Question about Hobart Welding Tools
Hobart plasma cutter250ci cuts then i stop it wont start up again till i turn it off and on and then wont run
5 Suggested Answers
johnr1959
  • 56 Answers
SOURCE: plasma cutter wont cut steady
Is your air compressor able to keep up with the continuous regulated air flow?
If positive air flow is not constant same pressure all the time
cutting will stop..>>
Also if your movements are to fast and or material to thick machine will behave that way..
Posted on Jan 30, 2009
SOURCE: miller plasma cutter stops cuttingafter a few seconds
the cutter probably has a built in current monitor. that trips out then resets itself. try a lower current.
Posted on Mar 24, 2009
buffalonyman
  • 1865 Answers
SOURCE: Plasma cutter only cuts for only a few seconds
The unit needs to be tested.
You're welcome to ship the unit to me for diagnostic testing and repair. info@taeckertindustries.com
Posted on Nov 07, 2009
SOURCE: Would you purchase the 400
It's all about duration. How much metal do you need to cut continuously. Although the 400 will cut a similar spec it won't hold out as long. So if it;s lots of short cuts the 400 is fine, if you need to cut thicker gauge for longer period go 500.
Posted on Aug 16, 2011
Would you purchase the 400 hobart or go to 500 hobart plasma they seem to cut the same thickness on the metal chart..
Aug 16, 2011 | Airforce HOBART AIRFORCE 400 PLASMA CUTTER...
Only cuts for 3 seconds, device still on
Possibly an internal short in the torch tip... the expendable components failing in the tip will cause the sensors in the machine to register a "no cut" or "free air arc" state and kill the power to the tip to prevent damage to the unit. Replace the tip components and double check the grounds connections.
Apr 03, 2010 | Hobart Airforce 250ci Light Weight Plasma...
My Hobart 250 airforce doesn't start
On the main circuit board for the power supply, there is usually a thermal fuse installed, its a sealed unit and is not servicible, look for a black epoxied case,approx 3/8x3/4 long, with 2 leads coming out of it. Inside is a set of bi-metal contact points which serves as an over voltage/over current protection. These contacts deform/corode over time and it sounds like there not contacting properly. As soon as you try to load the machine, the current passing through this high resistance heats these contacts up, and shuts off power to the unit. I am not familiar with the guts of a hypertherm, but have extensive experiance repairing inverter based plasma cutting equipment, and i have encountered this before. I assume hypertherm must have some equivelent to this thermal switch inside the power supply.....Good luck..
Dec 29, 2009 | Miller Hobart AirForce 250A Plasma Cutter ...
Hobart airforce 250 ci has power but will not operate
make sure that there is air to the plasma and set at the proper psi. Make sure that the contact tip and nozzle is in the cutting head correct.
Dec 18, 2009 | Hobart Airforce 250ci Plasma Cutter 12...
Nov 07, 2009 | Airforce Welding Tools
Plasma cutter wont cut steady
Jan 22, 2009 | Hobart Welding Tools
Hobart 250 a keeps cutting off the flame
If you have a bad air supply then the moisture in the air will cause the torch to cut off and the cut quality depends also on air supply,speed,metal thickness and condition of your consumables,meaning your electrode and other related parts in the torch tip.Hope this helps
Jan 05, 2009 | Miller Hobart AirForce 250A Plasma Cutter ...
Hobart M-802 mixer
Your overloading the mixer with too much product or not enough water,cut the batch down,the motor protection board is doing its job by shutting off.
Aug 06, 2008 | Hobart Food Mixers
Welding Tools Logo
56 people viewed this question
Top Hobart Welding Tools Experts
Matt Olenzek
Matt Olenzek
oneStan
oneStan
Are you a Hobart Welding Tool Expert? Answer questions, earn points and help others
