Question about Refrigerators
R134a. Standard-Automatic Defrost Top Freezer-Models. Just stops.
Hi, My name is Eileen. This freezer just stops all the time and I loose all my food. You can hear things running and the light comes on inside but nothing is cold or frozen on top or bottom. I pulled it out of it's spot and hit the round metal thing at the back and something started up. But I cant keep doing that of trust that. Can you please help me.
  • Thomas F. Schneider May 11, 2010
    Sound like the defrost time is stopping and you are hitting it to make it go again./Either replace the defrost timer or oil the motor bearing on the clock timer. .
  • 159 Answers
SOURCE: ice build up in back section of a Whirlpool no frost top freezer refrigerator 66"hx30"wx27"d
your sure the defrost cycle works? sounds to me its not. you need to remove the freezer back and check the defrost components. or put it in the defrost cycle and see if it is working. to get that much frost as you describe the dor would have to be left open. also check all door seals. let me know what you find and we can go from there
Posted on Aug 10, 2007
  • 1122 Answers
SOURCE: Hotpoint top freezer HTS18GBMBRWW
CHECK FREEZER FAN,CHECK FREEZER DRIAN IN BACK OF FREEZER IS NOT FROZE,CHECK DEFROST TIMER TURN CLOCKWISE TILL CLICK FAN SHOULD COME ON,THANKS-MIKE
Posted on May 29, 2008
  • 1122 Answers
SOURCE: Freezer cold but things not frozen -frosting up. Fridge warm.
most of the time on ge its the defrost heater or defrost sensor in the freezer,that's why its freezing up.you can go to sears .com click on prats put in your modeal number and get yours parts-mike
Posted on Nov 30, 2008
rpbuice
  • 161 Answers
SOURCE: GE Profile Stainless Steel Top Freezer Refrigerator
Check the compressor.
Unplug for 15-20 min. plug it back in and listen for the compressor to start. You will have to be behind the ref to listen and make sure you hear the compressor start and not just a fan running. If you hear a clicking noise then the compressor relay is bad.
Posted on Dec 17, 2008
  • 118 Answers
SOURCE: admiral fridge, freezer won't stay cold
Check the condenser fan, listen and see if it kicks on, if it doesn't then find someone that know how to take it apart and change them.
Posted on Jan 31, 2009
Top shelves in freezer not freezing food. Also no ice from ice maker. Seems cold air has stopped coming out of top vent
We had the same problem with our refrigerator just yesterday. Defrosting (even tho frost-free) cleared up the airflow problem-- If it's frost-free, when it defrosts enough to allow air flow, the automatic defrost can take over. Cause was stored food blocking the vent between the freezer and lower part of fridge.
Mar 02, 2013 | Freezers
Maytag mtb2156de freezer leaking through the top of the frig. The freezer is keeping things frozen, but water is running onto the floor.
That water is from the melting frost of the automatic defrost cycle. Their is drain in the freezer behind the back wall under the evaperator coil that is blocked, so instead of defrost water draining it's pooling in the freezer or in some case espically on models with the freezer on the top,the water is leaking from the freezer vents into the fresh food compartment.
The way to clear the drain is remove back plate and remove all ice build up and GENTLY make a small hole in drain through then totally flush w/warm water.
The exact location of drain is under the coil behind back freezer plate in the center
Aug 28, 2011 | Maytag MTB2156GES Top Freezer Refrigerator
Water is leaking from under the freezer compartment onto the top shelve of my whirlpool refrigerator
Good luck,
Gene
Aug 10, 2011 | Whirlpool Refrigerators
Water dripping from Funny looking . unit in ceiling of refer
The way to clear the drain is remove back plate and remove all ice build up and GENTLY make a small hole in drain, then totally flush w/warm water.
Good luck
I hope this helps you to stop that leak,
Gene
Aug 09, 2011 | Frigidaire FRT15B3A Top Freezer...
I have a Kenmore Coldspot Model 106.70182000 that is leaking water from the freezer into the refrigerator. Any ideas? Thanks!
Good luck
Gene
Aug 08, 2011 | Refrigerators
When it defrosts the water comes into the refrigerator on the top shelf
I hope this helps
Gene
Aug 03, 2011 | Refrigerators
Water is leaking into teferagerator, seemingly from the freezer compartment. It is a Kenmore Coldspot model 106.72132101 type 21 TFA.
Good luck
I hope this helps
Gene
Aug 01, 2011 | Kenmore 61282 / 61284 / 61289 Top Freezer...
My Roper refrigerator has water inside it at the bottom and on lower level shelves. How can I correct this?
Good luck
I hope this helps
Gene
Aug 01, 2011 | Roper RT21AKXKQ Top Freezer Refrigerator
WHY DO I HAVE TO DEFROST MY SELFDEFROST REFRIGERATOR EVERY 30DAYS? AND MY FOOD ON THE BOTTOM WILL NOT STAY COLD UNTILL I DEFROST THE TOP.
hi my name is Sean, this more than likely has a bad defrost timer, and/or defrost thermostat. Timer is located in the control panel in the refrigerator, the thermostat is located in the evaporator compartment in the freezer, Let me know if you need more assistance.
Thanks
Mar 26, 2011 | Whirlpool 21.0 cu. ft. Top Freezer...
Automatic defrost has stopped working. How do I fix it?
Good day,
There are 3 components to a defrost system. The defrost heater, which is mounted to the bottom of the cooling cool, behind the rear panel in the freezer compartment. Second, is a defrost thermostat, which is a 1" round disk clipped to the top of the same coil in the freezer compartment as well.
They both can be checked with an ohm meter but the coil must still be cold. Unplug the machine.
The heater should check at below 30 ohms. If it tests infinity (no resistance) it is defective and needs replaced. The defrost thermostat (which must be below 30 degrees for testing) should read zero ohms. If not, replace. It is the most common part to fail.
The last component is the defrost control, which is mounted in the fresh food compartment and can be either a standard timer or adaptive (solid state) control. It is the second most likely component to fail.
Below is an excellent tutorial on defrost systems.
http://www.appliance411.com/faq/howdefrostworks.shtml
Apr 06, 2010 | Whirlpool 21.0 cu. ft. Top Freezer...
Refrigerators Logo
129 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
