Question about Crosley ENTERTAINER PLUS RECORDER Shelf System
How to get out of standby mode in a crosley record player
Unit won't get out of standby mode
5 Suggested Answers
djnick989
  • 1067 Answers
SOURCE: crosley songwriter cd recording problem
maby the formatt its wrinting on is ther any options in menu of it to set the output formatt to mp3
Posted on Jan 22, 2008
  • 38 Answers
SOURCE: will my autorama crosley cr712 record player work without
The record player will work with out a remote.
The CD will need a remote, for operation control.
The radio will work with out a remote
Posted on Nov 04, 2009
Grubhead
  • 5158 Answers
SOURCE: Hi I have a crosley auto rama record player with
There's one way to check the motor. Take it out and connect a battery (if it's over 9 volts a PP9 should do it.) if it don't turn it's dead!
Then try CPC online parts people.
Posted on Jun 02, 2010
  • 1039 Answers
SOURCE: cannot get my new crosley
When it is off and plugged into the wall outlet the standby light will be on. The stadby light will go off when power button is pressed. If not there is poblem that needs service.
Posted on Dec 26, 2010
Button standby
The receiver is in protect mode, most likely due to a damaged amplifier. This protect mode, keeps the unit from turning on and causing further damage to itself and/or your speaker system. For more information, please visit my website at audioserviceclinic.com. Thank you.
Jul 27, 2013 | LG Lsb316 Sound Bar With Wireless...
TV won't turn on. Stays in Standby mode
Someone is going to have to go inside and check voltages and other things --no brand or model is indicated here so this is as much as I can suggest.
Dec 20, 2012 | Televison & Video
My symponic tv is in standby mode and won't turn on
check for defective regulator at the power supply section and shorted horizontal section. if you don't have an idea how to trouble shot this unit i suggest to leave it to a trained tv repairman to fix the problem. atleast you have an idea what to expect when you hire somebody to do the job good luck.
Sep 17, 2012 | Symphonic ST419E TV
Sony HCD LX20i audio shelf sysyem won't turn on. Standby light flashing. Disc stuck in it.
Check the speaker wires for shorts, if okay! suspect the audio output ic's, the protection circuit won't come out of standby because there is a short.
May 06, 2012 | Audio Players & Recorders
Sony FD Trinitron WEGA..won't turn back on TWO Blinks---B+ over current protection (OCP) , unit goes to the standby mode then displays the 2 blink fault. Could be a short in the power supply of an
Visit this site for details. All information about this type of fault [2 blinks of standby light to sony Trinitron]; are described here in detail.
"Electro-help", is the name of the site.
Search for it on Google.
May 02, 2012 | Sony FD Trinitron WEGA KV-30HS420 30" TV
Sony kv36xbr800 won't turn on -standby blinks 2 times pls help
Two blinks - B+ over current protection (OCP), unit goes to the standby mode then displays the 2 blink fault. Could be a short in the power supply of any of the circuits.
Apr 22, 2012 | Sony FD Trinitron WEGA KV-36XBR800 36" TV
Acer p241w stays standby
CHECK IN BIOS MODE ,THIS PC NOT GOES TO STANDBY SO PROBLUM IN YOUR OS .FORMATE PC NOW CHECK .
Aug 31, 2017 | Acer P241W 24 inch Monitor
Philips HTS6100 -seems to be stuck in Standby Mode....won't actually do anything! Any ideas?
Your unit maybe on protect condition that why on standby mode,,,it means theirs a truoble in circuit inside that why happened...try to consult in the nearest service cnter or a wll trained technician,,wish you luck
Feb 19, 2012 | Sony Audio Players & Recorders
PIONEER VSX-D606S WHEN POWERED STAYS IN STANDBY MODE- LIGHT IS ON, A CLICK IS HEARD BUT THAT IS ALL
Your unit staying in standby mode is an indication that its having a power problem. Remove its plug from the wall and fix it back into the wall, then turn it on again. If its still stuck in safe mode, then the power supply board in the unit is the cause of the problem.
The power supply board might be defective and maybe that's why the unit won't power up. Its receiving power but it cannot transfer the current to the necessary part of the unit because a capacitor, diode, etc may have been faulty. Until these bad components are replaced, the unit might not come on.
To actually find out what's wrong, you need to disassemble the unit with a screw driver and check what's wrong. You will be needing a meter in order to test the components on the power board, once you detect any bad component, you can make necessary replacement at any electronics accessories store withing our vicinity. This is the only way by which you can detect the problem.
Of course, testing the power board with a meter will require someone that has the ability. So it you can't, then you might be needing the help of a repairman or you can call a friend that has the ability to help you out.
I wish you the best of luck.
Regards.....
Apr 17, 2011 | Pioneer VSX-D606S Receiver
Crosley ENTERTAINER PLUS RECORDER Shelf System Logo
273 people viewed this question
Top Crosley Audio Players & Recorders Experts
 Grubhead
Grubhead
Electro Med Services...
Are you a Crosley Audio Player and Recorder Expert? Answer questions, earn points and help others
