Question about Viking Designer Series DFUD140 (Ultra-Premium) Built-in Dishwasher
Every light on display is flashing on a viking dfud140 dishwasher
Its flashing back and forth between the cycle side and the option side
  • 205 Answers
SOURCE: viking dishwasher quit working
Possible bad door switch, thermostat or timer issue, call for service, make sure the tech. knows how to fix Asko dishwashers as that is what is in on the inside. Be sure that you are getting power to the unit.
Posted on Jul 21, 2008
tipstir
  • 67 Answers
SOURCE: Viking Dishwasher won't start. All the lights continue blinking and it sounds as if a motor is continually running.
What had changed since you last use it? Prior day? Also when last did you clean out the filters for it?
1. Drain Pump
2. Block Drain (blocked or kinked)
3. Valve Leakage
The electronic display has detected a sensor fault on the unit for the flashing you see. Check the filters and drain pump. Make sure nothing is clog also the line where the hot water goes to it. I know you said you have it under protection for 5 years and that's up right so some parts might need to be replace. If you go down to your main breaker for the unit you can trip it off and on and see if that clears it up but I you might have a serious problem with it.
Now you got 2 options.
1. Call up Viking and get an estimate of how much it will cost to repair the damage.
2. If the cost is greater than buying a brand new one then, better off getting another one then. If not then get it repaired.
Posted on Jul 31, 2008
SOURCE: Dishwasher will not start
you can hold the start atop button down for 5 seconds to re set it or you can turn off the circuit breaker to the dishwasher for 20 sec. That should help. If not, it probably is a bad celenoid which a repairman needs to replace
Posted on Nov 19, 2008
  • 552 Answers
SOURCE: My dishwasher won't start or
Very common issue on this unit, unplug for 30 seconds if the light still flashes replace the touch pad to fix the problem.
Let me know,
http://www.appliancerepairlesson.com/
Posted on Mar 07, 2011
KevinWhite
  • 1902 Answers
SOURCE: Viking Dishwasher VDB450SS Unit appears
Hello & Welcome to FixYa
Check the door latch switch mechanism as that seems to be bad and needs replacement as everything else is working fine. Please get back to me if you have any other questions.
Kevin
Posted on Jun 18, 2011
Problem with my Viking DFUD140 dishwasher
There is no economic sense to repairing a 13-year-old dishwasher.
Apr 06, 2017 | Dishwashers
Cycle control lights flashing all at same time
are you sure you have cleaned all the water outlets as when these get blocked and the water builds up the dishwash will go into a standby mode as a sefety precaution to stop your kitchen getting flooded if it was me i would take off all water outlet pipes and use boiling water and a good cleaning fluid it only takes a little blockage and then it will cut off so clean all pipes through properly and then try again is the water going into the dish washer before it cuts off or is their no water going into it either if you post back ill have a nother look for you hope this is some help i had same prob with mine but it was different brand of washer but after cleaning all pipes inlet and outlet it worked fine and is still working now use good limescale remover cause if you live in hard water area then this is probably you problem .......................................................
Nov 10, 2007 | Viking 24 in. Professional Series DFUD140...
Motor keeps running and we can't operate the dishwasher
Look for water accumulating under the dishwasher. It has a tray that will catch any leaking water before it gets to your floor. If this is the case the most likely cause for the leak is the drain hose (located behind the main pump housing).
Jan 12, 2011 | Viking 24 in. Professional Series DFUD140...
No water, sounds normal . might be silenoid switch on inlet valve? vud140 viking dw
could be the water valve silenoid connection clip to the power source has been disconnected, 2) water valve is clogged with debris, 3) water valve silenoid has gone bad. I think one of these three things may be your problem. Good Luck
Dave
Aug 07, 2009 | Viking Designer Series DFUD140...
Nov 17, 2008 | Viking 24 in. Professional Series DFUD140...
Condensation
Turns out the vent was obstructed. Re-positioned the custom-fit door and problem solved.
Sep 30, 2008 | Viking 24 in. Professional Series DFUD140...
Kenmore Dishwasher #15769
Try this solution first
Push the Hi-temp and then push the Sani-rinse. Go back and forth multiple times on these two buttons. I found that after a handfull of pushes that a "1" came up on the display. I continued to keep rotating the two buttons and then a "2" came up on the display and the dishwater started it's "drain" phase. I then hit cancel to clear and then I selected the cycle I wanted. The washer started up just as normal at this point.
Feb 16, 2008 | Kenmore 15769 Built-in Dishwasher
Viking Designer Series DFUD140 (Ultra-Premium) Built-in Dishwasher Logo
23 people viewed this question
Top Viking Dishwashers Experts
Mike
Don Kahr
Don Kahr
Level 1 Expert
Rick Gloria Malmoe
Rick Gloria Malmoe
Are you a Viking Dishwasher Expert? Answer questions, earn points and help others
