Question about SanDisk 1GB microSD Memory Card
1GB MicroSD card detecetd by computer as 0 memory device
I have connected a 1GB microSD card to computer though USB card reader. When I checked the properties of the microSD card it displayed as 0 bytes available space and 0 bytes used space.
Is it possible to format it?
Please help me.
  • 1123sun Jan 19, 2009
    Now when I connect the same microSD card to same to PC through USB card reader, its not at all detecting. How to format it?? please help me.
  • 158 Answers
Please format it. It needs to be formatted to read them.
Posted on Jan 12, 2009
  • 1 more comment
  • muhammad ali
    muhammad ali Feb 17, 2014
    unfortunately my sd card was giving sudden 0 bytes when i format it again nd again it never work help me to resolve problem 4 gb sd card is it possible to recover nd use again
  • muhammad ali
    email me iqbalnsons1@hotmail.com
  • muhammad ali
    when i format it say window can not format it
I have connected a 1GB microSD card to computer though USB card reader. When I checked the properties of the microSD card it displayed as 0 bytes available space and 0 bytes used space. Is it possible to format it? Please help me.
Posted on Oct 03, 2009
4 Suggested Answers
randy320sgi
  • 121 Answers
SOURCE: 2gb sd card but available only 1gb
levyveress,
Well you have a 1GB SD card, there are roughly 1,073,741,824 bytes max per gig. They vary slightly from USB flash drives it total bytes, but the number should be 1,930 (or something close) MB for the 2Gig SD card, bring it back it may have been mislabeled on the packaging.
randy320sgi
Posted on Jan 18, 2009
  • 181 Answers
SOURCE: i ve 1gb micro sd
take the card to asda and ask if you plug it into there memory reader where they print photos to see if it opens.if it does it is your reader at fault.
Posted on Jun 01, 2009
gurvy
  • 223 Answers
SOURCE: I have forgot the password
Most memory cards have a lock switch on the outer edge of the card, its very small. look on the physical memory card and slide the switch back and forth a few times, leaving it in the unlocked position. Then insert it into your computer and try again.
Posted on Aug 29, 2010
How to remove write-protection on a micro sd card
  1. Connect the microSD card to a computer
    Use a memory card reader to connect the microSD card to a computer for formatting. In case you're using an SD card adapter, ensure that the write protection key is in the unlock position.
  2. Locate the card Right-click My Computer, and click Manage. Go to the Disk Management tab on the left pane, and locate your microSD card from the list of available disks.
  3. Format the microSD card Right-click on the microSD card's drive, and click Format. This eliminates all data, including corrupted files that cause write protection in storage devices
Nov 09, 2016 | Electronics - Others
Where do I insert my microSD memory card or does my computer have a slot for it?
Here are the ways for you to insert your microSD to your computer
1. Use "memory card reader" (this is probably the best way)
find the slot that says "micro sd" that's where youre going to insert the microSD
2. Use the internal memory card reader of your pc ( if your computer has it)
it is located in front of your desktop. The find the slot that says "micro sd" and insert it.
Sep 13, 2011 | SanDisk 2GB microSD Memory Card
How do I load scan disk pictures onto computer
If your PC has an SD card reader you can place the microSD card into the adapter that it came with and then insert it into the slot on the PC. The SD card reader will be a small slot usually at the front of the computer. If there is no SD card reader then place the microSD card into the gadget you use it with such as your camera/phone etc and connect the device to your PC using a cable the device came with. The cable will have a USB jack at one end that will fit into the USB ports at the front/back of your computer. Once your device is connected you can follow the on-screen instructions to access your pictures.
May 23, 2011 | SanDisk 1GB microSD Memory Card
MY COMPUTER DOES NOT DETECT MY 1GB MICRO SD CARD
check your card reader or check your card into another computer if it works then it is your card's problem if the card does not detect with a new card reader then its time to change the card.
Oct 11, 2009 | SanDisk 1GB microSD Memory Card
I ve 1gb micro sd card which i use in my fone.now when i try to read the data through card reader and it cant be read My 1gb SanDisk microSD memory on my computer.
Jun 01, 2009 | SanDisk 2GB microSD Memory Card
Memory card cant be read My 4gb SanDisk microSD memory doesn't read on my computer. I bought it today at Radio Shack.
Are you using a card reader? If yes, you need to isolate the problem. Please follow the steps below:
1. Try connecting your memory card reader into different USB port of the computer.
2. Try using different card reader to see if there's a problem with the card or with the reader.
3. Connect it into different computer.
4. Remove and reinsert the MicroSD in the card reader and make sure that the card is properly seated.
5. If the card reader and the computer are working but still unable to detect the MicroSD, try to reformat the card.
6. If same problem persist, return it to the store and have it replaced.
Have a great day!
May 26, 2009 | SanDisk 2GB microSD Memory Card
Inserting Memory Card
you need to buy a usb card reader
Mar 21, 2009 | SanDisk 1GB microSD Memory Card
Clean the contacts with a pencil eraser
Use a Photo Recovery tool.software
use HP USB Format tool from Extreme Tech
http://files.extremeoverclocking.com/file.php?f=197 ) and try reformatting.
If none work, it is hosed and only I can fix it so let me know ;-)
Jan 14, 2009 | SanDisk MobileMate SD+ 5-in-1 USB 2.0 Card...
SanDisk 1GB microSD Memory Card Logo
613 people viewed this question
Top SanDisk Electronics - Others Experts
k24674
Piyal Perera
Piyal Perera
Are you a SanDisk Electronics - Other Expert? Answer questions, earn points and help others
