Question about Frigidaire FRT18G4A Top Freezer Refrigerator
Freezer not working properly...
Hello All, My Freezer has not been working properly for a week or two now, not freezing anything at all. Within the last few days, the fridge seems to be warmer then normal as well, So I went through this site, and there was a suggestion to open the back of the freezer (inside), and check the coils to see if they were frozen or not... I did this, and yes, it was frozen, not evenly, all on the right side. So I left it unplugged for a little, and with a hairdryer I melted all the ice, and dried up the freezer. Put it back together and turned it on, took a while to start getting cold again, but it started, so as a joke, I took off the back again to see if all the coils were frosting up evenly, and they are not, still freezing again just on the right side, and the rest of the coils are not even cold to the touch.... Any ideas? Thanks!
  • Brian Preston Jun 10, 2007
    Okay, so what your basically saying, is that there is no easy fix for this? I'm looking at replacing some major parts... Also, I couldn't find the exact model number on this site, so I went with the closest I could find, the actual Model # is: frt18g4awb....
  • 878 Answers
Nortron, sounds like the system is restricted. I have seen a lot of these Frigidaires in the past 5 years with this problem. You should have a even frost pattern through the entire evaporator. I have been changing the compressor, evaporator and heat exchanger on these models. Your system on this refer is covered for 5 years, parts and labor for this failure. Here's hoping it's under 5 years. If it is, make sure all three componets mentioned above are changed out, otherwise the same deal is going to happen again down the road. Catriver.
Posted on Jun 10, 2007
Doest seem to be freezing as solid as it should aspecial in door
Hello Linda, thank you for your post!
I understand that your Frigidaire freezer is not freezing properly. This could be an issue with your sealed system (which is compressor, condenser, drier, or tubing) or your control panel. The recommended temperature setting for your freezer is 0°F. It is also possible that this could be a miscommunication within the freezer and I would suggest performing a reset. You can perform a reset by disconnecting the power cord for at least ten minutes. If the reset does not help resolve your problem you need to contact a professional technician for proper diagnosis and repair. -Matt
Jan 15, 2016 | Frigidaire 14.1 cu. ft. Upright Freezer...
Water leaking somewhere in exlectrolux freezer and causing the fan to freeze up. Help
Hello friend, thanks you for your post!
It sounds like a possible leak within your water line or water filter and that is what could be causing your Electrolux refrigerator fan to freeze. I would recommend having a professional come out to properly diagnosis your refrigerator.
The leak could also be within the cabinet and a technician would have the appropriate tools need to locate the cause of the leak. I hope this information has been helpful. -Matt
Oct 03, 2014 | Electrolux EI26SS55GS Stainless Steel ...
The drain keeps stopping up
Since there is no description of what type of freezer, I will talk generic. Most freezers have some sort of drain heater. Commercial walk-ins use them. 2 types: an insertion type that go inside the drain and another type that is wrapped around the outside of the drain and then wrapped with a foam type insulation call armaflex. hope this helps some.
Jul 28, 2017 | Freezers
Lg refrigerator leaking and freezer issue
Honestly, most people are not experienced on LG to know all the symptom and their solution. I guess you will have to wait for it to break again to have it fixed.
Oct 25, 2013 | Refrigerators
Freezer is working properly but fridge is not staying cold?
is the fan on in the freezer?? if not then you need a new evap fan..also check to see if there is frost build up on the back panel in the freezer section if so then you have a defrost issue could be a bad bandaid the problem..defrost the freezer back panel so air can flow into fridge side, but you will need to address the problem within a week or it will build up again
Apr 05, 2012 | Refrigerators
My whirlpool refrigerator is having problems, the back part of the freezer is all frozen solid, there is snow/frost building up above the ice maker and my refrigerator is reading at 60 degrees. I called...
Hello, Most times this is a bad cold control, but there are other things to check for. Make sure the condenser fan is working and the coils are not covered with dust. A separated heat exchanger ( small capillary tubing soldered to the large suction line ) can separate from one another and make the fridge run too long. - tape tubing back together. A poor working evaporator fan motor could also make the fridge run too long and freeze - replace the fan motor. An inefficient compressor or refrigeration system could make the fridge run too long and freeze - have a service tech check this out. A misaligned control settings, make sure the air damper and cold control have not been bumped and are out of normal settings. Stuck open air diffusers or air dampers are becoming more and more common for allowing too much air to be blown into the fresh food section and freezing things. On all frost free fridge's the freezer temp air is blown into the fresh food section, if you have "easy" to freeze items ( eggs, veggies in water, etc ) in front of or under where the freezer temp air comes out, they could freeze - store them in a different spot. Doors not closing properly making the fridge run too long is something else to check for.the air dceflector, As you know, the deflector directs the freezer air toward the front of the frig and the rear of the cold control
Oct 31, 2010 | Whirlpool 25.6 cu. ft. Side-by-Side...
My side by side coils freeze. I already changed out the mother board but within two weeks it freezes again. Any ideas?
You may have changed the wrong part.
The defrost heater and defrost thermostat are bad.
They are located inside the freezer coils behind the freezer panel.
Sep 17, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
Fidge freezer is not working properly
Get british gas homecare cover for heating and appliances, don't tell 'em the freezer isn't working, then a month later report it as a fault, they'll fix it. Unscrupulous i know but what can ya do? Otherwise get a hotpoint engineer, sign up for their maintenance plan.
Apr 04, 2009 | Hotpoint FFA70 Bottom Freezer Refrigerator
Refrigerator freezes everything-on 3rd service call now
If you have had 4 problems in a year where Sears had to replace something, you are entitled to a new refrigerator according to the lemon law. Call the 800 number and they can review your service calls. We have had several problems with our refrigerator as well. (Ice maker, lightbulb burning the plastic cover, motherboard needed replaced and the strip that holds the two doors together fell off) Today the service man was there for the 4th time to replace the door strip. I called the number and they are processing the paperwork for a new refrigerator.
Dec 30, 2008 | Kenmore 73502 / 73504 / 73509 Bottom...
GE side by side refridgerator
Sep 17, 2008 | Refrigerators
Frigidaire FRT18G4A Top Freezer Refrigerator Logo
240 people viewed this question
Top Frigidaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
