Question about Toshiba REGZA 42 in. Flat-Panel LCD HDTV
There are lines through the screen (red and blue) like the screen is cracked but the screen s not cracked as far as i can see
    Top Expert:
  • Toshiba Master
  • 14,553 Answers
If the set got struck on the screen the screen itself may not be cracked but the panel (The entire front where you view the image is called a display panel) may be damaged inside.
A good photo would tell me--usually it will look like a odd burst or lines and or colors more pronounced where the screen was hit and spreading out in a uneven pattern---Google for "Pictures of Damaged LCD or Plasma screens"
Posted on Dec 06, 2012
Fixing color convergence red and blue lines
most TVs have an adjustment for convergence in your on screen menu, go into convergence of service menu & try to adjust; it it is still too far out of convergence contact a service technician as convergence issues can be very difficult to resolve unless you are very sure of what you are doing.
Dec 26, 2014 | Televison & Video
Crack inside screen blue red green lines
You have cracked your LCD screen (the screen that displays the picture). The glass on top of it is called a Digitizer Screen (the screen that recognizes your finger). This is a fixable problem, but the cost to repair will depend on the phone, insurance or lack of, and who you get to repair it for you....hope this helps you some.
Nov 28, 2012 | Cell Phones
I have a Hitachi 43FWX20B. I can see the red is not lined up with the blue and green on the far left side of the screen. Only the red and only on the far left side of the screen. Blue and Green are OK. I...
Please do us a favor and rate this by cliking the thumps up icon located here >>>>>>
Projection TV sets have two very common problems. One is convergence ( 3D/Warped video) the other is CRT fluid ( Dull Video). Below are more details for both items. Also, complete repair kits with instructions and repair support are avail from site such as www.TvRepairKits.com
Common Problem #1) Convergence has gone out
Projection TV sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
This is a very common failure on these projection sets and a fairly simple DIY fix. All projection sets including Samsung, RCA, Sony, Philip Magnavox, Panasonic, Pioneer, Akai, GE, JVC, Toshiba, and others at some point will have the same problem.
Common Symptoms include....
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
  • TV shuts off after powering on. Power light will blink. TV may also make a chirping noise.
Here are some pics of convergence problems.
69189a5.pngSOLUTION #1
For more more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Common Problem #2) CRT Fluid is Cloudy
Projection TV tubes have a liquid coolant that is used to keep them from overheating. After many years the coolant in the blue and green tubes will become cloudy and cause the screen to look dull, red/orange, etc. You may even see halos around images.
Picture of a set that needs the fluid changed.
TV set after fluid change
69189a5.pngSOLUTION
You can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Jun 02, 2011 | Philips Magnavox 9P6034C 60" Rear...
Hi my monitor has bright colours on it and i cant make out what im doin its really bright and hurts my eyes
Turn off the pc but leave the monitor on. unhook the monitor from the pc. the screen SHOULD run a "self test" with a moving white green red blue box. if that box is on a bare black screen and there are no bright spots or cracks or anything weird looking, then the screen itself is ok. If however, you see odd shades of blue and pink and it looks cracked or scratched or has lines in it, then it is time to replace that screen.
Nov 10, 2009 | Dell E173FP 17" LCD Monitor
Screen has lines
Most likely youve damage the lcd screen either by dropping it even though you didnt, but that would be the only cause this problem, line on a lcd screen are usually cause by a broken power current thru screen or a cracked lcd screen maybe it was defective in the first time. I dont know, but line are usually means no power or no information going thru screen.
need to be replaced.
Jun 27, 2008 | Kodak Easyshare M753 Digital Camera
Blue and red arched lines on screen when background dark
Sounds like you are describing retrace lines that could indicate that your CRTs or something in the drive circuits are bad.. Check the resistors on the CRT sockets to see if they are in tolerance. If they are try turning the red and blue screen adjustments down just a little this should take the lines away. You will however be needing service in the not to far future. Turning the screens down should help if the resistors check out. Let me know if you need anything further.
Jan 31, 2008 | Sony KP-48S35 48" Rear Projection...
Mitsubishi VS 4552A
One of your convergence IC's has either cracked loose or burned out. The IC will have to be resoldered or replaced and then the convergence circuits realigned. If you do not have experience in repairing convergence circuits then have a qualified tech handle it for you. This is by far the most common failure in the projection sets and a good tech can have it fixed in about an hour and a half. I charge $150 for that but shops in your area will vary, so call around.
Jul 30, 2007 | Mitsubishi VS-45607 45" Rear Projection...
43H70 Blue Convergence out of line and will not line back up
If the blue colors will not line up, and the blue appears to sag inward from one or more sides, then you can bet that one of your convergence IC's has either cracked loose or burned out. The IC should be resoldered or replaced and the convergence realigned by someone experienced with projection TV convergence circuits.
May 21, 2007 | Toshiba 43H70 43" Rear Projection...
Three seperate colors on Screen
Screen may have a hair line crack in it causing projection to be distorted. Inspect screen very closly with magnifying glass if necessary to insure no cracks. If crack is found replace screen.
May 18, 2007 | Zenith R40W46 40" Rear Projection...
Faint red lines in a curved arch like pattern
Guys I did this myself real easy. Just don't turn the corresponding screw too far. Only need to adjust it until the lines go away. Do it on a darker screen so the lines are more visible. I did the red 2 years ago and the green 6months before that. The blue lines are coming on my screen now and I've fixed it in 10 minutes. The TV is amazing.
Apr 10, 2007 | Sony KP-51WS500 51" Rear Projection...
Toshiba REGZA 42 in. Flat-Panel LCD HDTV Logo
175 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
