Question about Lexmark JetPrinter X1185 All-In-One InkJet
My x1180, how do i change the ink cartridge
It's not clear how to open up this printer to change the cartridge and i don't want to break anything.
  • Anonymous Feb 25, 2009
    dont know how to open it up
    President:
  • 1,901 Answers
Here is a copy of the setup guide that should give you some good help:
X1100 Setup Guide
The cartridges are in cartridge carriers under the scanner unit cover.
Posted on Jan 12, 2009
The printer wont let me do anything because it says I have an alignment problem and to take the tape off of ink cartridge but there is no tape! Its not a new cartridge I don't know what its talking...
May be dry the ink or refill ink cartridge so , it could't properly ink out the nozzle. If possible u can batter manually clean the print head. Then try to it. Otherwise need to change the ink cartridge.
Jun 13, 2013 | Office Equipment & Supplies
What is the cartridge number for all in one1108 serieshe
If you mean the Lexmark X1180 printer, it takes in the #16, #17, #26 and #27 Lexmark ink cartridges.
Dec 14, 2012 | Lexmark Office Equipment & Supplies
Advent resetting ink levels
Hi There
Your all-in-one printer is designed to stop printing before quality is compromised. Make sure you always use KODAK Ink Cartridges. Kodak is not responsible for the compatibility or performance of non-Kodak brand ink cartridges or refilled ink cartridges. To purchase KODAK Ink Cartridges, go to the KODAK Store.
To resolve the error, replace the black ink cartridge with a new cartridge:
  1. Turn on your printer.
  2. Open the access door. For printers with LCDs, follow the instructions on the LCD screen.
    NOTE: For ESP 3250 and ESP 5250 all-in-one printers, if the ink cartridges don't move to the center when you follow the instructions on the LCD screen, see Printhead and ink cartridges do not move to center with access door open.
  3. When the printhead stops moving, pinch the latch on the black ink cartridge and lift it out of the printhead.
  4. Remove the new black ink cartridge from its bag.
  5. Remove the protective cap from the black ink cartridge.
    CAUTION: Insert the ink cartridge immediately to prevent the printhead from drying out.
  6. Insert the black ink cartridge into the printhead.
  7. Press down on the tab until you hear a click.
  8. Close the access door. For printers with LCDs, follow the instructions on the LCD screen.
    NOTE: For more information on installing ink cartridges, see the Extended User Guide for your printer. Review Maintaining Your Printer - Replacing ink cartridges.
If the error continues, upgrade the firmware for your printer:
  1. Press the Cancel button on your printer to clear the error message. (If the error does not clear, contact us.)
  2. Upgrade the firmware for your printer:
    1. Locate and select the firmware download for your printer.
    2. Follow the instructions to install the firmware.
  3. If the error continues, contact us.
Support Link :
Mar 29, 2012 | Office Equipment & Supplies
How to change printer cartridge Dell 810
Open the printer cover with it turned on and connected to your pc. When you open the cover, the printer should bring the ink cartridge carrier to the front and center so you can access cartridges easily. Press or pull the plastic tab next to the ink cartridge that you wish to replace and it will pop it up towards you and out of the carriage. if there is no plastic tab to eject the cartridge, grab a hold of it with your finger and pull upward and out towards you. Don't worry about breaking anything or harming the cartridge. Once you remove the old one, remove the plastic tape tab on the new cartridge before inserting. Then close the printer cover and it should walk you through aligning the print heads on the display. Good luck!
Oct 09, 2011 | Dell 810 All-In-One InkJet Printer
The instructions tell me to lift the lid, but I don't know how, it seems to be locked, is there something underneath I need to push or pull. I need to change the ink cartidges
On this particular printer there is no locking mechanism to access the ink cartridges. In order to open the cover, use a single open hand and place your fingers just underneath the screen on the front, and pull upward. The entire scanner piece should raise and a plastic bar on the right-hand side will lower down to prop it open.
If you're having a lot of trouble opening it, you may want to check around the sides of the printer to see if there is any tape leftover from when the printer was packed in its original box. When they ship a printer it is always covered in tape to make sure that nothing falls open or breaks before it's delivered, and there may be a piece of clear (almost invisible!) tape left over preventing the printer from opening.
Once it's open, the ink cartridges should come to the middle. Press down on the small lever on the print head (the ink cartridge holder) to pop the cover open so that you can install the cartridge.
Hope this is helpful!
May 09, 2011 | Lexmark P6350 All-In-One InkJet Printer
My c543dn insists that the cyan cartrige is missing but its not- any help here ?
These would be my recommendations, based on problems I've had with a similar printer:
1) Open the printer and pull the cyan cartridge back out.
2) Check the bottom of the cartridge to make sure there aren't any scraps of plastic or other material that might be preventing the printer from recognizing it.
3) Check inside the ink well (where the cartridge goes) to make sure nothing's stuck down in there that might be preventing the connection. Be careful and use a flashlight so that you don't accidentally break anything else (I've done that before).
4) If all of that is clear, re-insert the ink cartridge and push down (not too hard, but firmly) until it clicks into place.
5) If none of that works, the leads on the cartridge might have been damaged, or it might just be defective. You'll probably need a replacement toner cartridge at that point.
Hope that helps!
May 07, 2011 | Lexmark C543DN Laser Printer
How do I get the black cartridge printer out of my mx310 to replace it? Seems stuck and I don't want to break anything!
First you want to open the cover ,the ink cartridge holder will move into a position then stop it is now in the position to remove your ink cartridges !Now you want to press down on the semi-circular tab to release the carthridge and then remove it.It might seem stuck in there give it a little pull don't worry you wont break anything remember when there were installed they had to snap in....
Sep 10, 2009 | Canon PIXMA MX310 All-In-One Printer
Printer shows Carriage Jam, but I can't find it.
many reason coses carriage jam bout i think that the in coder belt faulty
Mar 23, 2008 | HP Photosmart C4150 All-In-One InkJet...
Ink replacement fault
Did you use Lexmark brand cartridges? Sounds like the printer can't read the chip in the cartridge. Try cleaning the contact pads behind the cartridges and in the carriage with the eraser on a pencil.
Jan 23, 2008 | Computers & Internet
Lexmark x1180 printer all in one
Clean the contacts on the cartidge and printer ( open the replace ink door wait for the printhead to come to center and turn off power) if that does not work then replace cartridge, it might be a recycled one that they did not chane the chip.
Oct 11, 2007 | Lexmark JetPrinter X1185 All-In-One InkJet
Lexmark JetPrinter X1185 All-In-One InkJet Logo
46 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
