Question about Toshiba Satellite A105 Notebook
Toshiba Satellite A105 left speaker high buzzing noise
It starts when I play music or Skype, and is still there when I put on headphones. It seems to go away at times for a day or so when I shut down and remove the battery pack, possibly.
The right speaker is fine and keeps on working, even when the left one acts up!
This is a 2 year old unit bought in the States.
Thanks, Francois
  • 2 more comments
  • francois599 Jan 13, 2009
    Hello Robert,
    Yes it does.
    Thanks, Francois
    Thanks, Francois
    Thanks. I did check this, and even in a middle of a park or by the pool, away from any power source or appliances, it will do it at times!!
  • francois599 Jan 20, 2009
    It still does it without the battery, at times only...
  • 827 Answers
You can replace the speakers without too much expense:
http://cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem&item=110320798636&cguid=ce3a19eb11e0a0aad3a52ce5ffa63243#ebayphotohosting
If you've installed the latest soundcard driver, I think this is your only solution, mate :(
Hope this helps
Chris (ziraffa)
Posted on Jan 13, 2009
  • chris grams
    chris grams Jan 13, 2009
    I think it is probably current feedback on the speaker's wire..
  • 177 Answers
Hello and Welcom to FixYa!,
It sounds like there may be a Faulty Spekare installed, Including a Loose Wire- It is also possible that There is an Interfering Object Nearby!
Contact Toshiba
  • Jackson Henney Jan 13, 2009
    If there are any problems-
    Thanks For Asking, --P3NGYJ03
    President:
  • 1,990 Answers
Welcome to Fixya! Driver Updates Could Help. Have you tried Magnetically Shielded Headphones? If not you should be able to locate a Loose Wire Connection to this Speaker inside the Unit. Just Solder it back on and you should be Good.
    Sergeant:
  • 366 Answers
Check if any source of electromagnetic interference is nearby.
transformers, fluorescent lamps, monitors can generate fields easily captured by audio device,
make this test: use in same area a radio am/fm with same earphone move around and check if sound if affected by same noise.
if you find the source then you can try to remove or to shield it
Posted on Jan 12, 2009
  • 43 Answers
It sounds like a error in the sound driver tryed to reinstall the driver?
Here you have some new drivers for your computer. hope they work
http://genericdrivers.bee.pl/windows-driver-printer18.html
  • Robbin Lundgren
    Robbin Lundgren Jan 12, 2009
    Remember to Rate... Ty
    Brigadier General:
  • 5,158 Answers
Does the headphone jack have a stereo plug on it ?
Robert
  • Roberta Smith
    Roberta Smith Jan 13, 2009
    it sounds like outside interference... and believe it or not the worst offender is a computer... do you operate it near a desktop computer.... the left speaker wires may not be as well shielded as the right.... or the item causing interference is on the left of the laptop.
    Robert
  • Roberta Smith
    is this issue still there when you run the computer without the battery... try that for abit... there may be a bad capacitor in the battery circuit.
    Robert
Sound coming through right headphone, but not through left. Sound also not coming through left speaker. Help?
are you adjusting sound through the windows controller or the application you're playing music through? there are a few things that could affect that, there's also the actual sound setup where you can change your setup i.e. surround sound, single speaker, headphones etc
Oct 02, 2013 | Toshiba Satellite Computers & Internet
Why are there random buzzing sounds coming from the speaker?
An easy step that you can take is to try to reinstall the drivers. Something may be conflicting with them which causes this effect. The other option is that the hardware may be failing.
Here is the driver page for your Toshiba laptop. Hopefully it is as simple as the drivers just needing an update!
Dec 07, 2011 | Toshiba Satellite L655-S5155 Laptop
I can't hear sound from my laptop even with the builtin speakers. It's a Toshiba Satellite A105-S4064.
On the front of the laptop there is a circular knob, play a music cd and then turn the knob from left to right and see if the sound comes back, if that doesn't work then make sure where the speaker is in the bottom right hand side of the screen click on it and make sure the volume is turned up.
If it still doesn't work then reload the sound drivers. At this point if the sound still won't work then that means that either the speakers or the motherboard is bad and you won't know for sure unless you replace the speakers first.
Nov 28, 2009 | Toshiba Satellite A105 Notebook
Buzzing noise when I talk
Do you have the Play n Charge Kit connected? It seems if you use that with the X1 at the same time, some kind of hum noise is transmitted through the USB bus power to the X1 headset, and you hear a buzz or high-pitched hum. The solution is to use the X1 without the Play n Charge Kit, and charge the controller when you're playing the sound through your TV instead of the headset.
Jun 29, 2009 | Voyetra Turtle Beach Turtle Beach Ear...
Headphones won't work when attached
try another headset, check headset switch off/ on
Jun 26, 2009 | Toshiba Satellite A105-S4274 Notebook
Cant hear sound on labtop
There is a volume control knob on the notebook itself.....sheck to see if this is not set to minimum...
keep me posted
Apr 08, 2009 | Toshiba Satellite A105 Notebook
Toshiba Notebook L315 Headphone Jack Problems
the sound socket on the motherboard was nearly damaged, the only way can fix it is replaced the socket on motherboard by componnet level technician, otherwise you have to use USB port to sound out...
Nov 14, 2008 | Toshiba Satellite A105 Notebook
Toshiba satellite laptop
Before going to any shops, here is a suggestion that can't hurt anything.
Go to the Control Panel and click on Sounds and Audio Devices. On the Volume tab at the bottom, you will see "Speaker Settings". Click on the Advanced button. Change that setting to "Stereo headphones". You should hear the sound only through the headphones then.
Feb 14, 2008 | Toshiba Satellite A105 Notebook
Sound is distorted like it is underwater.
It seems there is driver related issue. You may reinstall/update your driver. For further assistance please post your question.
Also can you please tell me whats your computer's part number and operating system?
Good Luck
Feb 05, 2008 | Toshiba Satellite A105 Notebook
Toshiba Satellite A105 Notebook Logo
55 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
