, replace the bake burner and the igniter.
There is a small chance for the spark module itself to be bad as well.
The oven safety valve
(also called the gas valve) is the part that ensures that gas is not released until the igniter has reached the correct temperature needed to ignite the gas. While this part can fail, it is uncommon. If the hot surface igniter does not glow you should first verify that you have voltage to the circuit. This is a live voltage check and should be performed by a qualified person. If voltage is lost at the valve terminals then you should verify the continuity of the bi-metal in the valve using a multi-meter.
Jan 18, 2013 | Belling XOU592 / XOU593 Electric Double...
Pizza scorching on bottom
This may sound simple but....Do you know for sure the oven temp is 550 (use a thermometer on the stone to be sure) The thermostat may be set at 550 but could be running hotter? I have had this problem in the past with ovens.
Mar 29, 2012 | Blodgett 911-DOUBLE Gas Oven
Blodgett Oven won't light
Go here,find what you seek. Great Co.
BLODGETT
44 Lakeside Avenue, Burlington, VT USA 05401
Toll Free: (800) 331-5842 Phone: (802) 860-3700 Fax: (802) 864-0183
Dec 12, 2008 | Blodgett 911-DOUBLE Gas Oven
Large yellow flame, not cooking food thoroughly
I think ill give it a try for you. The gas lines come in thru you cutoff valve then thru you gas valve and on to the burner. right before the burner you will see a bell shape fitting. The gas line is in the center of the fitting and there will be some opening around this fitting That fitting has dust clogging it up. This is where the gas mixes with the air Turn your oven off and blow this fitting out.
Oct 25, 2008 | Blodgett 911-DOUBLE Gas Oven
Pressure of flames in Cannon gas oven
HI thanks for your question. the part that's at fault, is the igniter. it glows but not hot enough to ignite all the gas. replace the igniter. thanks the appliance doc. please rate my answer. thanks.
Oct 09, 2008 | Ovens
Won't light up
had the same problem, safety gas valve is sticking get a small hammer and tap saftey valve. Just bought a new saftey valve about 3 weeks ago pilot light lite but now flame. I have a blodgett oven made in the 60s. Blodgett is getting away from there swithes that they have been replacing them with a replaceable thermocouple.made by robert shaw. My supplier said that they are not on the market yet. oops! good luck from oswego ny pizza villa.
May 01, 2008 | Blodgett 911-DOUBLE Gas Oven
Blodgett Oven 1048 DOUBLE NG Double Pizza Oven Deck Type Gas Ultra Rokite Decks 48 in W NG Logo
Top Blodgett Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Irene Tulloch
Are you a Blodgett Kitchen Appliances - Other Expert? Answer questions, earn points and help others
