Question about GE Profile PFSF5NJW
Ge profile pfss5njw refrigerator is frezing up all the food and drinks
  • 531 Answers
SOURCE: GE profile side by side refrigerator door won't close
if you took out the door for the refrigerator to put in your house thats were your problem or gasket have to change
Posted on Apr 01, 2009
  • 531 Answers
SOURCE: Refrigerator not keeping food cold
you may have defrost problem
Posted on Apr 06, 2009
  • 351 Answers
SOURCE: Ge Profile ice maker not working
you either have a bad water valve, which it is sticking open or B. the ice maker is not shutting the valve off.
Posted on Apr 19, 2009
aasc
  • 1606 Answers
SOURCE: where is the thermostat on a GE profile refrigerator Side-by-Side
There is no thermostat ( cold control ) on your model refrigerator . It works off thermistors ( 3 in the refrig section and 2 in the freezer section ) . These thermistors , operate by the coldness which in turn , less resistance to the main control board the colder or warmer it will provide .
Posted on Sep 12, 2009
  • 1891 Answers
SOURCE: GE Profile Refrigerator defrost cycle last hours
it;s probably not going through the defrost cycle or its getting stuck in defrost .. on the back of frig the is a metal cover plate . in side you will find the main board . replace it . it runs the compressor and defrost and controls tempt . this is a very common problem . the new boards are better . and they cost a litle more . mm hope this helped / feed back pls .
Posted on Feb 04, 2010
Manual for GE profile pfss5njw/pfsf5njw for setting temp.controls.
Most GE appliance manuals are available through their support site: http://www.geappliances.com/ge/service-and-support/literature.htm. The manuals for the PFSS5NJW and PFSF5NJW are here: http://products.geappliances.com/appliance/gea-literature-search?Ntt=pfss5njw&x=0&y=0 . The direct link to the Use and Care Manual is currently http://products.geappliances.com/MarketingObjectRetrieval/Dispatcher?RequestType=PDF&Name=49-60489-2.pdf .
To change the temperature setting for the refrigerator, press and release the appropriate Warmer or Colder touch pad. Press several times to reach the desired temperature setting. (The freezer control is on the left.) Note: As you cycle through the temperature settings, it is possible to set the cooling to OFF. See page 4 of the manual to see these directions.
I hope this helps.
May 23, 2017 | GE Refrigerators
Unit icemaker wont make ice cubes or is slow to make cubes
The thermostat that cycles the icemaker is not working. Or freezer temp is not cold as it could be. Try setting freezer setting to E and fresh food to 8. Make sure not to have anything that freeze real easy on top shelf. Put can drinks on this shelf or pickles. I hope this helps.
Aug 23, 2011 | GE Profile 26.6 cu. ft. Side-by-Side...
REFRIGERATOR SIDE TO COLD,FOOD AND DRINKS GET FROZEN
There can be many reasons why your refrigerator is freezing your food. To see what could be happening and to figure out how to possibly fix your problem. Take a look at this tip which contains many of the causes and solutions to fix the problems.
Refrigerator is Too Cold and Freezing Food
heatman101
Dec 12, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
GE profile side by side is freezing fresh food and not cooling items on top 2 shelves
ge profile side by side is freezing fresh food and not cooling items on the top 2 shelves
May 02, 2010 | GE Profile PSW26P Stainless Steel Side by...
GE Profile side by side frig freezing food
Most likely air damper brooken and not
Regulating air from freezer
Mar 03, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
GE Profile Side-by-Side Refrigerator gets to too cold
turn the temp setting up to40 then check in a couple of hrs
Nov 20, 2009 | GE Profile 26.6 cu. ft. Side-by-Side...
My GE Profile fridge side isn't staying cold, but the freezer is. There is no thick frost built up in back of the freezer side so I know it isn't the defrost heater. Could it be dirty coils underneath the...
There are a couple of things that can cause this. Thermistors, mainboard, fan and damper.
Start with the cheapest.
1. Check Thermistors - Pull J1 and check connector pins 1,2,3 and 4 to pin 5. They should beapproximately 15Kohms. In your case, the freezer thermistors (pin 3 and4 ) should be higher than the fresh food (pins 1 and 2).
2. Fan and Damper - Fresh food fan should be on and damper from freezer to fresh food should be open. If not, check that fans spin by hand and damper doesn't look damaged
3. At this point it is most likely the motherboard.
http://www.fixyourboard.com/techzone/refrigerators/ge_fridge_warm/warmflow.html
Oct 07, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Frige not cooling
The GE Profile is a complex but efficient refrigerator. We will need to check a few things like the evaporator, defrost element, defrost thermostat and the mother board. Let me know if you want me to go through this with you, Thanks, Sea Breeze
http://servicepartstec.blogspot.com/
http://appliancepartsandtechnicalservices.blogspot.com/
Jun 16, 2009 | GE Profile 26.6 cu. ft. Side-by-Side...
GE side by side not working
Defrost cycle not functioning. Could be defrost timer, timer motor, or defrost heater. I detailed this for someone else. see other solutions.
Nov 05, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
GE Profile  PFSF5NJW Logo
59 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
Gene Tuck
