Question about Neff U1721 Double circotherm Electric Oven
How do I replace the heating element in Neff U1461N2 main oven?
  • Neff Master
  • 3,463 Answers
Switch power off first.
Remove the screws that secure the rear cover in the oven compartment.
There you will see the circular element, undo screws that secure element, slówly withdraw element towards you, disconnect leads, taking care not to lose them behind the aperture., fit leads onto new element, and refit element.
Refit cover and test.
Plz rate my solution.
Thanks.
Posted on Jan 12, 2009
Hi - have a Neff U1721 double oven, the element in main oven went bang cracked the element and blow a hole in fan cover. replaced the element but now temp light comes on but doesn't heat up, can you...
Test element check for continuity across the terminals and it is getting power when switch onon. If both ok, chances are the front selector switch has blown.
Feb 01, 2011 | Neff U1721 Double circotherm Electric Oven
Neff single oven won't heat up. Replaced the main element and grill heats but when switched to fan oven the fan and light comes on but no heat?
If the fan is working o/k, then the element is faulty, or it is not getting power to it, you need to test with a meter for a supply to it.
Sep 23, 2010 | Neff Ovens
My Neff U1721 oven does not heat up, Element
YOU CAN BYPASS IT HOWEVER BEAR IN MY THIS IS A SAFTEY DEVICE AN MAY HAVE FAILED BECAUSE OVEN OVERHEATED,( FIRE RISK PRESENT) IF THIS IS THE CASE, A BYPASS SHOULD BE CONSIDERD VERY TEMPORARY.
Jun 10, 2010 | Neff U1721 Double circotherm Electric Oven
MAIN OVEN DOES NOT TURN ON HIGH
this could be the thermostat or the main oven element this sheet might help. For all Free appliance repair videos visit our VIDEO TUTORIALS
1, If the fan motor in the back of the oven is going round and the temperature light is on (normally little red light), but there is no heat then you will probably need a new oven element, these are generally very easy to fit and readily available from our website these can be tested with a electric meter.
To gain access to the NEFF element you will have to remove the back plate from inside the oven. Once removed you will see the fan and element, if you look closely at the element you will probably see a small hole burnt in it where it has blown. Sometimes however there is no evidence of a fault but the element is open circuit ie: broken inside the element casing, either way it will need replacing. Some elements will are fixed from inside the oven and some are held in place by nuts from the rear of the machine.
2, If your NEFF fan oven is getting warm but takes a very long time to cook or is burning the food more on one side than the other, then you need to check if your oven fan motor is working you will see the blade turning fast if it is ok. if the element is heating but the fan motor is not blowing the heat into the oven then you need To replace the oven fan motor is a little more expensive and a bit more involved.
3. If you have the opposite problem ie: your oven is over heating and burning everything then you will need to replace your NEFF oven thermostat
4, A quite common and easily overlooked answer is if your NEFF oven is not working at all ie: no heat and no fan then the chances are that someone has put the oven timer into AUTO mode, simply put oven back to MANUAL mode and all should be working again.
Jan 14, 2010 | Smeg Ovens
Neff circotherm doudle oven main oven fan working
It is more than likely that the oven element has failed.
You will it located at the rear of the oven compartment behind a removeable cover.
Hope this helps.
Jan 09, 2010 | Neff B1641 Single circotherm super...
Neff cooker not heating up
Hi, it feels like your oven element has gone.
switch it off from the mains, open the door and remove the screws fixing the back panel. You will find a round two turn element. Unscrew the element fixings and check the element for burnt marks, corrosion. If you have a multi meter, turn it to buzzer and use the meter leads to test the element connections. If it doesn't buzz, it's dead. Just needs replacing.
Cheers
Feb 15, 2009 | Neff U1721 Double circotherm Electric Oven
Neff U1661 main element doesn't heat up
Hi.
Yes ,it is the element.
You need to remove the panel at the rear of the oven, this will give you access to the element.
Good luck
Nov 21, 2008 | Neff U1661 Double circotherm super...
Duco4ss main oven not heating on fan setting
put test bulb on the two wires going to fan heating element,that will tell all,if bulb lights,its the fan element that needs to be replaced!good luck!!
Dec 17, 2007 | Ovens
Neff U1721 Double circotherm Electric Oven Logo
168 people viewed this question
Top Neff Ovens Experts
bosch5
paulcarew
xxxxxx xxx
Are you a Neff Oven Expert? Answer questions, earn points and help others
