Question about Sony KV-36XBR400 36" TV
Sony KV - 36XBR400 36" keeps going to standby - blinks red x5
According to Comet engineer, 5 red blinks means "unstable" but he has not repaired it and left me saying he's order part, that was 6 months ago, now it has run out of warranty and still blinking 5 times
  • 179 Answers
5 blinks is an IK balance problem. it means your picture tube is not drawing the correct current on 1 of the 3 cathodes (IK). there is a good chance the tube is bad. if you reported it while under warranty you should call the warranty company and pursue it.
Posted on Jan 12, 2009
Why wont my sony kv-30hs420 tv wont turn on? When i try all that happens is the red light will keep blinking seven times!
My TV continues to blink on Standby with Red light ...
https://community.sony.com/t5/...blink...Red-light-flashing.../59141
Jan 12, 2013 - I need help with my Sony TV. The red flashing light keeps going on and off. ITs on standby. can someone guide me as to how to fix the problem. ... I have a Bravia KDL52W3000 with a 7" wide dead pix... Television - Picture & Sound ... What is the exact model number of the Sony TV? Check if the same issue ...
Nov 14, 2015 | Sony Televison & Video
Sony Triniton TV KV 32FS120 will not turn on
In standby mode (red led on/after the led stops from blinking), press "Display", "5", Volume (-)", "Power on" on the remote control in sequence, self diagnostic screen will be display, let me know the what is on the screen to diagnose where the fault came from.
Nov 25, 2011 | Sony FD Trinitron WEGA KV-32FS120 32" TV
What dose it mean when the standby light flashing?
Hello
In Sony TVs, number of blinks of the standby light denotes some problems inside the circuit board of that TV. The number differes with the section where the fault is. According to the number of blinks, we can reach to fault point easly. Just count the number of blinks, with TV switch On-Off with its front panel switch, not by the remote control. Keep this in mind. Ok.
Nov 05, 2010 | Sony FD Trinitron WEGA KV-36FS120 36" TV
Red blinking light, SONY KV-32FS13
The 4 blinks usually mean a vertical deflection problem. If you can solder you should be able to repair this yourself. Let me know if you wish to attempt the repair and I'll provide more details and instructions.
Dan
Oct 02, 2008 | Sony KV-32FS13 TV
My Sony Trinitron won't turn on...has 4 blinks in Standby.
There are 3 reasons for 4 blinls
1.unit went to stand by mode because of h-pulse
2.Vertical defflection pulse stopped
3. power line is shhorted or power supply is stoped.
Solution:
1. check 13vdc on A board of powersupply stage
2. Check IC561 on A-board.
Good Luck
Dals123
Sep 08, 2008 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Tv wont turn
The blinking red light at the the front of the television is the "Diagnostic STANDBY/TIMER LED".
This little red light will blink 2, 4, or 5 times and then stay off for three-seconds. And blink again for 2, 4, or 5 times. This cycle repeats. The most common diagnostic code is the 4-blink code.
When the red LED blinks 4-times, it means one of two possible causes:
1) +13V is not supplied on the A-board. Or, 2) IC502 is faulty.
It is best to take this television set to a repair facility and ask that the +13V power supply be repaired.
The copper tracks and integrated circuit pads are very thin and delicate on the KV-24FV12 circuit board, and will easily lift off of the circuit board, if the incorrect desoldering tool is used. Unless one has a good quality PACE vacuum desoldering unit, one should not attempt to repair the television.
Aug 17, 2008 | Sony KV-24FV12 24" TV
Sony Trinitron KV-32FS320 5 blinks
Sony KP53HS10 5 blinks
Five blinks means "Video out abnormality detection". Possible problem areas are as follows:
Video out, IC7101, 7201, 7301 and others in C board circuit.
Q510, 516, 524 (A board).
There are actually three C boards, the CR, CG and CB boards. They are attached to the rear of the red, green and blue CRTs, respectively. I wouldnt attempt to repair the set myself. I would solicite the services of an authorized Sony servicenter.
Jan 23, 2008 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Bad picture color. red LED blinks 5 times. Replace picture tube?
Definitely bad picture tube==not worth fixing......T.
Oct 11, 2007 | Sony KV-36FS16 36" TV
Sony KV-36FS76U keeps turning itself off
Due to playstation or dvd nothing will happen. 5 red flashes means jungle ic failure shows this display. Technical person only sorted out the above problem.
May 07, 2007 | Sony FD Trinitron WEGA KV-27FS100 27" TV
Sony KV-36XBR400 36" TV Logo
231 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
