E4 in an innovair a/c
After 30 mins the unit shuts down and blows hot air Turned on my Innovair mini split AC (18000 BTUs) display shows E4, then powered it off. Powered on again but now it blows hot air.
  • jorget67 Jan 12, 2009
    Tried that but still same problem. When ac is turned on and standing near compressor, I can't hear the humming sound of the motor, I only hear the fan going. Probably need to call for warranty repair (hopefully)
    Thanks you anyway.
  • 4 Answers
Check the Capacitor.
Posted on Oct 06, 2011
    Scholar:
  • 121 Answers
Hi! jorget67
Sound like the compressor overload is tripped. Make sure the condenser is clean then reset the breaker on this circuit.
Sincerely, InMrFixIt
Posted on Jan 12, 2009
  • Rian Peters
    Rian Peters Jan 13, 2009
    Hi! jorget67
    I believe you may be correct, but there may be some pressure switches or a leak, and there is a problem with the refrigerant. A service call will be necessary.
E4 error on screen
Check out door unit. May be weak in Running capacitor/Fan motor capacitor/Condensor coil dust blocked. First clean and run, if still problem check speed of fan motor, if less replace fan-capacitor.
May 07, 2014 | Midea 24,000 Btu 17 SEER Inverter Mini...
Error code E4 on cold star mini split unit
E4 usually means either blocked capillary, low refrigerant charge, high ambient temperature.
First: check the filters. The front panel opens up like the hood of a car and the filters are fine plastic meshes that you should be able to see through. If you can't see through them that means they are clogged. pull them put and clean them with water only and replace. If the filters are blocked the unit will be unable to refrigerate properly.
Second: check the capillary (water outlet). If the hose is clogged, water usually backs up and sometimes the A/C will start dripping into the room. This also makes cooling defficient. Do NOT try to force water through the hose. Sometimes there is debris in it and you will just make the plug harder to remove. The way to remove it is by sucking the water back, not pushing it forward. A technician should be able to do this for you. The other possibility is that the other end of the "hose" (on the outside) is clogged or under water. Just remove the obstruction.
Third: the ambient temperatre is too high and your BTUs are not sufficient to cool the space. In other words, your A/C is not big enough for the amount of heat/size of the room.
Fourth: have the refrigerant level checked by a qualified technician. They can refill the refrigerant. They have all the tools required.
Mar 20, 2014 | Heating & Cooling
1 ton ac works for 5min and display E4
e4 error code comes for defrost. just remove the cover of your split ac, you shell found a sensor there , check for rat cut.
Oct 12, 2013 | LG LS-L1210CL Mini Split Air Conditioner
Has stopped working and shows - E6 Model: Innovair
http://innovair.com/producten?cat=residential
This is the manufactures website. there is a contact page you can contact them at also can find a dealer from this page that may be in your area.
Oct 09, 2013 | Heating & Cooling
Innovair vexus
i am gettin e9 on my innovair vexus ac unit
May 29, 2013 | Heating & Cooling
I have an Amcor 18000 BTU Mini-Split A/C with Heater and Remote. It has never run more than two days and then I get E4 error code. It is difficult to get anyone to service these units in rural areas. I...
CLICK HERE for the manufacturer site and your owners manual.
E4 is an "Abnormality of Outdoor Unit."
This could be anything from a blown diode to low refrigerant.
Any HVAC repair company should be able to test the unit.
Thanks for using FixYa - please accept this answer to remove it from the work queue.
:D
Jul 08, 2009 | Heating & Cooling
E4 error code on AUX mini-spit a/c unit
E9 Showing on my split unit a/c
May 07, 2009 | Heating & Cooling
My domain air 2.65kw portable ac unit - E4
Make sure the filter is clean and the pump is operating.
Mar 08, 2009 | Heating & Cooling
It sounds like you have a freon leak and may need a charge. When there is a leak, the compressor will run for awhile but without the proper charge, it will heat up and kick on on thermal overload. After the compressor cools, the unit will come back on. Have the unit serviced by a professional.
Jan 09, 2009 | LG LS-L1210CL Mini Split Air Conditioner
SPLIT AC
PROBLEM WITH THE INSIDE FAN MOTOR
Sep 27, 2008 | LG LS-L1210CL Mini Split Air Conditioner
Heating & Cooling Logo
1,539 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
