sony h8 analogue video camera keeps telling me to reinsert tape also when it does run for acouple of mins no picture or sound but when i press the pause button i can see the picture
Try depressing the "Reset" button with the camera powered on using a pencil/ball point pen - the camera's logic may have got out of sync. This often helps to remove C:xx:xx error types as well.
Was this helpful?
Yes
No
Popular Solutions for Sony HDR-HC1 Mini DV Digital
The touch panel does not work in flip out mode(standard mode). However, it works when you flip the...
(More)
The touch panel does not work in flip out mode(standard mode). However, it works when you flip the panel to view on the side of the camera. The battery test worked and I can view from inside.
cam stop working doesn't power up and screen will flash white about every 10 sec ? can you help...
(More)
cam stop working doesn't power up and screen will flash white about every 10 sec ? can you help thanks
the lcd panel on my hdr hc1 is not working properly. I am unable to access the menu and the frames...
(More)
the lcd panel on my hdr hc1 is not working properly. I am unable to access the menu and the frames keep moving on the screen.
