Hi i get new asus rampage extrim x48 moboits have temperature probes where and how i must instol them thanks for help
  • 28 Answers
Do a google search for "Motherboard Monitor", with this program you will be able to monitor the output from all the sensors on your motherboard.
Posted on Jan 13, 2009
I have a Asus Rampage Formula board w/ 4gig mem, was running a BFG GTX 260 max core nvida card , win XP pro 32 bit sp4. I have had no issues for about 1yr then when the computer would run for a few hrs the...
Mabee the hard drive has failed . try entering bios and see if the hard drive is recognised .If not try turning the computer off unplug it then reconnect the drive data cable and power cable
then re- start the computer and see if it is recognised. some models of older hard drives needed a driver installed during set up -- you usually have to put the driver on a floppy disc and hit the f6 button when prompted by windows set up to install third party drivers . I hope this helps
Apr 08, 2011 | ASUS MB RAMPAGE FORMULA 775 X48 RT...
Asus p5e3 freezes at POST.
Hi David,
Maybe you could buy a new CMOS battery and replace the old one..
Might be worth a try..
Hope this helps
Chris (ziraffa)
Jan 09, 2009 | ASUS MB P5E3 PREMIUM/WIFI-AP X48 RT...
Cannot install the audio driver, my computer no sound
Hi nenmacil, suggest you disconnect any other sound device jacks when installing the supremeFX II software. Asus boards use auto jack sensing software.
Disconnect your other speakers. You also have the option for live chat from Asus: http://livesupport.asus.com/
Your board is very new (2008). Check with a pro from Asus.
Or call tech, M-F, 8:00AM to 5:00PM EST at: 1-812-282-2787.
Good luck nenmacil!
Thank you for using fixya.
Mike
Dec 11, 2008 | ASUS RAMPAGE FORMULA LGA 775 Intel X48 ATX...
Can I run two EVGA GeForce 260 GTS cards in crossfire on an ASUS Rampage MOBO?
This is an excellent question, basically "Can you run two Nvidia cards on a cross fire motherboard in a SLI configuration". My first thought was "No" but you should be able to still run a single Nvidia card.
From everything that I have collected the above is correct. Here is a reputable site that you can trust which has a spill on whether you can do this: http://www.tomshardware.com/forum/246903-33-nvidia-graphics-card-crossfire-motherboard
Oct 03, 2008 | Computers & Internet
F30 Erorr on stove...
The fault code shows that your temperature probe opened.
1. Check resistance at room temperature & compare to RTD Sensor resistance chart.
If resistance does not match the RTD chart replace RTD Sensor Probe.
Check Sensor wiring harness between EOC & Sensor Probe connector.
2. Check resistance at room temperature, if less than 500 ohms, replace RTD Sensor Probe. Check for shorted Sensor Probe harness between EOC & Probe connector.
Jun 29, 2008 | Frigidaire FGB24S5A Gas Single Oven
Error 211, 212!!!
Hi Antonyo,
The codes you are getting (211- 212) relate to the boiler tank behind front panel.
210 Temperature probe short circuit Check probe cable (plug contacts)
Replace probe(rinse tank)
Install probe correctly
211 Temperature sensor interruption See 210
212 Actual boiler temperature too high Contactor welded
Incorrect sensor / defective sensor
Check probe / cable (Contact plug II XA5)
Hope this helps ,regards KIT
Jun 06, 2008 | Meiko DV 80.2 Dishwasher
Computers & Internet Logo
44 people viewed this question
David Payne
David Payne
