Question about Compaq Computers & Internet
Installing Firewire !!
Good Morning, I have a Compaq Presario SR5502uk pc and need to connect this to my sony camcorder, the sony has I-Link, but my pc doesnt how easy is this to install and what do I need to buy - I am not the most competent PC`er in the world so as simple as possible !!
Many Thansk
  • 790 Answers
Hello!!
Install the camera drivers which is provided in the cd and connect it to comp.. as simple as it is ..
Thank you!!
Posted on Jan 12, 2009
I want to watch video from my camcorder on pc. My camcorder has a 4 pin ieee firewire port. How many pins does the compaq presario sr1420nx have for its ieee firewire port? Should I use 800mps cables
You are on the right track. The best way to hook your computer to your camcorder is the firewire connection. There are 4 pins on the small connection on your cam, but on the PC the firewire connection is bigger and has six pins on that end. You should get the best cable that you have access to, because speed is everything when you are dealing with video, I would get the 800mps. Just make sure to check your connections on the PC and the Cam to make sure you get the right cable.
Apr 30, 2009 | HP Compaq Presario SR1420nx...
Cannot connect handycam to laptop
this is a windows like solution, but it helped me.
Press hard on the cam and make shure that it connects the docking station.
Apr 18, 2009 | Sony DCR-HC32E DV Digital Camcorder
Connecting a Sony Camcorder to a Compaq Presario
Didn't actually find a solution. Looked at another HP notebook I have and found it has a 1394a port so I'll change computers.
Nov 28, 2008 | Sony Handycam DCR-HC40 Mini DV Digital...
Which cable do I need to conect my camcorder to pc
if you need a visual on it, there is a video on www.HandBookLive.com under Electronics. The example is Belkin IEEE 1394 cable (Firewire and I-Link compatable) and it connects digital camera to a laptop.
May 28, 2008 | Sony Handycam CCD-TRV78E Camcorder
Connecting Sony Handycam DCR-HC14E to iMac
There is a great manual here:
http://www.sony.co.uk/support/ShowExternalPage.action?product=DCR-HC14E&supportProductModelName=DCR-HC14E&linkType=manual&isRegistered=false&site=odw_en_GB&pageType=manualPopup&sectiontype=Support&externalUrl=http%3A%2F%2Fpdf.crse.com%2Fmanuals%2F3089850112.pdf&externalLinkType=manual
And in short the I.link is a 1394 port or firewire port
You should be good to go
May 02, 2008 | Sony Handycam DCR-HC14E Mini DV Digital...
My Compaq Presario X1000 doesn't recongize my camcorder via firewire port.
It may be the problem with driver. Your OS may not contain the proper driver.Like in windows service pack 1 do not recognise some camcorders. either upgarde to service pack 2 or download proper driver from manufacturers site
Apr 21, 2008 | Compaq Presario X1000 Notebook
I want to capture movie from dv tape to compaq presario notebook
You are mentioning that you are trying to transfer video though USB port, that is not possible, you have to connect the to the pc through the DV port from the camera to the Firewire port of the PC, if your PC doesnt have a Fire wire port, install a IEEE1394 firewire card in one of your PCI slots.
Dec 01, 2007 | JVC GR-D270 Mini DV Digital Camcorder
I need a driver for a digital video recorder camera. the model is sony dcr-trv10.
Sony's website says: "Some digital camcorders must be setup to output a signal through the i.LINK® port prior to being connected to a computer. Consult the instruction manual of your camcorder for specific information before continuing with the steps in this solution. Instruction manuals are available in the Manuals/Specs/Warranty section of the Sony® eSupport Web site.
  1. Ensure the i.LINK cable is connected securely to the camcorder and computer.
  2. Ensure the camcorder is turned on and being powered by the supplied AC power adapter.
  3. Ensure the video capture card and software are configured properly to receive the i.LINK signal from the camcorder.
  4. NOTES:
    • Depending on the video capture card and software you are using, you may need to manually configure the capture card and software to receive a signal from the i.LINK port. If applicable, check the Help files of the software or contact the video capture card or software manufacturer for further information.
    • Sony® digital camcorders are not provided with and do not require special device drivers for i.LINK connectivity. The device drivers that allow i.LINK connectivity should be provided with the video capture software. If the software you are using does not appear to have the required drivers, you will need to contact the software manufacturer.
Likely this is the case where the camcorder needs to be setup in order to connect to the Firewire port. This is done inside the menus. Windows XP and Windows Vista will detect a camcorder connected to a Firewire port automatically. Make sure your camcorder is powered up and configured before connecting it. Does your PC have a Firewire port? Many do not, PCI cards with firewire ports can be bought online or from local retailers. Some sound cards come equipped with one.
Nov 18, 2007 | Sony Handycam DCR-TRV110 Camcorder
Installing a firewire pci Card onto my HP Compaq dc5000 Small Form Factor PC
Hi, Actually there are various types of customized firewire connections for your computer. Here is a link to view some products that might work with your computer. http://www.firewire-1394.com/firewire-usb-combo.htm Also, there are different sizes of PCI cards available. You have to shop around to find an apropriate size.
May 04, 2007 | HP Compaq dc5000 PC Desktop
Computers & Internet Logo
26 people viewed this question
Top Compaq Computers & Internet Experts
Alun Cox
Lee Durbin
Lee Durbin
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
