Question about MSI A6000-226US Core 2 Duo T6600 2.2GHz 4GB 320GB BD-ROM/DVD±RW 16" Windows 7 Home Premium w/Webcam ... (9S7168324226) PC Notebook
I have a msi a6000 laptop and it keeps shutting off itself and wont boot windows when windows stars booting it shuts off and i clean the fan so thats not it can someone tell me what it's hapening
  • redneck Dec 06, 2012
    my msi a6000 has windows 7 and i try instaling windows 7 but shuts off with windows xp dont shut of but won't let me get to the option where i have to prest r so is hard pleas help
    Problem Solver:
  • 5 Answers
Try replacing the thermal grease on your cpu.
the BIOS have a protection that restart or shut down the computer/laptop when the cpu get to hot.
You can also check if the power suply is working in parameters
Posted on Dec 06, 2012
  • 23 Answers
SOURCE: my msi gx600 laptop experience black screen
Well the first step is to try and boot from your recovery disc. If you still have no monitor output then plug in an external monitor. This should invoke your os into using a generic display driver for the os. If you get some visual output then its just your driver for your laptop display thats corrupt and needs re-installing. If not then the chances are you fried your graphics chipset.
I dont think that an Msi GX600 will have a replacable MMX2 or 3 card so the chipset is more likely hard fixed to the motherboard. Basically you need a new laptop.
Posted on Mar 16, 2010
dugiehowsa
  • 114 Answers
SOURCE: MSI laptop technical problem
Sounds like the laptop used up all the battery power and turned itself off. Its doing this possible because your AC Adapter is not functioning correctly. Most AC Adapters have an indicator light to show wether they are working or not. Does your have this and is it on? If the device is still under warranty, contact the manufacturer for a replacement. http://www.msicomputer.com/support/sup_NBService.asp If the device is no longer under warrany, then I would recommend getting a new AC adapter. Make sure you get the same model AC adapter that originally came with the laptop. This will ensure that you have the correct voltage and amperage.
Posted on Sep 25, 2006
fraywing
  • 37 Answers
SOURCE: When I turn on my MSI M510C notebook - I get this message "reboot and select proper boot device or insert boot media in selected boot device and press a key" and cannot do anything else. Can someone t
I've read this problem due to new hardware interferences with desktop computers, all they had to do is change a few pins around on the harddrives.. since this is a laptop, and is quite difficult and dodgy to access the hardware, the only other suggestion is to reinstall windows with a recovery disk, or windows CD-ROM.
Hope this helps :)
Posted on May 27, 2009
  • 57 Answers
SOURCE: When I turn on my MSI M510C notebook - ''reboot and select proper
Your notebook does not see the proper boot files on your C drive. Many times the boot.ini has been corrupted.
You will need a Windows XP Install CD mounted in the CD Rom. When you boot the system you need to choose the CD as the boot device (if the notebbok does not do it by default) then typr R to enter the recovery console. Once you get the C: prompt you will need to create a new boot.ini file using the bootcfg command. See the following website for details in using the Recovery Console:
http://commandwindows.com/recovery.htm
Posted on Jun 15, 2009
Testimonial: "Brilliant. Thanks so much. It worked a treat. Much appreciated"
freedhast
  • 3 Answers
SOURCE: built in webcam not working MSI wind notebook u100 series
please chek ur webcam status..that on or off. if off press fn + f6.
Posted on Aug 25, 2009
My msi A6000 wont fully boot up it loads up to the windows icon pops up then it sits at a black screen with just the crusor help
you have a sevaral trouble with the video driver please go to boot at errors system then turn off the video driver and reestart this can hel you ! try it
Feb 05, 2014 | Computers & Internet
My msi u230 keeps shutting off
Overheating When the CPU overheats then it will shut down (i.e. thermal overload) and won't boot up again until it has cooled down. If this is the problem is not fixed then the CPU will eventually fail.
A faulty fan causes the problem or the fan and heat sink assembly are clogged with dust.
Check the CPU fan to see if it spins freely, if not replace the fan.
If the fan and heat sink is clogged with dust the remove the dust and make sure the vents are clear and dust free. Use a small brush and can of compressed air to do this.
Feb 05, 2013 | MSI U230 Light087 Netbook
MSI computer randomly shutting down
Jan 20, 2013 | Computers & Internet
My acer aspire 3000 star up only half way and torn off in seconds ?
turn on your laptops, press F2, and wait for a while. if your laptop doesn't shut down, it means you just have a software problem, try to check the boot order. make sure you put your hard drive as your first boot order and save. if it still shut down even after inside the bios setup, it means your laptops have a hardware malfunction. probably overheat, exhaust covered by dust, the cooling fan is not working, or other hardware malfunction.
Jun 13, 2012 | Acer Computers & Internet
My laptop will startup but as soon as it reaches the loading for windows it shuts itself off.
The problem you have can be fan problem.
If the laptop is still under warranty you should take it to assistance.
Mar 01, 2011 | Computers & Internet
UNMOUNTABLE______BOOT_____VOLUME ***Stop: 0 X
It could be a problem with the harddrive and memories ,if you enter the DELL bios setup page when the computer starts up does it have an option to test the hard drive if so test it.
Also if you have two memory sticks then try with only one and vice versa.
Try booting with another boot CD like the ultimate boot CD it has some hard drive testing tools too.
Good Luck
Nov 04, 2009 | Compaq Presario 2195US Notebook
Laptop keeps shutting off by itself
When you encounter about this issue this is overheating problem maybe the CPU fan is not spinning and faulty already, you need to check the CPU fan and replace a new one.
Computers may not be smarter than people, but if they’re designed properly, they will shut themselves down before overheating to the extent that they do themselves damage. If the smart person keeps turning the notebook back on and figures out a way to foil the protection, the laptop is probably doomed.
Once a laptop shuts down for thermal event protection, it may refuse to power back up for a fixed period of time, five or ten minutes, or it may begin to boot and shut down immediately as soon as it boots to the point that it can figure out that its too hot.
The over-temperature protection is generally a BIOS rather than an operating system function, so one sign of an overheated laptop is one that shuts itself down while you’re using it and then refuses to boot as far as the operating system unless you leave it alone for an hour or so to cool down.
Unless you’ve been working in a very unfriendly environment, high temperatures, direct sunlight, etc, you should take even a single overheating shutdown as a warning to back up your data at the first opportunity and to give the cooling system a serious cleaning.
Oct 08, 2009 | Gateway (60.44K08.001) Laptop Heatsink
When i on the system, the fan is not rolling, sometime when on and boot upto the the window evironment, its shut itself down. what could be the possible problem with them
Please Check CPU making any noise or not.
remove the CPU side door and check Fan is rotating on Processor if not it may not rotate due to heavy dust inside. ( clean it and refix it)
Check SMPS Fan is rotating or not..
If fans or not rotating Heat Builds up then computer shuts down itself.
If both fans are working...Just Open BIOS window by press DEL button continuosly while startup and wait for 2 to 3 minutes If the computer shuts down Itself in BIOS Window also then we can confirm issue with Hardware.
If Computer not shutting down in BIOS Window then issue with Operating System Boot files corrupted.
While Turn ON the system press F8 to enter in Safe Mode.
Open command prompt by clicking on
Start >. RUN >> type cmd >> then press enter.
now type chkdsk /f
now press Y
then reboot PC it fixes the Boot files error then your PC works perfectly.
If you still exp same issue let meknow..
Feb 18, 2009 | HP Pavilion dv6000z Notebook
Laptop boots then shuts automatically off
If you haven't tried it yet, pull the battery out and try booting from the adaptor only. If it boots normally, then your battery pack may be bad (shorted cell) or the regulator that has the job of charging and monitoring the battery pack while keeping your system running may not be healthy.
If you own any multimeter (at the cost of Chinese DMMs, everyone should own one), check the battery pack for charge. Under normal conditions, they should measure a couple of percent higher than their rating. You will have either Lithium Ion or Nickle metal hydride batteries in the pack so should measure some multiple of the nominal cell voltage of one of those types that are respectively 3.6 & 1.2 volts.
Nov 28, 2008 | HP Pavilion dv9000z Notebook
Shuts off at boot up screen?
Start the computer in safe mode (tap F8 immediately after turning it on until you see the option of how to boot)
If it successfully boots into windows, you have an issue with either driver conflicts and/or viruses. If it still restarts itself, you most likely have a hardware issue (bad hard drive, motherboard, etc)
Jun 24, 2008 | Acer Aspire 5000 Notebook
MSI A6000-226US Core 2 Duo T6600 2.2GHz 4GB 320GB BD-ROM/DVD±RW 16" Windows 7 Home Premium w/Webcam ... (9S7168324226) PC Notebook Logo
604 people viewed this question
Top MSI Computers & Internet Experts
vsri9
David
David
Matthew Spark
Matthew Spark
Are you a MSI Computer and Internet Expert? Answer questions, earn points and help others
