Question about LG LD301EL Dehumidifier
My LD301EL dehumidifier is missing a hose connector cap. How do I get another one.
This unit never had this cap. I am 82 years old and find emptying the water is too difficult for me. Please help.
  • 883 Answers
SOURCE: No water collection
compressor may be starved for freon or blockage in freon line...tech must troubleshoot.
Posted on Jun 08, 2007
SOURCE: LG LHD45EL Dehumidifier
Push through the membrane with the drain connector. The membrane has a circular cut almost all the way through it, and pushing at it with the drain connector will pop out the little hole. I've done it with four LG units.
Posted on Sep 23, 2007
  • 121 Answers
SOURCE: LG LD65EL dehumidifier will not collect water
Make sure the filter is clean and also make sure the coils are cleaned. If these are clogged they will restrict airflow which will cause the coils not to remove the humidity from the air. LG recommends that you clean the air filter every 2 weeks. They also include a brush to clean the coils. If this still does not work you will need to contact LG for service or a replacement. They have a 5 year warranty on them so the ones that you guys have should still be under warranty. Make sure that you have your reciept when you contact them to prove that it is still under warranty. Keep me posted. Also please rate my solution when you get a chance. Thanks - Tech101
Posted on Jul 08, 2008
SOURCE: Water from LG 30 pt dehumidifier drains into
(assumming you are not an idiot, like the other solver suggested) you may very well have it connected to the right spot, many of these units, are not balanced well, (or are balnaced all to well, depending on how you look at it) The imbalance, basically makes the water drip to the front, instead of the back. Try to put something under just the front of the machine, to tilt it back, ever so slightly. Good luck
Posted on Jun 26, 2009
heatman101
  • 43501 Answers
SOURCE: My dehumidifier LG LHD 45 EL runs, but does not
Here is a tip that I wrote about that problem...
http://www.fixya.com/support/r4662409-dehumidifier_running_but_no_water_in
heatman101
Posted on Apr 30, 2010
Challenger dehumidifier 710 left on all night water on floor none in the tank
Maybe there is a hose connection to the pan and it is missing its cap? I have an old Sears humidifier and always had a hose on it going to the sump.
Jan 18, 2018 | Dehumidifiers
Why does water leak onto the floor instead of draining into the tank?
The hose connector should be capped or a hose connected and directed to a floor drain.
Apr 29, 2015 | Amana D930M 30 Pint Dehumidifier
I have a Danby dehumidifier model DDR6011R and it runs but I have yet to empty any water from it. I have used other dehumidifiers in the same area and they take out tons of water. What's the problem
1st ck your humidistat settings yes the fan can run but not the compressor to take water out
2nd ck your filters could they be blocked ?
and last but not least if the unit is more than a few years old its not as efficient as newer units and will take much longer to work consider an upgrade to a newer unit , also moisture levels in basements vary due to season , winter not as damp as summer so volume of water removed will change
use an external humidy gauge to verify it working correctly there not so expensive now and can be gotten most places that sell dehumidifyers 70 % rh is considered normal
Oct 18, 2014 | Dehumidifiers
I have a Haier dehumidifier, model DE45A-L and recently it has started leaking water and not collecting in the bucket. When we dump the water out it seems to just come from everywhere in the front. The...
There may have been a failure in the area where water is collected and directed to the bucket but also check to determine whether the bucket is reinstalling correctly after it has been emptied.
Sep 02, 2014 | Dehumidifiers
No lights on controls but power at theplug willnot start ?
? power at the plug, so power at the socket, but not in unit. check unit fuse in plug, check for fuses on unit, usually at back near to power inlet
Aug 13, 2014 | LG LD301EL Dehumidifier
My basement dehumidifier runs but extracts no water from the air. It worked when I first turned it on in June but I only emptied it once. In the past I emptied it every day in the summer. Do I need a...
Gayle, your unit has some age on it, but it may still be salvageable .
There are 5 basic, but solvable reason for what you described. Please pay particular attention to numbers 1 & 2..
1. The humidity extraction level is set to HIGH. Lower it to 32-35%. Or set to Maximum if yours
is a manually controlled unit.
2. Air intake filter is dirty or clogged. Turn unit OFF, & Unplug the
Unit, before removing to inspect & clean it, if necessary. If washed,
allow filter to completely dry before reinstalling. DO NOT operate
the unit without the filter.
3. Obstructed air flow. Maintain a minimum of 12 to 18" of clear air
space around the entire unit.
4. Cooling coils are dirty and need to be cleaned. Use warm water & dish washing liquid to
clean the coils. Rinse and wipe dry. Apply a light coating of WD40 to the coils.
5. Ambient air temperature at floor level is between 40 - 60 degrees.
dehumidifiers do not work well between those temperatures
(Unless, you have a Low Temp Unit). This applies mainly to
where the air temperature at floor level is colder than at shoulder
level
in basement applications. Raising the unit up off the floor,
onto a sturdy table, counter top, etc, that can handle the weight
of the unit, plus a full tank of water, will usually resolve this
problem.
If none of the above solves the problem, it may be a case of the compressor needs to be recharged with refrigerant gas or that the humidity condenser sensor has failed. These things usually occur in units that are 5 years old or older. As far as repairs are concerned: The unit is 14 - 16 years old and the cost to repair, may be as much (or close to it) as purchasing a new unit. If you decide to purchase a new unit, be sure it's a "Low Temperature" model, as yours is being used primarily in a basement application.
I hope I have helped you and thanks for choosing FixYa.
Jul 24, 2011 | Whirlpool Dehumidifiers
Cannot connection drainage hose because of blocking cap. Do I have to disassemble whole cabinet?
The cap should just screw off the hose connector. You may have to carefully drill a 1/4" hose in the center of the threaded hose connector, once the cap is unscrewed. Some models require that, others don't.
Jul 08, 2011 | Haier 45-Pint Dehumidifier
LG LD301EL Dehumidifier Logo
83 people viewed this question
Top LG Dehumidifiers Experts
Bill Long
Craig Butler
Craig Butler
Gil Shultz
Are you a LG Dehumidifier Expert? Answer questions, earn points and help others
