Mission parts available from [email protected]
SOURCE: Need to Replace the drivers on Mission 782 speakers.
Unless the company that made the speakers machined the allen screws themselfs, I'm sure any standard or metric allen set will work. Just becareful of the bracket because it may be glued to the speaker frame or there might be a gasket between the 2.
There will be a some wires coming from the crossover that will lead to the tweeters and to the woofer. They are terminated with female connectors that will slide on to the male end on the speakers. If the speakers that you are getting are from the same manufacture, then they should have the same fittings. If not, you may have to replace the females to match. It's a simple strip and crimp process.
Just make sure to mark the wires so you know which one is pos and neg. If you mix them it will throw your speakers out of phase and they won't sound right.
Hope this helps.
SOURCE: recently one of my mission
Drivers are easy to replace in most speaker systems. There will be 'spade' type push-on connectors to the drivers. Here are contact details for the Mission service centre in the UK: http://www.mission.co.uk/Distributor.aspx?lang=En&Tab=29 They should be able to supply you with a replacement.
SOURCE: I have this mission 782 for many years! It happen
It's bi-wireable (BUY-wire). Did it occur to you that may be a factor if you're using it that way? The jumpers (or lack thereof) on the back allow or disallow the amp(s) to affect all the drivers. You can tie any amp to one or the other pair of binding posts to test them.
SOURCE: Replacement base soeaker for mission 782
I have the same problem too, can anyone know where we can get a replacement of the woofer?
