Question about KitchenAid K45SS Classic Stand Mixer
Stand jumps My mixer head is jumping up and down while mixing it has even worn the white off the beater. while off you can actually have the mixer locked and you can move the head up and down in locked position. Please help!!!
  • 2 more comments
  • Anonymous Feb 14, 2009
    Same with ours. Need to know if this can be fixed at home.
  • alexandra7 Feb 14, 2009
    I have the same problem as well. tried everything. it's going to break the whisk attachment if I use it, have resorted to an old hand mixer and I am NOT happy! help
  • Anonymous Apr 08, 2009
    This didn't work for me.  Turning the screw counter-clockwise did not make any difference, neither did turning it clockwise.
  • Anonymous Mar 18, 2014
    The head doesn't want to release from the stand so I can pour the mix into the pans for baking.
The height of the beater is easy to adjust on the tilt-head model.  Tilt the head back, and look into the pivot from the front of the mixer.  You should see a screw on the hinge.  With a flat blade screwdriver, rotate this screw half a turn counter-clockwise to raise the beater height.  Lower the head and check that the beater does not touch the bowl.  Repeat until the adjustment is satisfactory.  To lower the beater closer to the bowl, turn the screw clockwise instead.
Posted on Mar 01, 2009
Thank you for the help it worked
Posted on Mar 07, 2009
Kitchenaid stand mixer 5SSWH 325 watts. How do I adjust the bowl height? Beater is too far from bottom of bowl. Thanks! Cas
There is a screw at the bottom of the motor head (flat head) you usually can't see it because of the top rim of the mixing bowl. hard to see and hard to reach, it may also be hard to turn due to "gunk" from mixing stuff (egg butter flour sugar) turn the screw counter clockwise to lower the motor head clockwise to raise it, you may also have the wrong size beater, it is not an uncommon problem, if you are the original owner and you have the original beater it should fix your problem with the adjusting screw, however I am not clear as to your model a 5SSWH would actually be a K5SSWH, which stands for kitchenaid 5 quart solid state white mixer, if this is your model number and you have the correct beater size then the adjusting screw will work to lower the head down, adjust it down using the stir or slowest speed just untill you can hear the beater "Ding" against the bottom of the bowl, then back it off a quarter turn to adjust properly. Hope this helps, let us know
Apr 17, 2013 | KitchenAid K5SS Heavy Duty Commercial...
How to fix a Kitchenaid Model # KV25G0XWW mixer head that jumps
Use the locking lever on the side. It WILL jump if you are mixing something stiff.
Jan 12, 2013 | KitchenAid KV25G0X Stand Mixer
Beaters are hitting each other and jamming up
One of the beaters had jumped a gear. I understand they are nylon gears. My wife's had the same trouble. I unplugged the mixer, removed the bowl and install the beaters if you can to see where they are touching. They were two cogs off. I grapped the left (red) beater firmly and twisted it to the left. It took a couple tries and turning on the motor (with out beaters) to find the spot where they had skipped. In the end the left beater jumped back one then two teeth and now the beaters aline properly.
This will happen again with heavy dough, etc. now that the teeth are worn in that spot. Use a bread machine for the heaver dough. IMHO
Dec 12, 2012 | Sunbeam 2346 Heritage MixMaster Series...
The head of the mixer is vibrating (shaking) a lot when mixing. It does this so much that I feel as though I need to hold onto it when it's mixing. If I turn it on without the bowl and just run the...
I am sure you are locking the tilt head in the down position when your using it right? If so then check to see if the beaters are hitting the bottom of the bowl. If they are then there is an adustment screw that sets the height of the head in the down position.
Jan 01, 2011 | KitchenAid Classic Stand Mixer
The mixer turn table won't turn? Its only a year old?
Don't know a solution, because I am having the same damn problem.
I am very discouraged with this product.
It is a piece of ****.
I am thinking about taking it out back and shooting it with my 270 I bought.
That is the only solution I know.
Dec 03, 2010 | Sunbeam Heritage 2346 Stand Mixer
Kitchenaid beater rubs bottom of the bowl
Your beater to bowl clearance has come out of alignment. This can happen naturally over time and with normal use of the appliance. This is something you may correct from home using a flathead screwdriver.
Unplug the mixer, with the bowl and flat beater removed. Tilt the mixing head back as far as the machine will allow. In the exposed hinge, behind where the bowl would normally sit, you will see a 3/8 screw exposed. Turn this screw half a turn counterclockwise (to your left) in order to raise the flat beater from the bottom of the bowl.
This may take a few attempts until the beater is clearing the bottom of the bowl again. If the adjustment screw will no longer turn, do not force it. It is only designed to move so far to make the appropriate adjustment.
Be cautious. Raising the flat beater too high may leave dry ingredients at the bottom of the bowl.
If further information is needed, I would advise you to contact Kitchenaid Customer Service. They may walk through this adjustment through you over the phone and can look into ordering replacement beaters for you also.
Their toll-free telephone number is 1-800-541-6390.
Mar 20, 2009 | KitchenAid Artisan Series Tilt-Head Stand...
Mixer turns on but the beater doesn't rotate
Remove the metalic ring around the mixing head. Push down on it with a flat head screwdriver...
Remove the pin from the mix shaft.
Pull down on the mixer head. Inspect the gears.
If nothing wrong here, disassemble completely and inspect drive gears. Something is broke and needs replaced. You need to find it first, then take that broken part to the dealer to get a new one. Good luck
Feb 24, 2009 | KitchenAid KSM150PS Artisan Series Stand...
Beater rubbing bottom of bowl
This sounds like an issue of beater to bowl adjustment, which can come out of alignment naturally over time and with use of the machine.
If the flat beater is striking the bottom of your bowl, this may cause the locking mechanism to loosen and may cause the mixing head to "bounce" during use.
Your Use and Care Guide will cover the "beater to bowl adjustment," which you can do at home in a few minutes with a flathead screwdriver.
Feb 14, 2009 | KitchenAid KITCHEN AID 5 Quart Artisan...
KitchenAid Artisan Stand Mixer - Tilt is Tilting too Much & hits the bowl!
This may have a simple solution: This sounds like an issue of beater to bowl adjustment, which can come out of alignment naturally over time and with use of the machine.
Sep 23, 2008 | KitchenAid KITCHEN AID 5 Quart Artisan...
Beaters fall down
You have to change the planet hub and the beater.
Nov 06, 2007 | Kenwood KM800 Major Classic Stand Mixer
KitchenAid K45SS Classic Stand Mixer Logo
893 people viewed this question
Top KitchenAid Food Mixers Experts
Appliance engineer
jack arons
Are you a KitchenAid Food Mixer Expert? Answer questions, earn points and help others
