Question about RTO Intermatic HB1116R Power Stake With Timer
How to disassemble intermatic HB1116R
Timer not working
2 Suggested Answers
SOURCE: my HB1116R TIMER STOPS
If the timer dial will not push the tripper past the on-off lever, or if dial is no longer rotating, or is rotating slow, then clock motor has gone bad.
There are no replacement clock modules for HB series timers.
http://waterheatertimer.org/Intermatic-trippers-and-parts.html#PB
You can set timer to override and plug HB into another plug-in timer
Intermatic site no longer shows HB series outdoor timers except for HB8800.
http://www.intermatic.com/products/ec%204%20layer/plug%20in%20timers/plug%20in%20timers/plug%20in%20timers.aspx
Amazon still sells HB1116R
Posted on Jul 07, 2011
BOUGHT NEW INDOOR TIMER MODEL EJ351J,INSTALLED IT AND IT DOES NOT WORK DO I RETURN IT TO THE STORE, OR DO YOU SEND ME A NEW ONE?
1) Do not mail your timer to fixya. We answer questions and do not sell timers.
2) Intermatic gives 1 year limited warranty against defects in EJ351 manufacturing.
3) Intermatic policy is to return timer to merchant that sold timer.
4) You can also contact Intermatic, and possibly send timer into Intermatic for repair.
http://www.intermatic.com/customer%20service.aspx
5) Additional resources, including instruction manuals:
http://waterheatertimer.org/Intermatic-timers-and-manuals.html
Take a moment and rate answer:
And take advantage of fixya expert assistance live.
For a price, expert works with you while you work on timer or any do-it-yourself project.
Fixya is always less expensive than a service call.
Sep 02, 2011 | Intermatic Inc. ST01C Digital In-Wall...
Manual switch works timer doesn't.
Timer that worked before and stopped working: could be clock motor or trippers
New timer installation: possibly the wiring from breaker box and wire to Load are reversed.
Open following links to troubleshoot Intermatic timer.
http://waterheatertimer.org/How-to-troubleshoot-Intermatic-timer.html
http://waterheatertimer.org/How-to-wire-T104-Intermatic-timer.html
Jul 27, 2011 | Intermatic & Indoor/Outdoor Rain Tight...
My HB1116R TIMER STOPS RUNNING ON OFF WORKS FINE thank you in advance if i tap on housing i can hear timer starting for a few seconds
Jul 07, 2011 | RTO Intermatic HB1116R Power Stake With...
I have to spin the timer by hand to turn the lights on and off.I have the Intermatic ML900TW transformer.It seems to me I just need to replace the timer but they have been discontinued by Malibu Lights and...
PB912 timer module is not available separately.
Following link shows available PB series model numbers:
http://waterheatertimer.org/pdf/Intermatic-PB800-PB900-timers.pdf
http://waterheatertimer.org/Malibu-power-pack-stopped-working.html
If clock motor no longer operates, you can set power pack to override and then plug power pack into cheap in-wall timer.
Some people report being able to disassemble clock motor and clean gears and reassemble with a bit of white grease on gears. Other people report they took it apart and forgot to mark the tiny gears and couldn't reassemble the parts. My experience with clock motors and motors in general is once they slow down and overheat, they never work correctly again and are sorely underpowered afterwards. It would be easier to buy a cheap plug-in timer.
Jul 02, 2011 | Intermatic Malibu 900-Watt Power Pack with...
Automatic sprinklers (Intermatic timer) do not work in automatic, but manual does work. When I cycle the timer, the solenoid activates but not enough for the sprinklers to spray. Manual works fine. Any...
If manual override works, and dial rotates on time each 24-hours, then worn trippers are suspect.
http://waterheatertimer.org/Intermatic-trippers-and-parts.html#sprinkler
Upvote the help.
May 28, 2011 | Intermatic R8806P101C -...
I have a wall-switch Intermatic Timer Model 885L that has become too stiff to turn itself off automatically. Can these be lubricated by WD-40 safely???? Or what is best fixit???
I am unable to identify Intermatic 885L
Add a comment with clear description of timer so I can identify and help.
With mechanical dial timers, once the motor begins to slow down, then motor overheats and burns out. This is true for all electric motors, and eventually all electric motors stop working.
Power pack yard-light transformers, in-wall timers and plug-in type timers are not repairable, even with WD40, because the motor has already overheated.
These timers are replaced with new timer.
However if you have a power pack, since this timers is expensive, you can buy cheap plug-in timer, set power pack to override, and then plug power pack into cheap timer.
With direct wire mechanical box-type timers that are used for parking lot lights and pool pumps, for example T100 series 120V and 240V timers, the clock motor is replaceable. These small motors cost $16 to 60 depending on clock.
Again, add a comment with clear description of timer so timer can be identified for certain.
I can also post the manual if available, and post links to sellers of similar/same timer if replacement if necessary.
http://www.intermatic.com/products/timers/consumer%20indoor%20timers/in-wall%20timers.aspx
http://www.aplussupply.com/intermatic/timer.htm
Add a comment for more free help.
Also take advantage of fixya phone service.
For a price, expert speaks with you over phone while you work on timer or any do-it-yourself project.
Jan 31, 2011 | Intermatic Hardware & Accessories
Intermatic Timer Model HB1116R - Timer Clock Inoperative, unit is one year old.
1) Manual says: If within (1) year from the date of purchase, this product fails due to a defect in workmanship, Intermatic Incorporated will repair or replace, at its sole option, free of charge. This warranty applies only to the original purchaser and is not transferable.
2) Contact Intermatic
Dec 11, 2010 | Intermatic & Indoor/Outdoor Rain Tight...
I have an intermatic 7 day all weather timer model HB71R.I have lost the owners manuel.Anywhere I can print one off as it has to be re-programed.
Intermatic does not show that manual.
Intermatic manuals:
http://www.intermatic.com/customer%20service/instruction%20manuals.aspx
They show HB77R raintight.
This model may be close enough to figure out button sequence.
I work with timers and most programming follows similar pattern.
Older timers usually follow same pattern as new timers, except with fewer options.
http://www.intermatic.com/products/timers/consumer%20outdoor%20timers/digital%20timers/hb77r.aspx
Nov 16, 2010 | Intermatic 7 Day Digital Timer Model...
I have digital programmable timers (Model DT121 and Model DT11) that will accept programs, but won't turn the attached lamps on and off at the programed times. The batterys are new and I've had them...
DT121 Manual
http://www.intermatic.com/~/media/files/intermatic/products/instructions/timers/dt121c%20-%20english.ashx
All Intermatic manuals
Intermatic does not show DT11
Intermatic shows the DT121 is no longer available
If the display shows and you can set programs, then the battery is good.
Does the manual override work? This indicates whether the timer on-off switch operates.
If manual override does not work, then I discovered that timers are no longer any good
Programming:
Set present time
Then set ON time for program 1
Set OFF time for program 1
Then set ON time for program 2
Set OFF time for program 2
Most timers will not function if there is a conflict in programming > for example Program 1 says ON at 6 and OFF at 7 and Program 2 says opposite or has overlapping times
When events are set, press SET once > this will put timer in RUN mode
If manual override works, and you set programming correctly, but timer does not carry out instructions, I guess the timer is no good.
Intermatic has 24 hour timers with 2 on-off per day
http://www.intermatic.com/products/timers/consumer%20indoor%20timers/lamp%20%20appliance%20timers.aspx
Intermatic has 7-day digital timers (all digital timers today are 7 day where you select the day that each program works)
http://www.intermatic.com/products/timers/consumer%20indoor%20timers/digital%20timers.aspx
Oct 12, 2010 | Intermatic Hardware & Accessories
RTO Intermatic HB1116R Power Stake With Timer Logo
135 people viewed this question
Top RTO Hardware & Accessories Experts
Craig Butler
Craig Butler
Gene Haynes
Are you a RTO Hardware and Accessory Expert? Answer questions, earn points and help others
