Question about GE Spacemaker JVM1740 Microwave Oven
Whirlpool mt4155 microwave does not heat food
All lights and power on and sounds normal
SOURCE: GE Over range microwave, JVM1660
It happened to me too. Thanks for the part #.
Posted on Feb 12, 2008
SDZAKKMF
  • 50 Answers
SOURCE: my microwave doesnt work
The radiation module built into the microwave has burnt out. The way a microwave works is that the radiation module produces radio waves that make the molecules in your food speed up, and the kinetic energy in the food makes it warm. The sound you hear is a fan cooling off the module and the light is just so you can check the food. Because of the nature of the module, it cannot be replaced and the entire machince needs to be replaced.
Posted on Mar 08, 2008
  • 18 Answers
SOURCE: Microwave not heating food and is making loud noise.
You have burned out the magnatron (heating element) which is common on GE microwaves. most service companies will charge about 200-250 to replace it
Posted on Jan 31, 2009
localwonder
  • 6784 Answers
SOURCE: turns on but not heating food sounds a bit louder
Hi, this is common in most microwaves. this abnormal noise is coming from a faulty Magnetron. this device is responsible for the heating process and, it is damaged and not heating at all at this point.Simply replace the Magnetron and, this unit will start to heat once more.
Posted on Jun 01, 2009
mosekha
  • 23 Answers
SOURCE: My microwave starts however food does not heat up.
Micro wave as the name suggests produces heat when the micro waves aimed at an object causes the water molecules inside the object to vibrate hence producing heat.The gadget responsible is the magnetron. If your magnetron is not receiving ht voltage or receiving but faulty, then your micro wave wont work please take precaution when opening micro wave due to high voltage caps that remain charged sometimes even when it is off.check the high voltage fuse/ diode and capacitor if they are fine and the step up trans former o.k then the only option is to replace the magnetron
Posted on Aug 02, 2010
When microwave is started, why does it make a loud buzzing sound--like a Skil saw sounds?
Whirlpool Microwave Buzzing Loudly - ApplianceBlog
www.applianceblog.com/.../26531-Whirlpool-Microwave-Buzzing-Loud...
Aug 12, 2011 - 10 posts - ‎2 authors
My Whirlpool MT4155SPS-2 microwave oven has recently started to buzz loudlywhen operated. The sound is getting louder and more frequent ...
Whirlpool making intermittent loud buzzing noise Microwave ...
www.fixya.com > ... > Microwave Ovens
Whirlpool microwave ovens making intermittent loud buzzing noise related questions and answers. Ask your ... ...loud buzzing noise and it doesn't heat. i just tried it again and let it run for 1 minute. ... Question about Accuwave Microwave Oven.
Troubleshooting the Microwave: Potential Problems ...
www.appliancejournal.com/.../troubleshooting-the-microwave-potential-...
If your microwave buzzes loudly and produces no heat you probably have a defective power .... I have a whirlpool oven range and it's less than a year old. .... Humming sound stops when I open door to remove food, but when door is closed, ...
Whirlpool Microwave Ovens - Consumer Affairs
Feb 03, 2016 | Whirlpool Accuwave Microwave Oven
Whirlpool microwave have power, not heating up food or water
The problem is most likely the magnetron, or the inverter board, "7years old or less" and possibily the keypad control board.
May 02, 2012 | Whirlpool Microwave Ovens
Mu accuwaave makes a short noise intermittenly while trying to heat
Is your microwave oven set to full power when the intermittent noise occurs?
If it's set to a lower power rating, then the noise you describe sounds perfectly normal.
At a lower power setting, the device which creates the heat or microwaves, called the magnetron, switches on and off intermittently so that the food etc. is not cooked too fast.
This is quite normal & you should only be concerned if the noise occurs while the microwave oven is set to full power.
In that case you will have to have it checked out to see what the cause is.
Best wishes,
Graemevm
Mar 24, 2011 | Whirlpool Accuwave Microwave Oven
Does not heat up food everything else is OK i think that the rack touch the door when i was using it
Double check and make sure that the rack did't scratch the paint inside the cavity. Could be two possible reasons for it not to heat. Could possible be the magnetron or the diode. Normal when the magnetron goes bad, the microwave will still sound almost normal, bit just wouldn't heat. when the diode goes bad the microwave tends to make a humming sound when turned on
Feb 12, 2011 | Whirlpool MH3184XP Microwave Oven
Whirlpool model number MH7140XFB no longer heats
you either need a new h.v. capacitor or h.v. diode in the magnetron circuitry if you cant hear it cycle when it runs as in a low pitched hummmm when its drawing current to operate the magnetron tube, each part runs about $30 to $45 each,normally its the h.v. capacitor though
Jul 28, 2010 | Whirlpool MH7140XF Microwave Oven
Whirlpool MH1160XSQ-1 microwave oven will not heat
all microwaves have a magenetron which produces the heat. if this is gone and it is not under warranty, it is not cost effective to repair. check you manual, most mag's have a 3 - 5 year warranty.
Nov 07, 2009 | Microwave Ovens
The microwave stopped heating the food. Power
The light inside the micro wave needs to be replaced most have a door on the back side that yo can remove the screw and unscrew the bulb and take to a applince shop and purchance a new one to replace.
Jul 16, 2009 | Whirlpool GH4155XP Microwave Oven
Have GE JVM2050 over the range microwave, which stopped heating food and water since this morning. All other functions including light, key pad, clock, turntable work normal. The magnetron sound also
if everything works except the heating, it is most likely the mag tube is on its way out.........that is the most common reason for it not too cook.......since the microwave is a GE and it is 3.5 years old, i would say you are better off buying a new microwave, the mag tube starts at around $70.00 and up + the labor it costs too have a service person put it in........around another $60.00
May 02, 2009 | GE JVM2050 Microwave Oven
HI. I have a Whirlpool Microwave (MH6141XKB). It will not reheat the food and makes a louder "humming" sound than normal. Other than that, everything works fine. Please advise. Brent
Brent
The magnatron in your oven has gone out and will need replaced!( This is the device that heats up your food) If everything is working and your food is not getting hot 99.9 percent of the time its the Magnatron or its fuse! The loud humming is also a big clue the MAGNATRON has gone bad!
Please rate this response and help us keep this area free!
Thank You!
Jan 21, 2009 | Whirlpool MH6141XK Microwave Oven
GE Spacemaker JVM1740 Microwave Oven Logo
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
D. E. Hev
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
