Question about Apple iPhone Smartphone
My phone has been ringing 30 minutes with black screen not allowing me to slide ON..It also does not allow me to power down. This could go on all night if my battery does not run down. WTH?!
  • wendy white Dec 06, 2012
    Ok looking at a similar question from 2011, I held both the power switch and the on switch simultaneously for a 'hard restart.' I seems to have done the trick...
    Master:
  • 368 Answers
1.Check the device's battery level for at least two bars of strength.
2.If the battery level is low, charge the battery.
3.If the issue is not resolved, remove the back cover.
4.Remove the battery.
5.Wait 10 seconds.
6.Press and hold the W key.
7.While pressing down the W key, re-insert the battery.
•The device restarts and after approximately 15 seconds, the 'Recovery' screen appears
•Release the power button but *continue holding the home button*, for another 30 seconds.
Step
Thanks
Posted on Dec 06, 2012
Why am I unable to answer my phone?
Unable to answer calls - Support forum
https://talk.sonymobile.com/.../Unable-to-answer.../839311
Sony Mobile
Solved: Hi, my Z3 compact has been working fine but this evening I suddenly ... Thephone rings out but the swipe icons for answering the call simply don't ...
Unable to answer phone - Android Forums at AndroidCentral.com
forums.androidcentral.com > ... > Verizon Droid Incredible
Oct 24, 2010 - 8 posts - ‎6 authors
I am unable to slide the "answer bar" across the screen, to. ... I'm trying to determine if this is a hardware problem with my phone of if it is a ... Why am I unable to answer calls on my Galaxy Exhibit ...
Mar 30, 2015
Can't answer incoming calls...
Jul 24, 2014
Galaxy S5: Slide to answer problem
May 11, 2014
Cannot answer phone calls
Mar 7, 2013
More results from forums.androidcentral.com
Jan 01, 2016 | Cell Phones
I can't remember my password and it's not allowing me to reset it either. what do I do?
Reset your phone.
Important: Resetting your phone erases all personal content, including apps, and restores the factory settings.
1. Make sure your phone has enough battery power, charge your phone for at least 20 minutes.
2. Switch off your phone, and disconnect the charger.
3. Press and hold the volume down key, and connect the charger. An exclamation mark (!) is shown on the screen.
4. Press the keys in the following order: volume up, volume down, power, and volume down.
5. Wait for your phone to reset, during the reset there will be gears rotating on the screen for up to 5 minutes, after which the screen goes blank for ~30 seconds and then your phone will restart.
6. Go through the initial phone setup, if the date and time are shown, ensure the values are correct.
7. Disconnect the charger.
Jul 08, 2015 | Nokia Lumia 520 Windows Phone Black
HOW DO I UNDER FREZZER MY KINDLE
Hold the power switch for 20 seconds. Slide the power switch and hold it in place for 20 to 30 seconds before releasing it.
  • You need to physically hold the power switch in its off position for this long. Doing so tells your device to "reboot," in essence, instead of merely shutting down.
  • The reboot screen should appear as soon as you release the power switch.
Give the Kindle time to reboot. The Kindle will reboot within a minute or two. Be patient and give your device ample time to finish its reset.
  • There is some possibility that the Kindle will freeze as it reboots. This may be the case if your Kindle stays frozen on the reboot screen for more than ten minutes.
Charge the Kindle. If the device freezes during the reboot or does not respond to the reset at all, plug the charger in and allow your Kindle to charge for 30 minutes or more.
  • Make sure that your Kindle has enough time to complete a full charge.
Hold the power switch down again. After you finish charging the Kindle, slide the power switch and hold it down for another 20 seconds.
  • The reboot screen should appear again. Give the device a minute or two to reboot before checking it again. This should complete the reset.
Jan 01, 2015 | Amazon Kindle 3G
My Iphone 5c was working fine, its cracked up quit a bit but its been like that for a month or so now. I put my phone down and when i picked it back up about 7 minutes later the screen was black and w
If the front glass is what's cracked, the part called a digitizer, (which is a thin film layer that reads the skin's touch) could be faulty. WHen the glass is cracked, sometimes it's just a matter of time before the digitizer craps out on you.
Feb 07, 2014 | Apple iPhone Smartphone
White screen 8530
Have you tried a reset or a reboot? Try these steps:
1. Power off the cell phone by holding down the power button for at least 5 seconds. The screen should turn black. Now, let go of the button and press it again until the screen lights up again.
2. If the screen is still white while holding down the power button, open up the back of the cell phone and remove the battery. Wait for 30 seconds before putting the battery back in, to allow the software to reset itself. Put the battery back in and press the power button until the screen lights up again.
3. If you removed the battery and you still have a white screen, you may have a software issue. Go to a local cell phone repair company and have it replaced or fixed.
Apr 18, 2012 | RIM Blackberry Curve 8520
I cant slide to unlock my iphone or power it off either
Try holding the top button and the home button until it shuts down. Then power it on again w/ the top button. Hopefully a hard restart will allow you to use the touch screen again.
Feb 06, 2011 | Apple iPhone 3GS Black (16 GB)
OUR PROSTAR 816 SYSTEM IS RINGING BACK ONCE WE PUT SOMEONE ON HOLD WAY TOO QUICKLY. IN ABOUT 30 SECONDS IT WILL RING BACK & i'D LIKE TO CHANGE THE RING BACK TIME TO AS LONG AS IT WILL ALLOW. CAN YOU...
To change the hold recall timer on a prostar 816 you first need to be at a display set (doesn't matter what the extension number is).
with the handset down enter #20 the screen should say MMC DISABLED
enter in 1 2 3 4 1 # (that enables programming)
The code for hold recall is #52
enter in your hold recall time in sec. and in a 3 digit format. i.e. 30 seconds = 030 a minute and a half is 090 and so on.
press # when finished
Aug 13, 2010 | Samsung Prostar 816 Phone
Touch screen won't respond.
Try rebooting the phone completely. Hold down the Home & Power buttons for 5 seconds until the phone goes off completely. Then try turning it back on.
Let me know if that works?
Apr 12, 2009 | Apple iPhone Smartphone
Phone won't ring in sleep mode
I had the same problem with my iPhone the only way I was able to fix it was to re-flashed the latest 2.2 firmware. Power phone off, power on by holding power and home at same time, hold power for ten seconds and then release still holding home key for another 30 seconds to put phone in DFU mode. Then plug into iTunes it will detect phone in recovery mode and allow you to re-image
Jan 08, 2009 | Apple iPhone 3G Black Smartphone
My apple iPhone 8GB, screen locked and is only allowing me to make emergency calls. Thanks, Ada
You may need to put it back in its cradle to sync.....A quick turn the unit off, by sliding the touch screen slide.....then holding the top right-side tab.....It will give you a (Slide to power-off)....turn off for a minute...Once back on replace to cradle for sync...If problem still exsit...Contact Apple Genuis bar!
Sep 14, 2008 | Lands Phones
Apple iPhone Smartphone Logo
Top Apple Cell Phones Experts
Computer Repairing
Computer Repairing
Lesley Cameron
Lesley Cameron
Are you an Apple Cell Phone Expert? Answer questions, earn points and help others
