Auto restart my computer
when i am try to turn off my computer,
windows could not shutting down auto restart i few seconds.
i Reinstall Windows Xp but not solved this problem
help me please.
Hai Friend your reset button is Shorted so plz check your connection on motherboard with reset button................
Posted on Jan 12, 2009
Hello. My acer aspire 4820tg laptop is unable to start up. When i turn it on, it says that windows is unable to load, and gives me the option to try and repair it. When either doing that or attempting to...
I suggest to reinstall the OS. During the installation process, format the existing system drive/partition/volume and install the OS again. This will fix any software problems or corrupt files. If there are hardware issues, you'l know that when you reboot the machine to log into your account.
Aug 30, 2017 | Computers & Internet
Window can't log on?? when notebook on window logo display after few second computer is restart....any solution???
hello,
This problem can occur due to several reasons. And there are many steps that need to be taken care of. Try this step shut down the computer completely and then look for the F8 key on the keyboard once you locate the key hit the power button and then keep on tapping the F8 key until you see the start up options before booting into windows now try the options safe mode or safe mode with networking.
Now try these steps and see if this works out. and if this solutions help and let you log in computer then go ahead and restore your computer to an earlier time.
Thanks
Oct 09, 2012 | HP Compaq Presario CQ70120US Notebook PC
There is no services windows installer
Reinstall the Windows Installer
To reinstall the Windows Installer, rename the damaged Windows Installer
files, and then reinstall the Windows Installer. To do this, follow these
steps:1. Click Start, click Run, type cmd in the Open text box, and then
click OK.
2. Type cd %windir%\system32, and then press ENTER.
3. Type attrib -r -s -h dllcache, and then press ENTER.
4. Type ren msi.dll msi.old, and then press ENTER.
5. Type ren msiexec.exe msiexec.old, and then press ENTER.
6. Type ren msihnd.dll msihnd.old, and then press ENTER.
7. Type exit, and then press ENTER.
8. At the command prompt, type exit, and then press ENTER.
9. Click Start, and then click Turn off computer or Shut Down.
10. Select the Restart option, and then click OK, or click Restart.
11. Log on to the computer.
12. Download and install the latest version of the Windows Installer. For
more information about how to obtain the Windows Installer, click the
following article number to view the article in the Microsoft Knowledge Base:
893803 (http://support.microsoft.com/kb/893803/) Windows Installer 3.1 v2
(3.1.4000.2435) is available
13. Click Start, and then click Turn off computer or Shut Down.
14. Select the Restart option, and then click OK, or click Restart.
(Vista uses Ver. 4)
Was this helpful? Then click the "Yes" button below. Voting helps the web
interface. http://www.microsoft.com/wn3/locales....htm#RateAPost
Jul 30, 2012 | Computers & Internet
Hello, whenever i type, my trackpad locks for a few seconds how do i fix this?
Make sure the scroll lock button is OFF.
Download the following from the Dell Support Drivers and Downloads page.
Quickset
Alps Input Drivers
BIOS
After downloading these update install if starting with Quickset, Alps Driver then BIOS. After flashing the BIOS laptop will automatically restarts.
After it reboots. In Dell screen hold down the F8 then select safe mode then press enter key on it. Wait until it loads in safe mode. Try working in safe mode if problem persist if not then boot back to windows normal mode by just restarting the computer.
If problem persist in normal mode in windows then i suggest back up your files then perform windows re-installation.
In doing the reinstallation you need to use the windows installation cd came with the computer.
Boot to F12 then insert the CD windows then select to boot to CD the follow prompts.
May 28, 2011 | Computers & Internet
I have a HP Compaq dc5700, and i want to set it to default settings. I do not have any passwords for it. It has windows vista. i tried going to setting(f10) and it asks for a password. I removed the...
Password Security
Establishing a Setup password:
1. Turn on or restart the computer. If you are in Windows, click Start > Shut Down >
Restart.
2. As soon as the computer is turned on, press F10 when the monitor light turns green to enter
Computer Setup. Press Enter to bypass the title screen, if necessary. If you do not press F10
when prompted, a restart will be necessary.
3. Select Security > Setup Password and follow the instructions on the screen.
4. Before exiting, click File > Save Changes and Exit.
Restart.
3. Select Security > Power-On Password and follow the instructions on the screen.
Changing a password:
1. Turn on or restart the computer. If you are in Windows, click Start> Shut Down > Restart.
To change the Setup password, go to step 2.
To change the Power-on password, go to step 3.
2. To change the Setup password, as soon as the computer is turned on, press F10 when the
monitor light turns green to enter Computer Setup. Press Enter to bypass the title screen, if
necessary.
3. When the key icon appears, type your current password, a slash (/) or alternate de-limiter
character, your new password, another slash (/) or alternate delimiter character, and your new
password again as shown:
current password/new password/new password.
NOTE: Type the new password carefully since the actual characters do not appear on the
screen.
4. Press ENTER.
The new password will take effect the next time the computer is restarted.
Deleting a password
1. Turn on or restart the computer. If you are in Windows, click Start > Shut Down > Restart.
To delete the Setup password, go to step 2.
To delete the Power-On password, go to step 3.
necessary.
3. When the key icon appears, type your current password followed by a slash (/) or alternate
delimiter character as shown. Example: currentpassword/
4. Press Enter.
from
http://bizsupport2.austin.hp.com/bc/docs/support/SupportManual/c00794304/c007943
04.pdf
Feb 09, 2010 | Computers & Internet
Asus A6vm Laptop shuts down, the optical drive powers on its own.
Hello
Try to uninstall the software "asus instant fun" from add/remove software. Go start/controlpanel/addremove software.
Try to reinstall the software if you want it, maybe that gonna solve your problem.
You can also check your BIOS and see if you can Inactive the Music Button.
but try to uninstall it first, and restart your computer. then shut it down and see if it restart by it self.
make sure you do a full shutdown and not Hibernate or sleep mode.
Get back to me if it doesent help and we try something else
//Filip
Jul 09, 2009 | ASUS A6VM-Q066H PC Notebook
When i power down my notebook, windows is not shutting down completely which causes a long power up. it came pre-installed. when i turn my computer back on, a screen appears stating windows did not...
First, run a scan disk/check disk option. You usually get prompted for this upon a reboot.
Second, if that doesn't work, windows is smart enough to create a few restore points when new drivers/updates are installed. Open up an explorer window (like my computer or my documents, not internet explorer) and press F1 for the help display. Search for system restore. It's very user friendly, so it should be pretty easy to find it
Jun 11, 2009 | Microsoft Windows Vista Ultimate Edition
Suddenly closing windows
At first you go to the START & then go to CONTROL PANEL.Then select cclener and uninstall it. You must Shut Down then & Restart. Reinstall cclener. I hope this fix your problem.
May 01, 2009 | Microsoft Windows Vista Ultimate Edition
Automatically restart my computer.
You need to check the connecters to the motherboard the ones that come from the power button to the motherboard. Hope this helps!
Jan 12, 2009 | Computers & Internet
I am unable to connect to aol. Screen says invalid password. This has been going on for weeks. I have changed passwords numerous times. In the past the new one works for a few days, then the whole...
Hello!!!
Check Your Keyboard Connection, Then Restart Your Computer
Checking the connections and restarting the computer will make sure the keyboard is plugged in properly and the computer is correctly recognizing the keyboard.
To check the keyboard connection and restart the computer:
1. Shut down your computer:
* If using Windows® 98 or Windows® Me, click the Start button, then click Shut Down. In the What do you want the computer to do? section, choose the Shut Down option by clicking it, then click the OK button.
* If using Windows® XP or Windows® 2000, click the Start button, then click Shut Down. Click the What do you want the computer to do? drop-down menu to open it, choose the Shut Down option from the list, click it, then click the OK button.
2. Follow the cord from the keyboard to where it plugs into the computer.
3. Unplug the keyboard cord.
4. Wait for about 30 seconds.
5. Plug in the keyboard cord.
6. Turn on your computer.
Nov 05, 2008 | Computers & Internet
Computers & Internet Logo
90 people viewed this question
David Payne
David Payne
