Question about Sony KDS-R50XBR1 50" HDTV
How to reset parental lock password for sony sxrd projection tv
  • 6 Answers
SOURCE: Model Sony SXRD Projection
have to replace the lamp... part xl-5100... it's on the left side of the TV (if you are working from the back of the TV). there is one small screw that secures the door to the television1.gif. once you remove that door,the lamp is righ there with the labels that say pull... rempove this part. you'll likely see the shattered bulb on the inside. replace this part and the TV should be as good as new. you will have to call around to find one in stock though. the cost of the lamp is right around $250.00
this works for 50 in as well
Posted on Dec 26, 2007
  • 16 Answers
SOURCE: replace bulb tv wont turn on
make sure the lamp and lamp door are seated properly. does it blink any codes. 3 blinks is lamp or lamp door not seated properly
Posted on Jun 26, 2009
  • 2335 Answers
SOURCE: RESET LAMP HOURS ON SONY KDS-R50XBR1 sxrd tv
Click here to download the user'e guide and go to page #113 to reset the TV to factory settings.
Posted on Feb 27, 2010
welcomejee
  • 10594 Answers
SOURCE: Sony grand wega sxrd 60'
3 times red light blink indicates that lamp cover is not fixed properly. This can happen if you took out lamp from tv or replaced it. Lamp cover is plastic cover that need to be removed from tv cabinet to access lto lamp.
Make sure lamp cover is back in its position securely and turn tv On.
Thanks.
Posted on Oct 15, 2010
dcramer531
  • 1654 Answers
SOURCE: Hi! GREAT site! We have a Sony SXRD KDS-R60XBR1
5 blinks if for the ballast that powers the light. You can try changing the bulb first, if that doesn't fix it then I believ it will be your ballast. If you haven't changed the bulb before It could probably use one anyway, and you could keep the old for a spare.
Here are some more from sony on this.
According to Sony:
Red LED Flashing four(4) times
o Fan not plugged in
o Foreign object hitting blades
o CN2301 on ASU board not seated or connected
o ASU shield touching S1 board
Red LED Flashing five(5) times
o Interconnect harness from Lamp driver 5-pin to ASU 9-pin board not connected
o Lamp driver failure
o Bent pin on Lamp driver 5-pin connector
o DSU to C board harness not locked
o CN6501 on G board not seated or connected
o Lamp failure
Posted on Jan 29, 2011
Perental control lock
The master password is 4357. This will erase previously entered password when used. You can go into the menu and reset the a new password or turn off parental controls. Hope this helps.
Mar 26, 2010 | Sony Grand WEGA KDF-42WE655 42" Rear...
Young son locked tv parental control
Under the main menu, go to the Parent tab and enter the Master Password: 4357. This will completely clear the present password. You can enter a new one afterward.
Mar 12, 2009 | Sony FD Trinitron WEGA KV-34HS420 34" TV
Parental code lock sony kp51w5500 reset /or clear it?
If you lost password of parental code then put 4357 and press Ok
This will clear old pass word and type new password.
Jan 30, 2009 | Sony KV-32FS13 TV
Parental control/lock on Mitsubishi WS-55613
I can help you unlock your Mitsubishi HDTV V-Chip parental lock.
Please follow these steps to bypass the vchip or reset the V Chip password.
I hope that helps.
_______________________________________________
Reset Mitsubishi HDTV VChip Password
Bypass Mitsubishi HDTV Front Panel Lock
Aug 11, 2008 | Mitsubishi WS-55613 55" Rear Projection...
Mitsubishi parental control reset for tv model vs-5061
I can help you unlock your Mitsubishi HDTV V-Chip.
I hope that helps.
Jul 20, 2008 | Mitsubishi VS-50611 50" Rear Projection...
Parental control password
Hold CH+ and vol+ on front tv panel for 8 seconds. Parental control menu appears on screen, reenter password
Feb 15, 2008 | RCA D61W20 61" Rear Projection Television
Parental controls
If you forget your password, press and hold TV on the remote and the
MENU button on the television simultaneously for 3 seconds. Parental
controls will then unlock and you can re-enter a password via Lock
Parental Controls
Aug 26, 2007 | RCA P52939 52" Rear Projection Television
Sony KDS-R50XBR1 50" HDTV Logo
54 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
