Question about Garmin NUVI2595LMT GPS
Nuvi 2595LM screen went black
Unit is stored in protective case when not in use. Installed unit in car for use, no response when plugged in. Power cord is OK.
5 Suggested Answers
SOURCE: My Garmin nuvi 780 will
I had the same problem. When you have your nuvi plugged into your cigarette lighter it doesn't charge. Your battery is probaly near dead. I called Garmin and they told me to plug it into my computer via the usb cable. Turn the Garmin off and let it charge for several hours. That did the trick
Posted on May 27, 2010
sharcnet
  • 2130 Answers
SOURCE: nuviĀ® 650 Car GPS Receiver: My Garmin Nuvi 650 has a locked screen. The touch...
Sounds more like his problem is a non-responsive touchscreen. Please see this link:
http://www.sharc.net/gps_LCD_repair.htm
- Jim
Posted on Jul 06, 2010
  • 5 Answers
SOURCE: My Garmin nuvi 1300 brightness problems
I spoke to Garmin Support about this issue. There are 2 settings for contrast on the nuvi 1300. You need to set the contrast while it is plugged into the vehicle, and also while it is unplugged from the vehicle. The reason for the 2 settings is to save the charge of the battery while it is not plugged into the vehicle or power source.
Posted on Jan 14, 2010
  • 10865 Answers
SOURCE: Hi,
Hi Louise. Carefully pry the frame off from around the screen. It is thin and delicate so work carefully and use your fingernail. Once you have that frame off you will see a reset button. with the unit on, push the reset button. This may solve your problem, in fact it probably will. But, if it does not, go to Garmin.com and see how to mail it in for a repair. J.
Posted on Aug 02, 2010
Testimonial: "helpful but i still can't find the button and I pried off the silver frame. I may be missing somthing."
Hairlines and blotches on brand new Garmin Nuvi LCD screen
If your brand new Garmin GPS doesn't look good, return it for a replacement.
Jan 13, 2014 | Garmin nuvi GPS
Tip
Garmin Nuvi 1300 Hard Reset Models: Nuvi 1200, Nuvi 1210, Nuvi 1240, Nuvi 1245...
Models: Nuvi 1200, Nuvi 1210, Nuvi 1240, Nuvi 1245 , Nuvi 1250, Nuvi 1255, Nuvi 1260
Models: Nuvi 1300, Nuvi 1300, Nuvi 1310, Nuvi 1340, Nuvi 1350, Nuvi 1370, Nuvi 1390
Models: Nuvi 1410, Nuvi 1440, Nuvi 1450, Nuvi 1490
Does your Garmin Nuvi 1300 Freeze at Loading Maps?
Does it lock up or stop working?
This tip will describe how to perform a hard reset of the device, and how to backup your 'Favorites' in case the hard reset erases them. The next step in fixing your Nuvi when it doesn't start properly is to update its system software using Garmin WebUpdater.
A hard reset (or Clear All User Data) has been known to resolve unit quirks and strange behavior. It's generally recommended to perform it after a firmware update but is not required by any means. However, if you're seeing quirks and strange behavior with your unit after the firmware update, it is a good idea to do a hard reset of the unit.
Backup and Restoration Procedure for Favorites:
The Hard Reset procedure has been known to delete your Favorites, so back them up beforehand.
  1. From the Nuvi drive, copy '/Garmin/GPX/current.gpx' to a backup location on your computer.
  2. After the hard reset, copy your backed up 'current.gpx' from your computer back to the '/Garmin/GPX/' folder on the Nuvi, but be sure to rename it 'temp.gpx'.
  3. On the next power cycle, the Favorites will be read from 'temp.gpx' into the non-user accessible memory area on the Nuvi where they are actually stored.
Perform the Hard Reset:
*Note that this will clear all user selected settings on the unit
  1. Power the unit off.
  2. Remove the battery and wait several minutes.
  3. Install the battery.
  4. Press and hold (and continue to hold) the bottom-right corner of the screen while powering the unit on.
  5. Continue to hold the screen until the "Do you want to erase all user data?" prompt appears.
  6. Press "yes" and the unit will reboot. This resets all your location settings and user preferences.
If possible after the hard reset, let the unit sit outdoors in the open for about 30 minutes or so to let the unit re-acquire the satellite almanac data.
You have now performed a hard reset of your Garmin Nuvi 1300 series GPS unit.
I hope that helps.
__________________________________________
Garmin Nuvi 1300 Manual Download
Garmin Nuvi 1300 QuickStart Download
Garmin Nuvi 1300 Favorites Backup
Garmin Nuvi 1300 Webupdate
on May 13, 2010 | Garmin nuvi 1300 Car GPS Receiver
Locked up on Start/Boot screen.
You can try a reset by performing the following, just keep in mind that any favorites and waypoints that you might have entered will be erased.
1. Start with the unit OFF and unplugged from power
2. Touch and hold the lower right corner of the screen with an index finger or the eraser end of a pencil
3. Continue touching and holding the lower right hand corner of the screen then power the unit ON
4. Release the power button when the device powers ON
o You will see a new message: Do you really want to erase all user data?
5. Remove your finger from the touch screen when this message displays
6. Touch Yes
The device will automatically reset.
Please let me know if if helps
Thanks
May 13, 2010 | Garmin nuvi 1390T Car GPS Receiver
Garmin Nuvi 660 shut itself off and will not turn back on
Hi Sherry,
The unit should not get warm, unless the battery was fully discharged or maybe shorted out. Most likely a part has failed on the main board.
Please see this link about a Dead Nuvi:
http://www.sharc.net/gps_dead.htm
- Jim
Mar 10, 2010 | Garmin Nuvi 660 GPS Receiver
My New Garmin Nuvi 1400 will not turn on - it just gets to the screen "Loading maps" and then the screen goes black. I have tried the suggested holding down the power button for 10 seconds, but nothing...
My Garmin Nuvi 1490 was on for five or six hours driving then the screen went dark and now unit will not turn on or light up screen at all ? ANY HELP OUT THERE ?
Feb 09, 2010 | Garmin nuvi 1490T GPS Receiver
My garmin nuvi 255W has been working fine. I
Try resetting your unit with the reset button on the bottom. If this doesn't work, slide the power button all the way to the left and hold it for 8 seconds.
Dec 30, 2009 | Garmin nuvi 255W GPS Receiver
Battery Charging, Nuvi 35
Charge the unit over night, Plug in the AC charger and you should see a lightning bolt over the battery bar graph display.
With the charger plugged in, gently press and hold the on/off power until the screen goes black and displays the text "Charging battery". After a few seconds, the screen will go black to conserve power. At any time, you can press the screen and it will light up saying its still charging.
If you let it go over night, when you touch the screen, it will say Charging Complete and you can then remove the charger. You should have full green bars on the battery indicator.
- Jim
SHARCNET-USA
Dec 20, 2008 | Garmin Nuvi 350 Car GPS Receiver
Garmin c550 GPS-Won't turn on at all.
push and Hold the power button down while you push reset, keep power button pressed til it boots again. If it does not, and it's in warranty ship it to garmin. If it's out of warranty, have someone open it up and remove the battery for a couple of minutes.
Jun 29, 2008 | Garmin nuvi 350 GPS Receiver
NUVI 250w Show Black Screen with ICON of Computer and NUVI
I had this problem. I discovered that I was using the wrong lead in the car. The problem resolved itself when I used the lead that came with it.
May 24, 2008 | Garmin nuvi 200W GPS Receiver
Digital photo keychain
Have done that, reset the unit, tried all combination of re-installing software, starting program 1st, plugging in unit 1st. pressing power button, resetting unit while USB is plugged in adn not plugged in, holdig doen power button and reset, holding pwr button while plugging in, and about 20 more combination. The screen says "UPDATING", the little light is"GREEN", the battery meter shows "FULL", when you unplug unit screen goes black and "NOTHING"... "0", "NADA", piece of **** !
**** SOLUTION -- RETURN PIECE OF **** TO STORE FOR REFUND !!! *****
Dec 08, 2007 | Alera Technologies Digital Photo Copy...
Garmin NUVI2595LMT GPS Logo
1,420 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
