Question about Acer Aspire One PC Notebook
Hello, I have an aspire one 8615 and it seems to be that the cpu is "broken". Do you know what kind of cpu I have in my laptop and where I can get or order a new cpu? Thank you, Sabine
  • Roberta Smith
    Roberta Smith May 11, 2010
    what has happened to make you think the cpu is "broken"
Cooler fan
Lots of local places can provide a decent price and even install this for you, however based on the model number provided I was able to find this:
http://www.laptopcpufan.net/acer-aspire-5741g-series-laptop-cpu-fan-lf.html
As well as http://www.pchub.com
Jun 07, 2012 | Apevia Lithium Ion Battery Pack 4400 mAh...
Hi grade laptop fan not working
When the CPU overheats then it will shut down (i.e. thermaloverload) and won't boot up again until it has cooled down. If this is theproblem is not fixed then the CPU will eventually fail.
A faulty fan causes the problem or the fan and heat sink assembly are cloggedwith dust.
Check the CPU fan to see if it spins freely, if not replace the fan.
If the fan and heat sink is clogged with dust the remove the dust and make surethe vents are clear and dust free. Use a can of compressed air to do this.
Feb 11, 2012 | Computers & Internet
Hi, my acer aspire 5315 switches itself off when it gets hot? It has been doing this for a few months now! My cousin also has the same laptop and same problem!! I would be grateful if you could...
this can be possible if your laptop is AMD processor. kindly check the cpu fan if working, system will shutdown once cpu reach the temperature set from the bios. change the fan if not working.
Feb 23, 2011 | Acer Aspire 5315 Notebook
I've had my acer aspire (5315) laptop for over 2 years
Sometimes, the CPU heat sink fan might get clogged up or faulty or stop spinning entirely. Make sure that the fan can turn properly.
IF YOU CAN, open the unit when the battery is disconnected and the power is not connected, then reseat the CPU Heat sink and re-apply a eye drop heat sink thermal paste onto the CPU. Reconnect and tighten everything again properly and adhere to the sequence in turning the screws back as per their numbering on the heat-sink
If the FAN has trouble spinning, doesn't turn at all or is noisy and runs irregular please replace the fan. The fan alone should cost about a few US $.
May 16, 2010 | Acer Aspire 5315 Notebook
Rebuilding Acer Aspire 3660
Acer Aspire (NoteBook) 3660 Series
Please see below for the Memory ( RAM ) upgrade options available for the Acer Aspire (NoteBook) 3660 Series.
Memory Details for the Acer Aspire (NoteBook) 3660 Series Standard Memory : 512MB (Removable) Maximum Memory : 2GB Total Memory Slots : 2 Memory Type : DDR2 667MHz (PC2-5300) 200-PIN SODIMM
Dec 28, 2009 | Computers & Internet
ACER Aspire 6530 - Windows Vista sound problem
I had the same problem, and it always seemed to be a resource issue. (CPU running near 100%). Somehow my Acer ePower Plan was set to "balanced" and when i looked at the settings for CPU speed when the computer was plugged in, it was set to LOW !!! So, I changed it high, rebooted and it now sounds great.
Jun 21, 2009 | Acer Aspire 6530-5143 Notebook PC
Evesham 8615 Gtk laptop
Evesham Laptop 8615 XP Pro sp2. Need: Sound, Graphics, Ethernet, Chipset drivers. Thank You Samson.
Dec 21, 2008 | Evesham Voyager 6200 PM32 Notebook
Acer Aspire One  PC Notebook Logo
78 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
