Question about Toshiba E-STUDIO 450 Copier
E-Studio 450 network issue
I have e-studio 450. i configure all the setting in the netwrok setting pane. i have a domain and network is getting IP from DHCP. even i make reserve the IP to my E-studio 450. I am able to browse and check, change and save the setting via web browser. i uploaded the files of Clint1.exe and clint2.exe files to printer. when i send the pring command to printer it didint print in the logs it shows 0 pages against my Pc printing request.
  • Branko Djurdjevic
    Branko Djurdjevic May 11, 2010
    maybe is stupid question,but do you have print-scan dongle for es450?
Toshiba e-studio 450 black photocopy
I have machines, but I can not use the printer properties. If there is information about how appreciate if you provide information.
Posted on Jul 18, 2009
Why auto power down my Toshiba e-studio 450?
The machine has been set to power down instead of sleep?
Mar 03, 2017 | Toshiba E-studio 450...
Have Toshiba studio 450 & UbuntuX-Ser (computer name) with shared disk space via Samba. Have set Toshiba with save to file with \\UbuntuX-Ser\homes\john\store1\A_Scan as the folder to save scanned...
why not just use the public scan folder if you search network places for the machine IP there is a folder there called scans which is a public folder so everyone can use it.
Sep 01, 2011 | Toshiba E-STUDIO 450 Copier
IP address invalid
8360169.jpg music studio 12 deluxe installed correct on vista openns to studio but wont finish loading computer locks if i click on any tabs ???
Dec 18, 2009 | Computers & Internet
I have sign in HP photosmart to internet wireless connection and is notconnecting but still searching What do I do now.
connect it with ethernet cable to router. then press setup button scroll to netwrok setup press ok. scroll to view netwrok settings or print netwrok settings press ok. scroll to print netwrok configuration page. get ip adress. open internet explorer type ip adress in adress bar at top. then hit enter. it will open pritner ews page. at top click on networking. then on top left corner under connectivity click on wireless then click on ipv4 configurations. under that click on manuall and put same ip address and default gateways and subnet mask that u see on netwrok configuration page. adn hit apply. then go to netwroking tab and look for wireless setup wizard. click on that run wireless setup wizard from computer. it will successfully connect pritner to netwrok. then disconnect ethernet cable and turn on wireless radio. ur pritner is ready to go. print one more netwrok configuration page to check if u r getting same ip address after disconnecting ethernet. and then try to open ews of pritner again from internet explorer by putting ip address in address bar. if it is successfully opening page ur pritner is connectd to network.
Nov 19, 2009 | HP Photosmart C7180 All-In-One InkJet...
How to configure toshiba Estudio 232 network configuration
1. You need first of all USB Print&Scan dongle :)
2. On control panel press "user functions"
3. then select admin tab
4.press password and type password (default is 123456)
5. press network and then ipv4
There you need to type in free IP address, subnet mask and gateway.
For more ask your network admin
Oct 27, 2009 | Toshiba e-Studio 232 Black and White...
CAN'T CONNECT INTERNET USING USB BROADBAND TO LAPTOP DELL STUDIO 15
try to check if there are requirements that must be met in order to use the usb broadband. try checking the TCP/IP configuration on your network settings. And set it as dynamic.
Because the usb broadband will be responsible in assigning ip address to you so you can connect to their server and use the internet. .
I hope this works
Thank you :)
Aug 08, 2009 | Dell Studio XPS 16 Notebook
Problem with fax on estudio 3511
When enabling the Offramp Gateway, this equipment works as an SMTP server to receive
Emails from the Internet. To enable the STMP transmission in this equipment, designate the hostname (or specific domain) that relates to this equipment in the DNS server, and designate the MX record to receive the Emails that are sent to the equipment’s domain in the SMTP server in your local area network. Then the SMTP server should be configured to transmit the received Emails to the equipment in the SMTP transmission. For example, if the hostname of this equipment is designated as “host1.ifax.com”, the SMTP server receives an Email whose forwarding address is “<account name>@host1.ifax.com”, and the SMTP server transmits the received Email to the equipment. Then this equipment will send the received Email as a facsimile document to the fax number that is specified in the <account name> part.
Setup Procedures:
1. Setting up the DNS server and SMTP server.
2. Setting up the TCP/IP and the HTTP Network Service to enable TopAccess
3. Setting up the SMTP Network Service.
4. Setting the Internet Fax Settings.
5. Setting up the Fax Settings
6. Registering the Relay Box with Email addresses.
Dec 19, 2008 | Toshiba E-Studio 161 Copier
Compatability issues with Toshiba e-studio 350 copier and Windows Vista
This copier must have the latest firmware installed, a print enabler and you must have the latest print driver in order for Vista to be supported. All of this is available from a certified Toshiba dealer. Also, you can check to see if the copier is working by inserting the Cat5 cable to the copier from your network and typing in the IP address (found under the Administrator tab on the touch panel of the copier) into the URL bar of your browser. A web page will pop up showing the machine is active.
Oct 21, 2008 | Toshiba e-Studio 350 Copier
Network printing
the Best way will be to conect the printer to the  router  assign it a IP address then add the tcp/ip port to all computers  let me knew if you need more detailed info
Sep 04, 2008 | Toshiba E-STUDIO 450 Copier
Network printing issues - Toshiba e-studio 16s
try this:
start, printers and faxes
right click on the print driver , go down to properties click
click on ports
click configure port
click lpr in protocol
Lpr queue name PRINT
LPR byte counting enable
SNMP enabled
Try this and make sure your ip address is correct
Jan 21, 2008 | Toshiba e-STUDIO 16 Printer
634 people viewed this question
Top Toshiba Office Equipment & Supplies Experts
didi2005
jasbo
jasbo
Branko Djurdjevic
Branko Djurdjevic
Are you a Toshiba Office Equipment and Supply Expert? Answer questions, earn points and help others
