Question about Sony SA-WM40 Subwoofer
Replace sony subwoofer fuses
Where is the fuse located in a sony sa-wm40 subwoofer
SOURCE: No Power Sony Sub Model SA-WM500
I fixwd it by NOT subscurbsing to your Show
Posted on Jul 09, 2009
SOURCE: Power, but no sound
take an ohm meter and remove wires from speaker...put meter in the ohms position...you will put a lead on each of the terminals of the speaker...you should have a reading of 2, 4, 8 ohms....you may also try to use the continuity test, same, but there will be a beep ....this basically ensures that the coil running through the speaker is still good, as one piece, otherwise it will get no good reading and this is usually from blowing the speaker or sudden high bass sounds....
Posted on Aug 09, 2009
  • 336 Answers
SOURCE: Unit blew the internal fuse. SONY SA-WMS367 SUB-WOOFER
Bad output IC or voltage rectifier are the most likely at fault.
Posted on Nov 29, 2009
SOURCE: my sony sa-wx700 has blown the 6.3 amp fuse on the
i can't open yahoo mail in box
Posted on Dec 27, 2009
  • 308 Answers
SOURCE: The speaker is starting to buzz during the low
It probably buzzes all the time, you just notice it when it is outputting little volume. Check the cables for loose connections or replace them with other cable as a test.
Posted on Mar 12, 2010
My Sony SA-WM40 subwoofer has power, but sound kicks out. I'll turn off power for about 5min and when turn power on, sound is back. Is something overheating?
Probably, or the woofer coil itself is experiencing a heat, volume or motion related short. Clean any dust or debris from the heat sink fins in the back. Make sure it has lots of space for cooling ventilation.
Mar 31, 2011 | Sony SA-WM40 Subwoofer
The fuse blows in the SA-WM500 whenever there is an input from the amplifier.
http://www.retrevo.com/support/Sony-SA-WM500-Subwoofers-manual/id/752ag404/t/2/
The fuse blowing is a symptom of something seriously shorted internally. What preceded the initial problem? Smoke is bad. Fire would be soon to follow without the fuse blowing. Take it to a tech.
Jan 17, 2011 | Sony SA-WM500 Subwoofer
My Subwoofer Sony SA_WM500 was always burn the fuse therefore I had to change the STK, but now it takes off sound very low, How can I have back the high sound level? Zaruque Quimuenhe
It's no clear what you mean by "I had to change the STK", but if that means you have somehow defeated the fusing or place a larger fuse than it requires then STOP and shut it off. You might be risking a fire or more serious damage to the amp.
I would recommend you find a hands-on tech to look at it.
If you have resolved the fuse problem and now just have low subwoofer volume, you might want to track it back to the source and ITS subwoofer volume setting. There IS a volume level control on the sub, too. Turn it up.
The manual is here:
Jan 11, 2011 | Sony SA-WM500 Subwoofer
My sa-ma40kicks off after it plays for a few minutes
This sounds like a power supply problem. If it works after is sits or cools, check at the power supply for bad or disturbed solder connections, a lot of time if you look at the circuit board where the component comes through you will see a small ring in the middle of the solder.
Dec 22, 2010 | Sony SA-WM40 Subwoofer
Sony SW no sound
does this sub have an LFE output? if so, connect that to the LFE input on the reciever and make sure it is set up properly in the set up menu in speaker configuration. if the sub has speaker line input outputs, connect speakers to input of sub and out of sub to amp/recvr
May 10, 2010 | Sony SA-WM40 Subwoofer
How to hook up my subwoofer
It sounds like you're doing everything right. Did you define the sub to the Onkyo (Subwoofer = Yes, page 22)?
Let's prove the sub works. Set its volume about half-way, cutoff= 170Hz. Temporarily connect an RCA cable from its Line Input to one of the Tape Out connectors on the Onkyo and play some FM through it. If it's alive you'll hear the low end of the music.
Don't buy into the hype that there are different pedigrees of RCA (or speaker) cables that will make an audible difference. Save your money.
May 04, 2010 | Onkyo TX-DS696 Receiver
The speaker will cut-out after it has been playing a while. It will click-off, like it is going into a power-save mode, then back on for a few seconds or minutes...then back off again.
Sounds like you have an heat sensitive semi-conductor that might be connected to a relay (the clicking thing). As it warms up it acts up!
You can pin it down by spraying suspected parts (while under power and when it acts up) with Servisol Freezer Spray. Only spray one part at a time. The faulty part will return to normal, till it warms up again, or you force it to by touching it with a soldering iron.
If nothing happens to the part you spray, it's working and test the next. Don't bother to spray non semiconductor parts.
Apr 12, 2010 | Sony SA-WM40 Subwoofer
Mar 08, 2010 | Sony SA-WM40 Subwoofer
Nov 28, 2009 | Sony SA-WX700 Subwoofer
Sony SA-WM40 Subwoofer Logo
51 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
