Question about Frigidaire ATF6000ES Front Load Washer
Frigidaire front loading washer makes a clinking noise
My washer makes a noise when the tub agitates and spins. I took the top off and couldn't notice anything. When you turn it by hand you can hear a noise. It Washes and spins.
  • sharpshott18 Feb 18, 2009
    Can you post the exact part number for the seal? That would help me immensely, i have this same washer and bearing is bad, it was given to me this way so i'm going to try my hand at fixing it. not much to lose
  • becky1164 Feb 18, 2009
    when the washer goes into spin mode an alarmingly loud humming noise occurs, like an airplane. drum looks like it's spinning unevenly. although it is still washing and spinning the load, it makes me nervous to use it.
    Novelist:
    Champion:
  • 220 Answers
It sounds like your tub bearings are starting to go bad. Mine sounded like airplane taking off. Once the seal goes bad, water tends to migrate into the bearing cavity and flush the grease out of the bearings and then they wear quickly.
You have to completely remove the tub assembly to take it apart. Some say get a new washer, but I only paid $60 for the 2 bearings and a seal from a bearing house. They are even cheaper online.
You may as well try and fix it, worst case the junk yard doesn't care if it's in pieces when you bring it to them. I have no idea what an appliance repairman would charge to fix it.
If I remember right the seal is a 80mmx40mmx10mm metric seal. I found a rubber coated one from SKF I believe. The bearings should be 6306-2rs and 6307-2rs, but I would not buy anything till you have it apart. The bearings knock out easily.
INFO-Mine had -2z bearings installed which are only shielded bearings. The -2rs bearings hold up much better to water exposure in case the new seal leaks in the future.
If you want the exact seal part number, I can get it off my paperwork, Just write back.
I saw somewhere on an appliance blog that had step by step pictures of the procedure.
Posted on Jan 12, 2009
I have a top load fridgidaire washer model fwsc445rfs0. During the wash cycle it makes a high pitched scraping noise.... Struggles also while it winds down before rinse. Bearing maybe?
How To Fix A Washing Machine Making Noise During The ...
removeandreplace.com/.../washing-machine-making-noise-during-the-sp...
Jul 27, 2015 - Agitator directional cogs aka "agitator dogs" (top load washers) ... If you hear a rubbing sound or the drum spins uneven, then the ... A washer making a loud noise during spin cycle can also be caused ... The clutch in a washing machine connects the inner wash tub to the ..... May 8, 2015; High Water Bill?
Dishwasher Making Loud Grinding Noise During Wash Cycle
removeandreplace.com/.../dishwasher-making-loud-grinding-noise-durin...
Apr 11, 2014 - Dishwasher Making Loud Grinding Noise During Wash Cycle ... GE, Whirlpool, Frigidaire, KitchenAid, Maytag, Kenmore, and LG) this is a .... Our Amana dishwasher is making a loud, high-pitched squealing noise throughout the wash ....Out Of A Washing Machine - Top Load & Front Load September 30, ...
All comments on Loud dishwasher Frigidaire Gallery mode ...
https://www.youtube.com/all_comments?v=v-arYb20kOk
Dec 03, 2015 | Washing Machines
My Frigidaire FWT645RHSO front load washer sounds like a propeller airplane when it spins...HELP!
Robin, it sounds like the tub bearings may be going out on your machine. With the washer empty, reach inside at the top and gently lift the inner stainless steel tub. Does it move up and feel like there is some slop or play in the tub. If the bearings are tight, the inner tub will not move much at all independently of the complete outer tub assembly.
Have you noticed any grease on any clothes recently? Usually what happens is the water seal fails and the water eventually washes the grease out of the bearings and they fail.
Depending on your skill level, there are some good online blogs about tub bearing replacement. You may not want to deal with it. You have to make the call on that. Thats my 2 cents worth. Good luck.
Mar 19, 2014 | Frigidaire Washing Machines
It makes a loud noise when washing - it seems like the inner tub is sagging or something, when you open the door you can see the top rim of the tub. Is this fixable - and cost effective?
When my washer did that, I found that the shocks that hold the tub were bad...
Check out this tip I wrote about the noise and vibration that front load washers can make..
Washer Problems
Washer noise when spinning
heatman101
Feb 06, 2011 | Frigidaire FTF530FS Front Load Washer
My Frigidaire front load stacked washer/dryer makes a horrible noise and won't spin. It works perfectly except for the spin cycle
you need to remove the agitator take the cap off and remove the bolt from inside the agitator and then remove it look at the metal trunion in the bottom of the tub and see if there is a broken bolt holding the trunion to the shaft.there is a chance the transmission need to be replace if there is no broken bolt
Nov 03, 2010 | Frigidaire FEX831CS Top Load Stacked...
In spin cycle the tub had been making loud noise. Then there was a knocking the last time or two. Then it stopped spinning. The tube won't turn at all. Is this the bearing? Does the tub need to be...
Just had the same problem last night; I took off the back and noticed that the 'shock absorber' was broken. http://www.partstore.com/Part/Electrolux/Frigidaire/fwt449gfs1/Electrolux/Frigidaire/134564200/New.aspx
Not sure if the same part is broken on yours.
Oct 23, 2010 | Frigidaire GLTF1670A Front Load Washer
I have a Frigidaire GLTF2070DS Front Load Washer and during the spin cycle, it started making this horrific noise. I started another load of laundry and now it does not spin. What could be the problem?
Washer Problems Washer noise when spinning
heatman101
Sep 07, 2010 | Frigidaire GLTF2070DS Front Load Washer
Leaking from the bottom of the washer.
it sounds as if the main tub ring is bad you need to pull your agitator out and check the two blots that hold the tub to the shaft and make sure they have not become loose or broken causing the inner tub to drop on the shaft and tear the tub seal.
Feb 23, 2010 | Frigidaire Gallery GLWS1339EC Top Load...
Drum makes loud noise when spinning
HI thanks for the question. Frigidaire has a life time warranty. on that part .call them. thanks the appliance doc. please rate my answer. thanks.
Apr 29, 2008 | Frigidaire ATF6000ES Front Load Washer
My frigidare glws1233a top load
Do you have this noise when operating an empty machine ? It could be cause an unbalanced load of clothes. Stop the machine, redistribute the clothes and re-start the machine. In case you still have this noise, the problem is with the transmition between the drive motor and the inner tub. Good luck !
May 22, 2006 | Frigidaire GLWS1233A Top Load Washer
Frigidaire ATF6000ES Front Load Washer Logo
257 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
