What is Toner/Cartridge No. for Sharp Copier Printer No. AR-5618N
Please give me Toner/Cartridge No. for Sharp Copier Printer No. AR-5618N
    Habit-Forming:
  • 41 Answers
MX 235 AT
MX 235 GT
Posted on Dec 07, 2012
    Sergeant:
  • 241 Answers
The code for this one is MX235GT. Hope this helps.
Posted on Dec 06, 2012
  • 148 Answers
SOURCE: F2-02 error on Sharp AR-M237
on this code you may have to clean out the developing unit and start with fresh developer. Make sure the developer unit is not leaking from one of the bearings. You may need a tech for this one...
Posted on May 26, 2008
  • 92 Answers
SOURCE: crum data read trouble in sharp ar 207
The CRUM chip is what tells the copier that the correct toner is installed. It is specific to the toner cartridge. If it is a new cartridge then it should have a new CRUM chip and there should be no problem. If it is a recharge it's possible that the chip was not changed or the wrong one was used.
Posted on Oct 16, 2008
SOURCE: add toner still blinking of sharp AR-5316
the best you can do is to replace the toner cartridge itself. It won't work if you just refill it.
Posted on Nov 10, 2008
007tech
  • 95 Answers
SOURCE: sharp copier ar-bc320 error code??
the DK message means it is time to replace the black drum unit. the drum unit is called an ARC26DU. open the front cover. remove the toner cartridge/s by lifting the green lever and pulling the toner out. Open the left side door. look at where you just pulled out the toner and there is one screw (facing you) holding each drum in place - loosen the screw and pull the drum unit out towards you....slide in the new drum unit.
to reset drum counter go into SIM mode by pressing the following keys one after the other "P" "*" "C" "*" then 24 and start/copy key then 7 then select the color drum you are replacing and confirm reset. make sure copier restarts afterwards
DO NOT refill these toner cartridges (even if you can find someone to do it) The toner cartridges for these machines have generally had ongoing problems as far as longevity and quality - refilling them will only make it worse.
Posted on Apr 23, 2009
  • 5 Answers
SOURCE: U2 fault on Sharp AR-206
Error code U2 in Sharp copier AR 206 shows error or failure of toner crimp you can try to solve by replacing toner crimp
Or by reseting the error code by fallowing procedure
press c intrrupt 0 ( zero ) intrrupt contoneously after pressing all the light on control will go off then press 16 then press start switch
your prob will 100% solve.
if any more prob pl inform
Posted on May 27, 2009
How to fix replace toner cartridge problem when there is enough toner in the cartridge.
Remove from the printer, give it a good shake over the sink, (you may find toner leaking and it is hard to cleanup...then replace it. That may do the trick but if it does not you may be best off replacing the cartridge. Sometimes old electronics misreport the condition of components ....it could be that the machine is getting old and going wrong. But you will only discover whether this is the case after investigating further)
Oct 26, 2015 | Sharp Cartridge Copier Toner/Developer...
How can i fix f2-70 in sharp ar-5618n
replace the toner and drum cartridge with OEM do not use third party
Feb 11, 2015 | Sharp Office Equipment & Supplies
ERROR CODE F2-00
Please you should replace your toner cartridge.If you have new toner cartridge than the chip destination error.Thanks best luck
Apr 18, 2013 | Sharp - AR-M550N copier - ARM550N
Hi i refil the toner for my sharp ar-m207 and later the copier say add toner can not print or copy help my please
You have to replace the whole toner cartridge because there is a crum chip on the back of the toner cartridge. When the cartridge reaches empty and the copier says change toner the copier burns that chip so it can not be reused again.
Aug 24, 2011 | Sharp AR-M207 All-In-One Laser Printer
I am using Sharp AR-M201 photo copier machine. I just came across a error message ` System Error F2-02 Refer to user guide' Can anyone guide me to solve this problem? Thanks K K Mendon
F2 -02 Toner supply failure
cause :-
- developer unit trouble
- Toner supply abnormality caused by
installation of unpacked toner cartridge
Dec 26, 2010 | Sharp AR-M205 Copier
My copier sharp AR-161 is not working it's write
please change toner cartridge chip your toner cartridg is fail due to toner empty
May 12, 2010 | Sharp AR-160 Copier
What does it mean 2 and f flashing on my copier
An F2 code means you've either got the incorrect toner cartridge inserted into the machine or toner cartridge is faulty (there's a chip on the toner cartridge that identifies it to the copier). Please make sure what you've loaded is AR-016TD.
Sep 02, 2009 | Sharp Office Equipment & Supplies
Sharp AR-163 Copier
replaced your toner cartridge with a new one, if you install a new one and it didn't work and still F2 flashes, the cartridge that you buy is not suitable for your country, always ask for a genuine toner, do not use compatible toners for your copier.
May 01, 2008 | Sharp AR-163 All-In-One Laser Printer
Solution for copier
Your copier does not like your toner cartridge. Make absolutely sure you have the proper cartridge AR-202MT. Or, the countdown chip in your cartridge has reached zero or is malfunctioning. In any case, try a new toner cartridge.
Apr 05, 2008 | Sharp AR-M205 Copier
82 people viewed this question
k24674
