Question about TallyGenicom 8008 Laser Printer
T8008 printer with message says "replace fuser"
Hi i have T8008 printer and i got a message says "replace fuser" which means to replace the fuser unit infact the printer is working well so is there a solution to fix this problem without replacing the fuser unit??
    Novelist:
  • 169 Answers
The 'Replace Fuser' message on the 8008 can be cleared in the following way;
• Power the printer Off
• Hold down FORM FEED and ENTER and power the printer on
Keep the FORM FEED and ENTER keys held down until the printer displays SERVICE MENU - INFORMATION
• Press the RIGHT ARROW to MAINTENANCE, and press ENTER
• The Display should read MAINTENANCE - CLEAR FUSER, if it does not press the right arrow until it does and then press MENU/ENTER
• The Display Should now Read CLEAR FUSER NOT EXECUTE, Press the right arrow until the display reads CLEAR FUSER EXECUTE
• Press ENTER, and after a pause the display should read COMPLETED CLEAR FUSER
• Power the printer off and after about 10-15 seconds power the printer back on again.
The message should now be cleared
Posted on Dec 14, 2009
E300 error message
Hi Good day!! It may be the fuser problem. u may need to replace the fuser or buy a new unit.
Nov 19, 2010 | Canon imageCLASS D340 All-In-One Laser...
We are getting this message on the printer: 50.2 Fuser Error do we need to replace?
Your problem is in the fuser. 50.2 means the fuser is not reaching temerature properly in the allotted time. It either has a burned out ceramic heating element or thermistor (hi/low thermometer). Replacing will fix.
Apr 27, 2010 | HP LaserJet 5100tn Printer
What is error code E000 mean
Solution:
Press "Additional Functions",
Press "#", then press the "Right Arrow" button till it says, "Printer",
Then press "Set" then press the "Right Arrow" button again until it says "Printer Reset"
Then press "Set" again, the display will ask you "Yes" or "No".
Press the "Left" arrow for "Yes", then press "Set".
Now, unplug the power cord and wait 5 seconds and plug back in.
If this don't work, get a new fuser.
Feb 04, 2010 | Canon imageCLASS D880 All-In-One Laser...
HP Color LaserJet 2840 keeps showing 50.2 Fuser error message. Nothing helps correct problem. What to do? Have tried repeatedly turning printer off, waiting several seconds and turning on again. Each time...
The fuser is the heating unit near the paper exit, and that error means the lamp is burned out, the overtemp sensor is out, or the thermistor in the fuser is bad. About all you can do is replace the fuser. www.precisionroller.com will have a new fuser for you.
Jan 12, 2010 | HP LaserJet 2840 All-In-One Printer
Error message 50.2 fuser error
50.2 just means that either the thermistor or the lamp has gone out on the fuser. You can buy parts and fix the fuser, or just replace the entire unit.
Aug 10, 2009 | Office Equipment & Supplies
WORN FUSER? WHAT DOES THIS MEAN PLEASE
that means there is a fuser unit back side of u r printer this is the main unit where printing happens actually. I think there may be problem with fuser unit...may be paper jam or sensor problem..replace the fuser unit
Jul 06, 2009 | Epson Aculaser C1100 Printer
Error message 0500h
Your fuser is not warming up. You will need a technician to look at it.
Mar 16, 2009 | Konica Minolta magicolor 5430 DL Laser...
Fuser temp error
To test fuser out of circuit make sure lamp and thermal fuse are not open circuit, and thermister is neither open or shorted
Fuser repair procedure from tec manual.
Fuser Failure (U4-1, U4-2, & U4-3)
Switch off printer main power. Remove the Fuser Full Cover so you can observe the Heat Rods. Switch on printer main power and observe the ends of the Fuser Assembly. The Heat Rods glow.?
Y N
Go to step 5.
2 Replace the Printer Engine Controller PWB (REP 4.10.6). The error message reappears.
Y N
Problem solved.
3 Replace the Fuser Assembly The error message reappears.
Y N
Problem solved.
4 Check for a broken wire or a loose connection
between components
5 Measure the AC voltage between J23-2 and J23-6 on the AC Driver PWB. There is 110VAC (or 220VAC if the printer is the 220VAC model) between J23-2 and J23-6.
Y N
Go to step 7.
6 Replace the Fuser Assembly (REP 4.7.1). If the problem persists, replace the Printer Engine
7 The Fuser cycles up and down.
Y N
8 Measure the voltage between P401-1 and P 401-4 when the Fuser Fan cycles up and down. There is 24VDC between P401-1 and P401-4 when the fan is rotating and 0VDC when the fan is off.?
Y N
9 Replace the AC Driver PWB
Please rate solution to your question "How can I check that new Fuser unit is ok?"
Jan 10, 2008 | Xerox DocuPrint N32 Laser Printer
Printer HP ColorLaserJet displays Fuser Error
My HP Color Laserjet 2600n Printer is giving me error as
" 50.2 Fuser error " . then every time i have to reatart my printer.
please give me suggestion.
thanks and regards.
ajinmumbai
Dec 05, 2007 | HP Color LaserJet 2600n Printer
Engine Fuser Low Heat Error
HI, Yes it definitly sounds like your fuser is not getting to the proper temp. I would call Samsung and have this printer repaired or sent back. If you purchased it recently your warranty should be available. Hope this helps!! Thanks
Dec 04, 2007 | Samsung CLP-600N Laser Printer
TallyGenicom 8008 Laser Printer Logo
167 people viewed this question
Top TallyGenicom Office Equipment & Supplies Experts
Kolbrun...
Raj Patel
Are you a TallyGenicom Office Equipment and Supply Expert? Answer questions, earn points and help others
