Question about Sewing Machines
Singer stylist 834 needle stuck in right side position will not zig zag
2 Suggested Answers
SOURCE: bobbin singer stylist zig zag model 477
Check this web page
http://www.sewusa.com/Threading_Diagrams/Threading_Pages/Singer_Sewing_Machine_Threading/singer_477_threading_diagram.htm
Posted on Jan 23, 2010
Needle bar does not move in zig zag mode on singer 457 stylist and will not move to full left with the position lever
Have you changed your presser foot over to the zig zag foot? On some machines it won't work correctly until you change to the correct presser foot.
Aug 24, 2017 | Singer Sewing Machines
How do I adjust the needle position for straight sewing?
The stitch Width selection regulates straight-stitch or zig-zag width. Needle position does not determine straight or zig-zag. Needle position just determines whether the needle's home position is center, left, or right. Needle position can be used with straight or zig-zag stitching.
Jul 03, 2016 | Sewing Machines
Cant find power button
Need to know your model, however commonly for a zig zag model the power button is installed at right side of the machine.
Dec 19, 2013 | Singer Sewing Machines
Singer troubleshooting
It could be out of time. Try a new needle.
Nov 01, 2013 | Singer Sewing Machines
Needle position
Hmmm sounds like an issue I had/have with a singer stylist. There is a knuckle part that connects the zig zag mechanism to the needle bar. Mine had a pin that kept slipping out. When I took it apart (and lost the pin) I also discovered that the "round" holes the pin went into were work out and were more like ovals. The machine is now a parts machine.
Dec 09, 2012 | Sewing Machines
I have a Singer Serenade 30 and have set everything according to the manual for zig zag but it still sews straight. Help!
Make sure that your needle shaft is not stuck, move it back and forth, oil if necessary. I had it happen to me once, but mine was caused by a bent needle shaft after loaning it to someone, and I had to do this each time I wanted to zig zag stitch. .
Mar 12, 2011 | Sewing Machines
I rethreaded a bobbin and now cannot get the needle to pick up the bobbin thread. What is the trick? Singer Stylist zig-zag 457
make sure that your needle is a good, sometimes there is a slight bend or burr and you do not notice. Replace it and make sure that the flat side of the needle faces the rear of the machine, then hold you top thread end and lower your needle and watch it hook the bobbin thread (when you put your bobbin make sure you have it in your tension slot and there is at least 6 inches) then gently pull your top thread and pull your threads to the back (have at least 6inches or else the needle can unthread.
Aug 30, 2010 | Sewing Machines
ZIG-ZAG NOT WORKING
Make sure your presser foot is tight down. If the needle is going from side to side, it's doing it's job. If the stitches are coming out straight, the material is probably slipping back and forth to center area. The presser will eliminate this.
Aug 28, 2009 | Singer 2638 Mechanical Sewing Machine
Singer Athena 2000 won't zig zag
Did you switch the metal plate to one of the ones that won't allow left/right movement by any chance?
If the wrong plate it in -The machine somehow figures out that the plate won't allow the needle to move in the left/right directions and only does a straight stitch or funky other stitches.
Jun 08, 2009 | Singer Sewing Machines
Sewing Machines Logo
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
