Question about Garden
Needing parts for tradesman scroll saw model vs4000w
Tension arm broke
efs_perpends
  • 1996 Answers
SOURCE: Craftsman Radial Arm saw.
Have you already tried Sears Parts Direct?
Available by clicking here, you'll need to have the model number handy.
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take a moment to kindly rate this post....thanks!
Posted on Apr 08, 2009
  • 864 Answers
SOURCE: Need manual for Craftsman 16" variable speed scroll saw
Go to www.searspartsdirect.com and search by model number.
Posted on May 21, 2009
SOURCE: Need manual and lower blade support for the Hawk 216 scroll saw
I can send you a pdf of the manual. Email me at david.lowrance@tx.rr.com
Posted on May 26, 2009
SOURCE: need a owner manual for tradesman bench table saw model 8031
I believe I have the manual for the 8031 table saw. Are you still looking? Contact me at HollomannAFB@yahoo.com
Posted on Sep 12, 2009
My Ryobi model SC165VS scroll saw is an older model and the tension assembly parts are marked obsolete on all the web parts sites. Got any idea of how I can get the older model tension assembly?
See if you can get another broken one for parts on ebay or some junk shop. And if you go garage saleing you might just get lucky and bump into one!
Feb 13, 2016 | Saws
Motor will not run on scroll saw #315.216090...electric power to saw light.
if the tension is to great on the tension arm the motor can not overcome the tension to start. Disconnect the tension arm from the blade and see if the motor will run. If so the tension was to great. If not test the wiring going into the motor to make sure there are no breaks.
Mar 14, 2011 | Craftsman Saws
The pot metal in front of thequick release tension lever has broken and fell out. can I still use the saw If not where do I go to get another one 1830 120v 18inch scroll saw dremel
I believe the part you are looking for is called a "locking rod" dremel part number 2610922661, this is the black painted pot metal that is about 3" long attached to the upper arm rocker with a parallel pin, and the flip clamp (blade tensioning assembly) or it could be the small piece attached to the tension assembly that the blade attaches to which is silver and called the "blade holder assembly-top" part number 2610922683. I would recommend ordering both directly from Dremel CS 1-800-437-3635. I broke the locking rod on mine. I emailed dremel, and they emailed me back the next morning with a schematic, and parts list. I bought 2 and paid $10.41 total.
Mar 08, 2011 | Dremel 1830 120V 18" Scroll Saw
Trying to locate downloadable operator manual for rexon scroll saw model # RM 411 maufactured in 1988
U.S.A.--POWER TOOL SPECIALISTS INC.
684 Huey Road Rock Hill, SC 29730 U.S.A.
Tel: 1-803-980-7740
Fax: 1-803-980-7750
Http://www.tradesman-rexon.com
E-mail: custserv@tradesman-rexon.com
I'm sorry I could not find any downloadable information on this scroll saw, but I would imagine if you call or email the company above, they may be able to email you a PDF of what you need. Good luck.
Nov 21, 2010 | Garden
I need to replace the blades on a Sears Scroll saw. Model # 149236160
Your scroll saw should have come with Hex end tools to use when changing out the blade. You must release the tension on the blade (located on top of arm above blade). There is a small allen head screw which has to be loosened with an allen wrench to release the blade. There is also an allen head screw under the working surface which will have to be loosened to remove blade at the bottom. Replace blade at the bottom 1st, tighten up then go to the top, tighten it, then reset the tension and you're ready to saw again. Make sure to get a visual on the directions of the blade teeth before you remove it so you can replace the new one the same way. I hope this is helpful.
Sep 26, 2009 | Craftsman Saws
I bought a delta scroll saw model number 40-540, the blade was broken. I need to know how to change the blade and what type of blade the saw takes. Thank you
your delta scroll saw has two blade attachment points one under the table and one in the arm. attach under the table first and then in the arm. that way you can be sure to adjust the tension properly.
there are only two styles of scroll saw blade, those with pins and straight blades without pins
look carefully at your saw and you will be able to see which type holder you have
Sep 15, 2009 | Saws
May 21, 2009 | Craftsman 16" Variable Speed Scroll Saw
Need a owner manual for tradesman bench table saw model 8031
Mar 18, 2009 | Saws
Garden Logo
87 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
