Question about JRC Boating
I have a JRC 3000 radar, bearing pulse error pop on the screen...does anyone know what the problem....????
3 Suggested Answers
TechnoMarine
  • 132 Answers
SOURCE: seeking replacement magnetron for Raymarine M92652 4kw radar
give ne an email and i will quote it
Posted on Jan 17, 2010
  • 35 Answers
SOURCE: JRC Radar Scanner when rotating
There is a seal on the antenna scanner shaft, just below the seal there are two bearings, thou the antenna are enclossed moisture still get inside and get to these bearings. Try and get a small amount of wd40 on the bearings, if not, you will soon begin to see false echoes on the screen because the motor on the scanner or antenna will begin to work harder causing a drag causing these echoes. Good luck.
Posted on Jan 30, 2011
I have radar JRC JMA-9303.and we find a trouble "trigger error"
After black out of ship during audit Radar Model JMA 9303 no work.
Radar start work and after 15 sec. switch off.
Radar not show target and display error "ANTCLK ER" ( Bearing pulses are not
sent to the display unit)and "TRIG ERR" unknown error.
Antena of radar working.
Any body can suggest the solution
Oct 09, 2012 | GPS
JRC Radar Scanner when rotating is noisy inside the scanner base.
Jan 17, 2011 | JRC Jma-2343 4kw Crt Radar
JRC 1000 MKII bearing pulse error on receiver screen. Connections to scanner good and scanner turning. How can I determine if the problem is in the receiver? How can I fix it? louonboard
Normally the bearing pulse comes from the bearing pulse generator built inside the motor. Every time the motor turns it sends a pulse down the line showing the radar that it is indeed spinning. There is also a Heading pulse that comes from an electric eye elsewhere in the housing. The other thing could be that the wire carrying the bearing pulse is not getting back to the display. More so than often, it's the motor. I would have the display sent out to be checked on a simulator if there is a marine electronicshop nearby.
Oct 27, 2009 | JRC 1000 MKII Radar GPS Receiver
Error BZ
This is a bearing pulse error. Either the bearing pulse generator inside the motor is bad (Replace the motor) or it's in the radar cable or display.
Jun 15, 2009 | JRC 1000 MKII Radar GPS Receiver
I need schematics off jrc radar 1500
Ask at http://manualfox.com/schematic.htm
If anybody can find it, this is the right place to ask.
Apr 27, 2009 | JRC 1500 MKII Radar
Draw down is to high
found my fault not i the power cable in, but the interconnect to radar dome..approx 50mm from radar screen a break in the wire, found it just by wiggling the cable.. the set wont power up if the interconnect not connected or is faulty
Apr 07, 2009 | JRC 1000 MKII Radar GPS Receiver
Jrc 1000
Hi , I have a JRC 1000 with manual if it can helps ( in English and french but i ma in france. You can also use the installation manual of JRC 1500 available on internet under pdf format , very similar ( same screen and operating interface )
pcg1@orange.fr
Jun 13, 2008 | GPS
Raymarine 41xx - Message "bearing pulse error"
More than likely your motor is going bad. Inside the motor is your bearing pulse generator. Replace the motor and you should be ok.
Apr 28, 2008 | JRC 1500 MKII Radar
Boating Logo
82 people viewed this question
Top JRC Boating Experts
Steve
Steve
ray gallant
Fabrice Wolters
Are you a JRC Boating Expert? Answer questions, earn points and help others
