Question about Cell Phones
1209 battery backup solution
Not getting backup of battery even after changing the battery , at last battery will be in dead mode if left in handset
2 Suggested Answers
caroldon
  • 17129 Answers
SOURCE: i have a nokia 5530
Once fully drained out remove battery and use a good cleaning onthe battery terminals and the contacts with a contact cleaning liquid. Wipe dry.
Now put the battery for charging overnight.
If the battery drains out prematurely then it is quite possible that the battery is not retaining capacity( Ah), could have developed back emf.
So best get a replacement if in warrranty
Posted on Sep 21, 2010
How do you record an announcement? How do you change the code? How do you change the time? Thanks!
You may need to set the main handset to synchronize with the base unit plugged into the telephone wall jack and assign special configuration numbers to the other handsets in order to properly identify each one within a specified location. One handset left in the turned on mode may make it impossible to place calls with the any of the other handsets. This will continue until either the battery dies or fails on the handset or the phone is switched off and replaced in its charger for charging again. Synchronize the main handset by pressing the MENU button on the handset, then pressing the down button IN order to select the number you wish to assign to that handset. Repeating this process if you have already done so will greatly decrease the level of errors experienced with panasonic phones MORE USEFUL INFORMATION FOR ALL YOUR ELECTRONICS When troubleshooting these units, there are always several variables to consider. First check to see what last occurred with the unit such as did the children play video games, did the electricity go out due to bad weather. You may see that there are many possibilities but let's focus on what occurred last to the unit. Once we determine what happened last, we may isolate the actual cause of the problem. The actual cause may be associated with projection issues, older versions (Picture tube), interference from devices located nearby, and even a radio turned on and located really close to your unit. This is normally known as electromagnetic interference to electronics and is very common with the error you have provided today. Please continue to look for anything EXTERNAL to the unit before looking at the internal components. I have been working on these a long time so feel free to follow up with me.
Jan 18, 2011 | Lucent PARTNER18 Corded Phone
FIVE LAST DIGITS ON ID CALL. HOW TO CHANGE TO COMPLETE ID CALL?
Jan 18, 2011 | Panasonic KX TG4022 19 GHz Twin Cordless...
Caller i.d. doesn't work any more; changed batteries, and it still does not work. Do I have to set up the caller i.d. again? Nancy
Some Panasonic cordless phones come with up to five handsets each will need to be properly adjusted. You may need to set the main handset to synchronize with the base unit plugged into the telephone wall jack and assign special configuration numbers to the other handsets in order to properly identify each one within a specified location. One handset left in the turned on mode may make it impossible to place calls with the any of the other handsets. This will continue until either the battery dies or fails on the handset or the phone is switched off and replaced in its charger for charging again. Synchronize the main handset by pressing the MENU button on the handset, then pressing the down button IN order to select the number you wish to assign to that handset. Repeating this process if you have already done so will greatly decrease the level of errors experienced with panasonic phones MORE USEFUL INFORMATION FOR ALL YOUR ELECTRONICS When troubleshooting these units, there are always several variables to consider. First check to see what last occurred with the unit such as did the children play video games, did the electricity go out due to bad weather. You may see that there are many possibilities but let's focus on what occurred last to the unit. Once we determine what happened last, we may isolate the actual cause of the problem. The actual cause may be associated with projection issues, older versions (Picture tube), interference from devices located nearby, and even a radio turned on and located really close to your unit. This is normally known as electromagnetic interference to electronics and is very common with the error you have provided today. Please continue to look for anything EXTERNAL to the unit before looking at the internal components. I have been working on these a long time so feel free to follow up with me.
Jan 17, 2011 | Lands Phones
My Trip Lite Internet550SER UPS battery back up /serge protector was purchased through Dell only 8 months ago. Last night we had a major strom with power outage. This morning when I came in the devise was...
Yes, it can. I have replaced more than a couple of poorly made Chinese gel-cells after fairly brief service.
Also, you can extend your UPS's service time before the battery is depleted by turning off the monitor and settings the Power Management settings to power-down hard drives after 10-20 minutes.
In my experience, the ratings on UPS systems is wildly optimistic regarding their backup capabilities.
Also; the protection against lines surges caused by even distant lightning strikes is fairly minimal.
If this is in your home, you might consider installing a 'whole house' surge arrester. Depending on the maker, they offer up to $10,000 in damage insurance to cover any losses not prevented by their devices.
The plug-in strips with 'surge protection' have a 50 cent component in them to clamp spikes to ~200VAC and these even get tired with repeated surges and eventually become totally ineffective.
If the battery checks out OK, the circuitry responsible for switching from AC line to backup mode may have already been damaged during the storm.
Switching to the 'surge protector' mode really only provides mildly conditioned AC line and involves no active electronics.
Aug 06, 2010 | IBM Tripp Lite Internet Office 500...
1209 main network nahi aa raha hai kya kare?
apna network conection change kro.or settings main network sellings main ja kr automatic kro.manual nahi
Nov 28, 2009 | FROM Software Left 4 Dead for Xbox 360
My lg kg 300 is dead not runing or not lifes again
Remove the battery immediately. Don't put back the battery again at all in your handset until and unless your handset get fully dried. Also do not try to Switch On your handset, as this will result in permanent damage of your handset's main board.
Take your handset to the Authorised LG Service Centre and they will do the needful. Don't try to open it yourself.
Apr 23, 2009 | LG KG300 Cellular Phone
Battery Backup Outlets Not Working
well it could be your ups hardware is already fualty.. either u replace a new ups of ask a service if your worries is abt the cost you can ask mi if you are interested price you can neigotiate
Mar 16, 2009 | Belkin 1000VA/550Watts UPS with Software...
Loss of data when battery goes dead?
-are all pda's this way? All PocketPCs are this way. I don't own a P**m so I can't speak to them. -When the main battery depletes to the point where the unit shuts off how long do you have before data is lost? Until the backup battery dies. -Is the backup battery just used when changing main batteries or does it take over when the main battery goes dead? If so how long do you have before it is dead? I've never had it happen, so I cannot say how long, but if you continue to try to use the PDA on the backup battery it won't be long (minutes) if it even lets you do that. The backup is there to bridge over battery changes and to act as a safety net if you run the main batteries totally flat. -does the backup battery recharge or does it have to be replaced? Replace. -with a fully charged unit how long can it be left off before data is lost? Depends on the machine. Most of us leave the thing in the charger overnight every night, so this issue doesn't come up. You could try an experiment for 1, 2, 3 days, looking each day at the battery remaining and work up an estimate. I would expect maybe a week or more. Remember, even "off" the machine is still drawing power to maintain the RAM memory.
Sep 13, 2005 | Dell Axim X5 Pocket PC
Cell Phones Logo
56 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
