Disc isn't spinning!! Always coming up as no disc!!
    New Friend:
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
  • 38 Answers
It's broken.Maybe the spinning engine maybe something else in the electronic system. You can take it to some electronic service, but they maybe will say it's cheaper to buy one new instead to fix it.
Posted on Dec 06, 2012
4 Suggested Answers
  • 146 Answers
SOURCE: it's never been dropped, it won't spin the DVD, its says no disc
The motor is shot. Since the player is 29 dollars at WalMart you would do better to get a new player than to fix it.
Cheers
Posted on Jan 04, 2009
petraman7
  • 1175 Answers
SOURCE: Panasonic dd-s25 won't play dvd.
HI...
Have you tried reg.CDs to see if those have trouble too?
I would say that the lens assembly has got debris or a filmy substance over the lens.
If you're not the least bit technical , dont open the unit.
It will require that the cover gets removed and the top DVD spinner plate gets removed so that the Lens can be cleaned.
The chrome rails that the DVD reader runs on would need cleaing too.
Posted on Mar 04, 2009
sree-here
  • 61 Answers
SOURCE: Memorex dvd player 2040..disc won't stop spinning!
This is due to faulty DVD lens/head. Try cleaning it with DVD/CD hed cleaning CDs.If still the problem persists, contact near by service center for replacing the faulty Lens.
Posted on Mar 13, 2009
Philips DVD recorder, (250gb) DVDR3460H. can not remove disk .........
your gonna have to open the machine up the there is a whits tab that lifts the disc up to spin you will have to use your fingers to slde it of that make sure its unplugged and then the white thing will realese
Sep 19, 2008 | Televison & Video
I just bought a hand grinder from a guy but don't know how to take the disc off . it has a button u push but no nut on the disc
If there isn't an arbor nut holding the blade/disc on the grinder you have a disc with the threaded center built into it. While holding the arbor lock button down you have to turn the disc by hand until it breaks free and spins off. It may be on vary tight as it is a self-tightening thread so the disc won't come off while you use it.
Feb 22, 2012 | Black & Decker Black And Decker 4-1/2"...
Tried three CDs, but display shows disc error
First, try a "hard" reset of the player by physically pulling the power plug from the outlet, waiting at least 30 seconds before plugging it back in.
After it comes back on, try a non-burned disc you know to be scratch free. If this disc will not work, you have a hardware malfunction. Due to the relatively low prices of consumer electronics, it probably isn't worth fixing, unless it is a high-end brand.
May 05, 2011 | Audio Players & Recorders
No Disc-alert. Will not play any DVD's. Will not run lens cleaner disc. disc's spin. thank you
Discs spinning after being loaded, that's a positive sign, but 'No READ' or 'No Disc' usually means the laser has failed or its output is too weak to read DVDs (DVD players tend to spin discs at a faster speed with a higher read rate than CD decks (obviously to read the video data as well as audio per disc, the optical/laser voltage rating is higher for DVD). So they are more likely to fail quicker than CD lasers but not always.
In short, since the unit is only a player, and may not be brand new or under any warranty, consider replacing it with a new unit or perhaps a DVD recorder (or even a Blu-Ray player - as they are becoming cheaper to buy now) - the cost of repairs/parts for this one would be higher than a new one and not economical, although you can always submit it to a service centre and get a quote (and a second opinion) on the likely cost(s) of parts/repairs involved. It won't be cheap, trust me.
Mar 21, 2011 | RCA DRC277 DVD Player
Get error no disk. the disk in not turning inside the player
If your disc/dvd/cd isn;t turning in the machine it is most likely that you need to replace the laser assembly, which is the entire assembly with the drawer, the laser and the spndle motor, which is the small motor that spins the disc. Good Luck.
Nov 26, 2009 | RCA DRC290
Mar 13, 2009 | Televison & Video
It's never been dropped, it won't spin the DVD, its says no disc
Cheers
Jan 04, 2009 | Durabrand DVD-1002 DVD Player
My gamecube problems.
If the disc does not spin or spins strangely, it is almost always because the gamecube is having problems reading the disc, and not a problem with the motor. The laser can be adjusted to a higher power, but you will need several special tools to do so. You should be able to find a guide by googling for gamecube laser adjust. If that doesn't solve the problem, you either need to replace the laser or the laser control board.
Mar 19, 2008 | Nintendo GameCube Console
Televison & Video Logo
44 people viewed this question
Top Televison & Video Experts
