Question about Daewoo DV-T8DN VHS VCR
Daewoo VHS to DVD converter - disk only plays on the converter
I have a Daewoo VHS to DVD convertor (sorry don't have the model name to hand) using the one touch transfer method I have managed to copy a VHS tape onto a DVD-R.
I can play the resultant disk on the Daewoo machine and all loks fine but on any other player ( I tried two others ) and on my PC the player is permanently stuck trying to load the disk with no error shown.
Looking on the disk there are two files created one of which is the film the other is empty. My guess is the empty file is the problem. Has anyone encountered anything similar and managed to resolve it please?
The Disc needs to be finalised. Using the setup menu and disc info you select "finalize disc". I had the same problem.
Posted on Aug 21, 2012
4 Suggested Answers
  • 883 Answers
SOURCE: My VCR is playing too fast
try recording on a blank tape and setting the tape speed to SP (standard play). you should also see options for (LP-long play) and SLP (super long play). I think your machine is stuck on SLP option. if no-go, look for a manual on the web.
Posted on May 27, 2007
Grubhead
  • 5444 Answers
SOURCE: I'm trying to transfer VHS
It's an screen display for the Hi-Fi sound playing. However it should only come on when first starting. If it keeps popping up during playback it means that the Hi-Fi sound is dropping out then coming back on. This is often caused by poor tracking or the result of dirt on the video head. Clean the head and see if that solves the problem. If you are doing a lot of tapes keep cleaning it. Few video's have the option to remove on-screen displays. However if they do it will be on the menu somewhere.
Posted on Dec 12, 2010
Grubhead
  • 5444 Answers
SOURCE: Daewoo DVT5DN - when tape
It's almost certain that some damage has occurred to the mechanism. This might be visible to the eye. Whenever a tape cannot be played the electronics will detech this and shut the unit down to prevent further damage. Cleaning will not make any difference unless some kind of object has become lodged inside the works. My advice is to look at any plastic parts connected with the 'playing' parts for breaks, or cracks, or even lose parts.
Posted on Sep 16, 2011
How do I make Daewoo vcr/dvd player play vhs tape play over and over?
you cant loop a VHS tape, they only run for as long as the tape is.
Feb 20, 2015 | Daewoo Televison & Video
My VHS-to-DVD Burned Disc used to work and now it doesn't
Richard,
It could be your disc is scratched or DVD+R can't be read in the DVD player. Check for any scratches. Then pop in the disc in to your PC DVD, to see if it's readable.
May 31, 2012 | Daewoo DV-6T834 DVD Player/VCR
Want to record VHS to DVD on my Toshiba DVR620KU but do not want to connect to my TV set. Is this possible? My TV is older and does not have the input/output jacks. I just want to put in a VHS tape and a...
If the entire VHS is full then you can easily transfer the VHS contents to the DVD. The video will play while it is recording onto the DVD, but you don't have to have it hooked up to any TV for it to record. Now if you don't know how long the VHS content is that you want to record to DVD, then you will have to hook up the player to a TV so that you can press stop when you reach the end of the content you want recorded. At least this is true in the way that I use to transfer VHS to DVD:
1) Turn on the unit
2) Insert VHS tape
3) Insert DVD-+R or DVD-+ RW
4) Using remote, press VCR
5)Using remote, press play then pause the tape where you want to start recording.
6)Using remote, press DVD
7) Using the remote, press DUBBING. The VHS should start to play and the DVD should start recording
When using this method, don't hit the RECORD button!
I hope this helps!
Sep 05, 2011 | Toshiba DVR620 DVD Recorder/VCR
I have old home movies on these tapes.. I am looking into buying the Pinacle Dazzle DVD Recorder (convert) will this convert my tapes to DVD? Does anyone know?
You already have Movies on TDK E-HG 120 VHS tapes; All you want is to Transform the media on the tapes into another record Media or on DVD.
The following process would make possible the project
1. A DVD Recorder device would transform the movies already on one media to another media.
Note: The recorder that would be acquired should have a feed area for the VHS tapes on one hand, to be played, while on the other hand, a DVD disk area from which disk medium would be recorded.
Important Notes.
The devices required to make the process achievable includes
1. The DVD Recorder or Player alsoo known with multi perpose functionality for signal convertion capability
2. The DVD recordable disks on which to record a movies onto.
Caution
The process of recording would require selection features determinable on the recorder device else would produce movies with undesireable features
For example; VHS movies are appear in decodeable formats integral when displayed on VHS players. The caution is to select a signal conversion format suitable for movies that have to transform between recordable media.
1. A DVD disk medium has formats as design specification and on which requires consideration when attempting to transfer multi media or motion pictures.
Type of formats of decodes
NTSA standards
PAL standards
Mescem standards
NOTE;
Whenever the option is available, select NTSA or PAL for appropiate code transformation
Your DVD RECORDER DEVICE SHOULD HAVE THE OPTION TO RECORD CONSIDERING MOVIES ACROSS MEDIUM TYPES
REMEMBER;
consult professional advise before acquiring an devices and mediums
If any consultation is required, refer to user guides or manuals of the devices in question.
Consult a technical expert when the need requires it.
Dec 02, 2010 | TDK E-HG 120 VHS Tape
Unable to connect dvd/vhs recorder to record via freeview box
Can you give me the model number of the dvd/vcr and set-top box?
Jan 03, 2009 | Daewoo DVRS04 DVD Recorder/VCR
Hooking up my DVD/VHS player to TV & Convertor box
I would just hook up the dvd/vhs player with the red,white,yellow rca cables that should of come with your unit and just go to the input on the tv to watch your dvd/vhs player. This will give you a better picture and sound while allowing you not to have to watch dvd/vhs on a channel which helps make the dvd/vhs player independent. Also if possible I would hook the converter box up with the red,white, yellow rca cables to the tv as well if your tv has more than one set of red,white,yellow plugs since it is a better connection that coax and you probably watch more tv than vhs/dvd anyway. So bottom line try to hook up both boxes red,white,yellow and watch each box on different inputs instead of like channel 3 or 4. Also to record of converter box you can run coax from converter box to dvd/vhs combo and make sure your dvd/vhs player is on tuner input or channel 3.
Nov 16, 2008 | Insignia Digital-to-Analog Converter for...
Daewoo DV-6T955B DVD Player Problem
If your DVD is less than a year old, still under manufacturers warranty.
The problem you have "no Disk" is because the laser is not reading the DVDs.
Call the Main support number at 800-323-9668
Support FAX 973-384-9250
Email support service@e-daewoo.com
Mar 06, 2008 | Daewoo DV-6T955B DVD Player/VCR
Mini dvd can be burned on a regular dvd, but cannot be played
convert them to normal format using file convertor or record in VR format instead of Video format
Oct 24, 2007 | Canon DC210 DVD Camcorder
NTSC to PAL
You have to buy first a VHS player that can play NTSC, might not be available locally in Ireland so you have to probably buy online (US). The DVD recorder is fairly comnon nowadays and all of them are capable of recording and playing NTSC and PAL. You can then connect the AV out of VHS player to the AV In of the recorder. Or you can use a VHS-DVD combi. You can google in UK, here is an example: Toshiba RD-XV45, according to the specs, it can play NTSC on the VHS and you can record to DVD on any format that yoou want You can go to this link to view other product: http://audiovisual.kelkoo.co.uk/b/a/sbs/100304323/16875665.html My father died of cancer 6 years ago and I am also transferring the Hi-8 videos to digital format using PC.
May 23, 2007 | Samsung SV5000W VHS VCR
Daewoo DVRS05 Recorded DVD won't play in OTHER DVD players
my suggestion from reading other forums is that these players sometimes have problems finalizing the disc.. you could try making a copy of the disc in a computer to see if this fixes the promlem or maybe media these use dvd+r and has a lot of compatibility issues with dvd players.
Feb 01, 2007 | Daewoo DVRS05 DVD Recorder/VCR
Daewoo DV-T8DN VHS VCR Logo
390 people viewed this question
Top Daewoo Televison & Video Experts
 Grubhead
Grubhead
Are you a Daewoo Televison and Video Expert? Answer questions, earn points and help others
