Question about APC (SUA3000I) UPS System
The UPS does not come on at all
We usually turn off the UPS on leaving. Upon trying to put it on the next day, the UPS does not come on again. I have tried holding down the power button for some seconds to activate battery power but nothing.
Help! What could be the problem?
    New Friend:
  • 37 Answers
Well how long you had use the battery already if it more than 3 yrs it time to change a new one the time of the lifespam of the battery it startin to decae or the battery is bad. replace a new battery and test it up.. i sugguest you to on the power of the ups all the time. no need to worry for the equiment to be gettin spoil.. ups is able to with stand the unstable power and to protected the equiments.. the liabitily of the ups is high.. if you keep turn off the ups you may not a ware that u are not fully turnin off the ups that cause of the internal chargin may still charging and dis discharge and cause the life spam of the battery to dead faster.. that becoz the battery after u install into the ups it start to charge and discharge 300 cycles so it juz nice to prolong till 3 yrs but if you turning off and on it will speed up the cycles..
Posted on Mar 24, 2009
PC Power Issue
It does sound like a psu problem, if you are comfortable with opening your pc then (remember to use anti static wrist band rubber matting etc) and remove the psu and give it a good dusting (as the dust does collect in on the fan and inside the unit itself (please be careful when working with this unit as it is a power unit and can be dangerous) put unit once cleaned back into the pc making sure you reconnect everything carefully. (if you are not sure rather take it to a professional as you can do some serious damage to your mother board and or peripherals. but this should give a few more boot ups ultimately you could replace it with a new PSU.
Nov 09, 2014 | CORSAIR CX Series Modular CX750M 750W ATX...
I had a jam, upon clearing the jam, the printer will hang with the motor turning, and the display saing 'adding toner'. I changed the (new) toner, for a brand new one. Still message will not go away.
Leave the machine working to see the next message of Adding Toner. Usually the next message of "Adding Toner" is "Ready to Copy".
If the next message is "Add Toner", i suggest you to pull the new toner kit out and push it a little bit harder and check again.
If you power the machine off and on again, can you see what the message about toner is, Original or Unknown Toner is installed?
Sep 30, 2014 | Kyocera Office Equipment & Supplies
The ups does not want to turn on
The most common problem with UPS that no longer works is that the battery is dead. They often do not last longer than a few years. Replacement batteries can be bought rather inexpensively at any battery store. Usually they are some combination of 12 volt 7 amp sealed lead acid batteries. Replacing them usually get the UPS going again.
By the way. If you do not want to go to the expense of replacing the batteries, the UPS usually still functions as a first class surge arrestor and line filter.
Nov 11, 2013 | APC Symmetra LX UPS System
Why would my shuttle barebones upon turning it on and itgoes through a boot n dianostic it said pl-rom-ffc: 50disk boot failur insert system disk. What do I do???
Reinstall your Windows program, try buying a solid state hard drive and put your Window program on it alone usually a 120gb or 200gb will do, and have another hard drive for all your other downloads, ever since i did that my Windows loads much faster and have no hang ups or errors..
Oct 02, 2013 | Shuttle XPC Computers & Internet
Sir after changing the battery ups worked well one day and the next day onwards when i pressed the switch red and amber lights blinking and the upc trips with beep sound .kindly give the solution
Batteries in the UPS typically last 3 to 5 years and it depends upon several factors. including the number of times the unit must go on battery power and environmental conditions. There are usually several batteries in the UPS and while the battery voltage may show 13 volts, this may only be a float charge/voltage and a true indication of the battery voltage and condition requires the batteries to be tested under a load. There maybe one battery in a set of batteries that is faulty and causes the whole battery system to fail and indicate a battery fault.
These lower powered and cheaper KVA type UPS are switch over types, when the mains supply fail, the UPS switches over to the inverter in milli-seconds which then supplies mains power but the power waveform is a pseudo sine wave (ie not a true sinewave. A faulty inverter circuit won’t deliver power when the mains supply fails.
The true UPS types are usually the higher KVA units (over 1500 VA) that supplies uninterrupted mains power. The mains power is connected to a charger which charges the batteries and the inverter draws power from these batteries and converts it to true sine wave mains power therefore there is no switch over time lag from the mains to the battery.
Oct 16, 2009 | APC Computers & Internet
Phone shuts off
you might have damaged files on your sd and that is probably causeing the malfunction in which your phone shuts off so if you download from a new site you should be good or get a new sd it might be faulty
hope this helps
and have a nice day
May 26, 2009 | LG Vu CU920 Cellular Phone
No Power when turn on so battery wont charge
Try leaving it off, but plugged into the wall outlet so the batteries can charge up. If they are new, they are probably without a charge. The instructions should indicate how long it needs to charge - probably most of the day.
Jan 05, 2009 | Tripp Lite Smart Pro UPS System
Mge nova avr 1250 problem
ups charged for 8 hrs .No alarms but on powerfail no output to connected device
Nov 15, 2008 | Computers & Internet
New battery will not recharge
Don't turn it off, the battery needs to be constantly charged or refreshed. They will go bad just sitting around with no voltage applied. The UPS draws very little power and has surge protection so there is very little to worry about.
Dec 19, 2006 | QVS NetStar (UPS650A) UPS System
APC (SUA3000I) UPS System Logo
168 people viewed this question
Top APC Computers & Internet Experts
Jax Planet
Jax Planet
Are you an APC Computer and Internet Expert? Answer questions, earn points and help others
