Question about SAMTRON 55V 15" CRT Monitor
Monitor looses contact with computer
I am using your SAMTRON 73V flat monitor 4th year. Several month ago it did start to block after more than one hour time of use. The time of proper work did gradually drop down, to recent about 10 minutes, what is to short for doing any taks.
The blocking of the monitor appears as: moving round the screen a warring window with message 'not optimum settings, use 1280x1024x60Hz' by total lack of contact with the computer.
It is not possible to change actual settings using monitor keys.
After switching off the terminal for not less than about 10 min. and resetting the computer, the terminal can work properly next 10 minutes.
The optimum settings (shown in the warring window: 1280x1024x60Hz) of the terminal adjusted from Windows control panel do not allow to get proper work of the terminal in any future attempts.
The workshop:
VIDEO SERVICE
os. Pod Lipami 1d
61-628 Poznan, Poland
e-mail: avts@wp.pl
tel: +48 61 8205688,
told me one hour ago that they are unable to find proper integrated circuit to be replaced. They would expect to solve this problem if you send the electrical scheme (diagram) of this monitor on their address (regular or e-mail) given above.
Boleslaw Porankiewicz
os.Rzeczypospolitej 90/7
61-392 Poznan, Poland
Check the video card if it is properly inserted.
Posted on Jan 13, 2009
I am using samtron 56v monitor since 10 years, since 6 months I am facing problem in switching on the monitor, i have to press the knob or fix some packing to knob how to solve other wise mointor is w
Sounds like the power On/Off switch has been damaged. Replace it. If you wish to get some details; check the site linked here. Viewing it in "Mosaic" or "Magazine" will make surf easy. Pull up older posts. Surf the site with patience. Do a search by type in the brand name of your device at its search box.
Jun 09, 2014 | SAMTRON 55V 15" CRT Monitor
SVA 15" FLAT SCREEN MONITOR
maybe you have defective parts in oscillation circuit! in hotside of the power supply! or maybe you have loosed contact at the main board!
Oct 28, 2007 | SVA-USA SVA VR 15A 15" Flat Panel LCD...
Samtron 56v monitor
Problem may with VGA cable or Dry solder at Monitor RGB Video output Neck board, power supply SMPS of monitor & power switch. you better contact nearest TV Service Technician to repair your monitor.
Apr 14, 2014 | Computers & Internet
Black screen with box of 'Suggested resolution 1280 x 1040 60Hz'
The Samtron 73V has a maximum resolution of 1280*1024, are you running at that resolution ?
Mar 15, 2009 | Computers & Internet
Monitor Samtron after 10min. looses contact with computer
This problem is caused by the Novatek chip on the video board. Soldering a 50 Ohm Resistor across pins 5 and 6 of this chip resolves the problem on both the Samtron and the Samsung monitors. I have just corrected one of these last night by this means.
Hope that helps
Jan 12, 2009 | Samtron Computers & Internet
Color problem
There are three Cathod Ray guns responsible for the millions of colors.All colors are produced by mixing the three basic colors namely Red Green and Blue (RGB) at suitable proportion. If any one of the three guns fail firing then we get improper colors. This can be rectified by
(1) hitting the monitor at the back by keeping it on a pillow the screen facing down - it will reolve the problem if the failure is due to the loosening of the Head due to repeated thermal expansion and contaction.
(2) check the signal cable for loose connection, twisting etc on both ends - at the back of the CPU and Monitor (it is fixed)
TRY YOUR LUCK
ProfSweetlin
danielswweetlin@gmail.com
Jul 15, 2008 | Samtron 76df 17" CRT Monitor
Samtron 15" CRT monitor gone dark but readable!
Go to a computer fair and get a flat screen monitor for around $195 dollars. Why even keep this anicent artifact in todays new screens?
Feb 28, 2008 | SAMTRON 55V 15" CRT Monitor
Red color problem
As you are not able to see red color on your monitor means you will be seeing green+blue=cyan color your problem is that red signal is not coming to red cathode of your crt. please check 1 connector loose(cpu to monitor) 2 crt base loose. 3 loose or print or dry near red cathode circuit 4 red video output. 5 red signal from processor to red video is missing 6 processor ic. good luck
Sep 27, 2007 | SAMTRON 55V 15" CRT Monitor
Display color has been changed to rainbow.
AS hit the monitor on its top the color changes to normal. so what can i do AS IT COMES TO normal position after hitting that cleary indicates that there is no parts failure. 1 there is a loose contact in or near crt base. 2 loose contact in connector. 3 computer to monitor cable loose.
Sep 15, 2007 | SAMTRON 55V 15" CRT Monitor
Samtron Monitor 56v 15''
samtron 56 v problum: switch on the monitor no ON, but two or three times switch on now ON. what is the problum
Sep 06, 2006 | SAMTRON 55V 15" CRT Monitor
SAMTRON 55V 15" CRT Monitor Logo
232 people viewed this question
Top Samtron Computers & Internet Experts
Daniel Sweetlin
Daniel Sweetlin
Level 1 Expert
Richard Lilja
Richard Lilja
William Miller
William Miller
Are you a Samtron Computer and Internet Expert? Answer questions, earn points and help others
