Question about Sony Cyber-shot DSC-H50 Digital Camera
My Sony Cybershot DSC-H50 shows error code C:13:01 when the either of the current memory sticks I am using, is inserted. However, when I take out the memory stick out, and put on the camera, it shows the "internal memory full".But it does not gives any option to format it. The only one button on the panel is working and so the option of formating could not be done. I even tried to connect it to P.C. It shows four pictures. But again there is no option to either delete or cut the pictures. Pl. do the help. Dipak
  • 5 Answers
SOURCE: Format Error in Sony Cybershot
i think this problem arises when you fail to regularly format the card ie. take lots of pictures and delete some and repeat the process over and over instead of downloading every session and formatting the card causing coruption. Also if you've bought pro duo memory stick off ebay poss. its a very good forgery (again i've been caught out by this).
Posted on Jan 16, 2008
SOURCE: Sony Cybershot DSC S650 Memory stick not formatting
Well I have the same camera.
And mine won't turn on.
Suggestion dont trust this camera.
Or maybe it just can't hold that much memory.
Posted on Mar 21, 2008
mcomijohns
  • 477 Answers
SOURCE: dsc-s700 format error
If you have a computer with a memory card reader that takes the stick. insert it into the computer and goto my computer find the memory stick drive letter and format it their then retry the stick in the camera. also try to go into the cameras menu and try formatting it their if you cannot format the stick it is very possible it is bad.
Posted on Mar 25, 2008
there is no tools feature on the sony...select the 1st button lower right...all touch screen features appear...select menu in lower
left...select setup...camera 1 will display...select down arrow
twice until you reach format, the select...that should reformat
the memory...
Posted on Apr 07, 2008
dlundmark
  • 797 Answers
SOURCE: Sony CyberShot DSC W50 internal memory error
Before anything else try to reset all from the menu for the internal settings. This may get the camera back to where you will see the format option.
Make sure you format and delete all that is in the internal memory. This may be due to a full or corrupted memory space internally.
Because the camera can work with the memory stick, it seems that there is some problem with the memory internal space.
Try the format as mentioned above. Some cameras will only allow you to delete all in the internal memory.
Go to the menu and look for format the memory, and remove the card so that the internal memory will be defaulted.
Posted on Aug 04, 2008
How do I clear the memory stick on my Sony Cyber shot
The best and easiest way to clear a memory stick is to format it in your camera using the appropriate command. Different CyberShot models have different procedures for doing this, so please consult your manual.
May 15, 2012 | Sony Cyber-shot DSC-H50 Digital Camera
Getting an error code c:13:01 on my sony t900 camera
“Memory Stick Duo” is unformatted.
“Memory Stick Duo” is broken.
“Memory Stick Duo” type error
The camera cannot read or write data
on the “Memory Stick Duo”.
Format the “Memory Stick Duo”.
Replace a new “Memory Stick Duo”.
Insert a supported “Memory Stick Duo”.
All above are solution for your quiry
Jan 21, 2010 | Sony Cyber-shot DSC-T900 Digital Camera
Memory stic in camera format problem
dear,i've sony cybershot DSC_W35.I was getting format error c13.01 when i insert sony memory stick.but I've no problem when i was using internal memory.how can you rectify this problem
Nov 07, 2008 | Sony Cyber-shot DSC-W35 Digital Camera
Dsc-s700 format error
Mar 21, 2008 | Sony Cyber-shot DSC-S700 Digital Camera
Mar 15, 2008 | Sony Cybershot S650 Digital Camera
it could be a faulty memory card, but a more likely cause is that this stick isn't formatted yet. you can format it usually by bringing up the camera menu, then going to tools and format. you can also format it by using windows and a cardreader or your camera.
Mar 04, 2008 | Sony Cyber-shot DSC-S700 Digital Camera
ho un problema con la mia cybershot dsc-t5 come posso risolvere l'errore di formattazione C:13:1 su una memory stick duo prodotta da neo
Jan 02, 2008 | Cameras
Sony Cyber-shot DSC-H50 Digital Camera Logo
99 people viewed this question
Top Sony Cameras Experts
james laughton
james laughton
Are you a Sony Camera Expert? Answer questions, earn points and help others
