I need new belts on my D99D Sansui Tape deck
It needs new belts
robotek
  • 1512 Answers
SOURCE: Drive Belts for AKIA Stereo Cassette Deck CS-M01A
still need help?
Posted on Feb 09, 2008
  • 319 Answers
SOURCE: How to change belt in teac x1000r reel to reel tape deck
If you are not familiar with such work, I don't recommend trying to install belt(s). Replacing belts may involve disassembly of mechanism parts and critical adjustments to follow. Take to a pro/tech
Posted on Apr 23, 2008
maklean
  • 1665 Answers
SOURCE: Replace a Tape Deck Belt
Better take it to an electronics repair shop. They have some experience in such repairs.
Posted on Jul 05, 2008
robotek
  • 1512 Answers
SOURCE: Gx-77 Akai reel to reel tape deck -belt
G'day Chidu
You can buy a replacement belt kit with the correct belts for your model from here
Thanks for using FixYa, a FixYa rating is a great reward for locating this part for you. Good luck with the repairs, and happy listening.
regards
robotek
Posted on Sep 11, 2008
SOURCE: Please can you help me, I need an Aiwa AD-WX808
We have one for sale. If you are still interested make make an offer:
uta.kamleithner-maly@boehlerstahl.at
Posted on Jun 05, 2010
The belt on my Pioneer CT-9R has slipped off the left hand side flywheel. Can the belt be repositioned easily or do I need to see professional help?
If it has slipped off then the belt is too loose so you will need to replace it. Too many people try and put ONLY a new belt on and forget all the rest of the work a deck needs. They are only successful for a very short time if at all. I have been working on tape decks for 45 years and have seen just about all brands. Look for a shop that specializes in tape deck repair.
Feb 11, 2014 | Audio Players & Recorders
I need to know how I can hook up my Teac EQA 5 equalizer to my Sansui AUD 9 power amp.. I lost the manual to the E/Q
It is very easy, you don't need a manual for this. The EQ line in and Line out get hooked into the record out and Tape in of one of the tape loops on the Sansui amp. Record outs go to EQ in and the EQ out goes to tape play.
Oct 10, 2013 | Sony TC WE435 Stereo Dual Cassette Deck...
I have a Pioneer model CT-F2121 want to connect it to my Radio amp. I has two ports at back of Radio which is marked "switched" and "Unswitched" Radio is a Sansui model 210SS multi receiver. I have tried...
The deck if in working condition can be plugged into any AC wall outlet or the two AC outlets on the receiver. This is only for power, The Line outs and line in also have to be plugged into the Tape in and record out on the receiver as well. If the CT-F2121 need repairs that is what needs to be done first. Probably a whole set of belts.
Aug 12, 2013 | Pioneer Audio Players & Recorders
TAPE DECK
The number two deck either needs a new belt or there is something else wrong with the take-up drive to the reel table. This needs looking at and if you can not do it then a Tape deck Technician will be needed. They are around and that is what I do full time.
skywavebe@sbcglobal.net if you want it repaired
Oct 21, 2012 | Audio Players & Recorders
Broken belt on Teac X7 Dual Capstan Drive tape deck
I just worked on one of those the other day. The unit needs other maintenance besides the belt- Flywheels need to removed and oiled and capstan shafts inspected and cleaned- I don't know how many ask me how to put in belts and then the unit end up at my shop because there are a lot other factors involved in the service of this deck. The last X7 I worked on needed both motors reconditioned but it worked great after that.
Skywave Tape Deck Repair in Chicago if you need the job done right. I have the belts here and Russ is in New Jersey if you are out that way.
Dec 13, 2010 | Teac Audio Players & Recorders
Head jammed in record
Most likely one of the belts has slipped a bit and the unit is stuck in the middle of a transition. Normally, a power up will "reset" the mechanism. Try that first. The owner should hear the motor run once the power has been turned on. If that is the case and the mechanism does not clear, then the belt is slipping and can't return the mechanism to a known start state. The unit will need to see a servicer to reset it and to replace the main drive belt.
Dan
Nov 02, 2009 | Audio Players & Recorders
I have a sansui d-95m cassette deck i put the tape in but no movement, motor is turning but nothing
I have solved the problem it was the drive belt and I put a rubber band on it and work just as good as a new one.
Thank you very much for you help enyway.
Jun 24, 2008 | Sansui Audio Players & Recorders
SANSUI SC-2100 RECORDING PROBLEM
First try cleaning the heads with some electronics grade alcohol and a static free cleaning swab...although it sounds like the head may need alignment...if those two things do not work out for you, the capstan motor might be the culprit.
Jun 22, 2008 | Technics Audio Players & Recorders
67 people viewed this question
 Grubhead
Grubhead
