Question about Phil & Teds E3 Jogger
Back child undoes seat clips on my phill and ted
The child in the back of my phill and ted keeps undoing the seat clips and therefore reclining the front child, much to thier anoyance.
Tried covering the clips with the shoulder pads you put on the straps for a new born but they just took these off. any suggestions
5 Suggested Answers
SOURCE: Phill and Ted pram hood hard to put back in place
I have the same problem with a Phil and Ted's Sport - but I believe I have the solution as below. This is taken straight from the Instruction Manual which you can view at: http://www.arango-design.com/Phil-Teds-Sport-Buggy-p/7890-0001.htm - towards bottom of page is a link to the instruction manual - which I was unable to get on the Phil and Teds website. Got this today but haven't tried it yet. Hope this helps.
Really becomes clear when you see the pictures in the instruction manual.
Regards, John
Hood
The sport hood is packed disconnected.
To reconnect:
1. Locate sun hood and hold it facing down, as shown ‘a’.
2. Insert crimped wire ends into frame, through eyelets, ‘b’.
3. Lay hood back (to top of buggy).
4. Locate red coloured pocket at top of fabric seat and insert rear hood wires into each side, ‘c’ and ‘d’.
5.Open hood and attach domes, at bottom of hood, to main seat, ‘e’.
6. Pull eyelet at top of hood over pegs on each side of frame, ‘f’
Note that the windows in the hood are lined with a sun mesh of
a lower shade factor than buggy fabric. Always use sun cream
and clothing for protection of children in direct sunlight.
Posted on Jan 29, 2009
SOURCE: replacement covers for black and grey phil and teds
Hello there, I can get these for you (if you haven't got them already). The full set is £108.00, and the bumper bar cover is £7. P&P is £4.95
If you're interested please email me on elizabeth.higgs@mooshmedia.com
Thanks very much.
Posted on May 27, 2009
SOURCE: how do i take the main seat cover off my phil and ted sport
you have to undo the 2screws each side to remove handle, and there are 2 screws on each side near footrest to undo. then it should slide upp the frame and off where the handle bar connects. sounds more complicated than it is should take about 10-15min. then the whole seat can go in the wash.
Posted on Jun 13, 2009
  • 419 Answers
SOURCE: where can i get a replacement shoulder strap clip
If you contact www.johnstonprams.co.uk you will be able to contact them to purchase this part.
Hope this helps.
Posted on Apr 03, 2010
How do I undo the clip which fits into the car restraint point behind the back passenger seat
usually these things have a plastic tab that has to be pressed down to release the clip from the anchoring point bolt
Feb 20, 2015 | Baby Gear
How to remove electric drivers seat 2008 buick lucerne
There will be 4 bolts holding the seat to the floor of the car. They will have plastic trim pieces covering the bolts. You will need to move the seat all the way back to get to the front 2, and all the way forward to get to the rear ones. You will need to undo the wire connectors and free the seat belt base to remove the seat.
Aug 03, 2014 | 2008 Buick Lucerne
I don't know how to remove the seat to get to the batteries?
Under the seat there are 4 retaining clips connected to the trapeze bars (the bars going across in the front and back) Undo the clips and lift the seat off (make sure you don't grab by the armrests) Release the shroud fasteners at the back and take the shroud off. You will now have access to the batteries.
Feb 25, 2011 | Jet 3 Ultra Power Chair
How do i open the back seat of my pontiac g5 to get into the trunk?
This is easy. Get a friend, you need a little help. grab hold of the bottom seat by slipping your hands in the crease. Lift it up. The seat will lift up towards you. There are some clips on the bottom. of the seat, slide the seat off the clips and take the seat out of the car. Most backs have bolts holding the back in place. Undo the bolts, and lift the seat off the top clips,, and remove from the car. Goes back the way it came out.
Dec 26, 2010 | 2008 Pontiac G5
Britax vigour removing the seat to clean, how do I do it? Confused with how to get it off the seat reclining lever
Its like a bike brake cable. It was fiddly, but we managed it. If you get stuck, try taking it to a local bike shop who could undo it for you.
Aug 28, 2010 | Britax Vigour Standard Stroller
I need to set up the pram for a toddler and new born and have lost the manual
You will need to recline the main seat unit fully (undo the zips on the inside of the seat unit) and attach the toddler seat on top (with two right angled connectors put into the slots where the bumper bar clicks).
With this setting, you will be able to use this for a toddler and newborn.
I hope this helps.
Oct 28, 2009 | Phil & Teds E3 Jogger
CAN YOU MANUALLY RECLINE A POWER SEAT THAT IS STUCK
only 4 bolts hold the seat in they may have a plastic cover on them that can be popped off with a screwdriver.remove the bolts and lean the seat back check the wires going to the motor and make sure it has power going to it.Don't know of any way to manually recline the seat without taking it apart.
Jun 07, 2009 | 2002 Nissan Maxima
How do i take the main seat cover off my phil and ted sport
May 29, 2009 | Phil & Teds E3 Twin Seat Jogger
Emmaljunga toddler seat
You can not get a manual any more as they are not made. They are releasing a new seat in Feb 2010. This works in an identical way so I have been told. I have the old seat. It is easy to understand how it is fixed, but I would have a strong man to help, it can be tough.
Step 1 : locate bumper bar and with an alan key undo the two black clips either side that hold it together. Remove bumper bar from pram, Keep the two clips on the pram with the opening facing up.
Step 2 : With your toddler seat you should have another two of these black clips, place these two on the pram in the same way, but as far forward as they will go.
Step 3 : On your seat either side of the black knob that reclines the seat you will find two holes, simply place the seat lined up with the clips, put the screws with the clips threw the clips and the holes in the seat place, put the other side of the screw on and tighten. Thats it seat on.
Aug 02, 2008 | Baby Gear
Phil & Teds E3 Jogger Logo
65 people viewed this question
Top Phil & Teds Baby Gear Experts
Jennifer Rock
Jennifer Rock
ray gallant
Dorel UK
Dorel UK
Are you a Phil & Teds Baby Gear Expert? Answer questions, earn points and help others
