Epson sx 205, can't change the cartridge
I am trying to put a new black ink cartridge in my printer, but the thing that holds the cartridges seems firmly ensconced in the right hand side of the printer and won't move across ... I've tried pretty much every button ... can you help?
  • 4 more comments
  • brendybop Jan 28, 2009
  • Anonymous Jan 31, 2009
    i cannot do it
  • Anonymous Mar 23, 2009
    I also had a problem changing the ink cartridges. I followed the instructions in the Epson Leaflet in pressing the On and Stop Button. The cartridge holder kept shooting to the left to the right, to the left and returning back to its original locked position on the right. I could not get to the holder to change the cartridges. I therefore went on the net and located a Helper's advice and followed this and managed to eventually change the cartridges. Every time I do this it takes my valuable time, which I do not have. If I cannot do this easier, I will have to obtain another printer.
  • negee Apr 08, 2009
    I have the exact same problem with my printer too. And the solution wasnt so helpful too :(
  • jen6 Apr 20, 2009
    What an absolute nightmare I too am having in trying to change any of the cartridges! It takes ages. I still haven't managed to change them at present, after wasting at least 20 minutes! I am experiencing the same problem. The cartridge holder whizzes to the left and to the right and to the left and then firmly stays on the right hand side and is immovable! Also I do not find the cartridge lasts for very long and am always having to try and change the cartridges. Epson is very good at showing pop-ups of low ink etc, but this is a little tiresome. It is a shame as the Epson SX 205 is a lovely looking model, but is not easy to use.
    Jen K.
  • Anonymous May 21, 2009
    cant change ink epson sx205
With the power on and the lid up, click on the red stop (left panel). You will notice the cartridges move to the left and then they come back and stop halfway. Afterwards you should be able to slide the cartridges manually with your hand to the larger area on the right where you could do the cartridge change. Once you've moved it to that area just the lift the cover where the arrow is.
Posted on Feb 08, 2009
  • 1 more comment
  • ArvindRajput Sep 13, 2009
    You can get the cartridge to the desired position to replace the cartrige via your computer. Worked for me. I have posted the link to EPSON's solution.
    Basically , go to Printer properties - maintenance tab and select replace cartidge utility.
  • cuzzo142 Apr 13, 2011
    Thanks for posting...I'd forgot how to do it...happy days :)
  • Jackie Strachan
    Jackie Strachan Mar 23, 2014
    Press the button for six seconds, and release once the print carriage starts moving. For some reason Epson missed that part out of the instructions!
I went through the control panel>printers> maintenance> replace ink and it worked. the "pressing the stop button" doesnt work...try this way
Posted on Oct 29, 2009
With the scanner cover lifted, press and hold the arrow button for approx. six seconds. Once the print carriage begins to move, you can release the button. The print carriage will then indicate which cartridges require replacing. Press the arrow button each time the carriage moves to the low ink indicator, and eventually it should park in open area on the right. Now replace the ink cartridges previously indicated, Once replaced, press the arrow button once more and allow the printer a few moments to charge the print head.
Hope this helps!
Posted on Mar 23, 2014
  • Chris Allen
    Chris Allen Aug 03, 2015
    This is the correct answer, thanks!
    Sergeant:
  • 306 Answers
I seem to have lost you. Please repost if you still have a problem. Steve Medley
Posted on Jan 12, 2009
I had the same problem. i checked the web for a solution but found none. so what i had to do was press the red stop button (under the power button) until the ink went over to the left, then when it came back over to the right and passed by the opening where you can actually get your hand in to change the ink, i quickly pressed down on the long grey release button and pulled it up, stopping the ink from going over to the extreme right where its impossible to get at. i quickly turned off the power then to stop it in its tracks to prevent damage. i changed the ink, clicked back down the grey button and pressed back on the power. probably is bad for the printer but it worked for me. hoped this helps.
Posted on Sep 05, 2009
    Problem Solver:
  • 7 Answers
What is happening is the cartridge goes over to the arrow tab on the left to show you which cartridge is empty. (There may be more than one that needs changing). Then it should go over to the right to allow you to change it.
NB It is probably best to use Epson cartridges as I had to get my printer 'fixed' due to waste ink cartridge full - which doesn't appear to be user accessible.
Posted on Nov 22, 2009
Changing cartridge SX 150
Press ink button several times until it positions the holder to change the black ink.
Sep 24, 2012 | Epson Stylus Multifunction Inkjet Printer/...
Need to change ink cartridge on a epson stylus sx 215
remove the ink, then turn on the printer, then hold the power button in 2 seconds, wait for the ink cartridge to go to the center, then change the cartridge
Oct 26, 2010 | Epson Stylus CX3200 All-In-One InkJet...
My stylus sx 205 will not stop and let me change
After some searching (Epson doesn't make it easy), I found this documentation on how to change the cartrages for the sx200 series using the software:
http://support.epson-europe.com/onlineguides/en/sx200tx200/html/trble_2.htm#s-01200-00500-00100-00300
The support page for your printer is here: http://www.epson.co.uk/Store/Printers-and-All-in-Ones/Epson-Stylus-SX200/Drivers-Support?supportLandingPage=true
The downloadable pdf of the manual is here:
ftp://download.epson-europe.com/pub/download/3210/epson321015eu.pdf
Apr 23, 2010 | Office Equipment & Supplies
How to change cartridges epson stylus sx 400
From older Epsons: If the ink cartridges are empty (red light on), hold the ink switch 3 seconds to move the print head to the left. If they are not empty, hold paper switch until print head moves left. Once you remove a cartridge you can't reuse it, even if there's ink in it according to Epson.
Nov 16, 2009 | Epson Stylus C86 InkJet Printer
EPSON Stylus CX7400 won't accept ink cartridge
Mine acts up this same way (more often than not). I've found that as I install new cartridges, it helps to "tilt" it towards the chip end so that it "rubs" as it's going in. You'd normally hold both sides when replacing a cartridge but I don't even touch the outer end as I do it & it seems to help the printer "see" the replacement when installed.
Oct 20, 2009 | Epson Office Equipment & Supplies
C60 says full cartridge is dry
You could try taking out the new ink and putting in the old. Then uninstall the program, delete all reference to Epson in Regedit, then reinstall the program.
Change the cartridge when prompted.
Of course, having messed about with the jet, it may not work now !
Jun 05, 2008 | Epson Stylus C60 InkJet Printer
Ink Cartridge
Some of Epson's cartridges went bad that way. It may be a bad cartridge. Get a new one, pull that one out and see what happens. If it works, call Epson for a refund. They had a class action suit for that type of thing, they lost and paid off. I would think they will help you right away.
C
May 31, 2008 | Epson Stylus CX6400 All-In-One InkJet...
Changing black & colour ink cartridge
My guess is that it will be the non gen carts they cause heaps of trouble, beleive me. Hard to tell you for sure but the first thing I would do if you brought it in for repair would be to put in manufactures cartridges.
Dec 01, 2007 | Epson Stylus CX3200 All-In-One InkJet...
7,053 people viewed this question
jasbo
jasbo
