Question about Whirlpool Dryers
My whirlpool electric dryer will start and heat up perfectly, but once it gets going it flips the fuse. I had an electrician here saying that we only have 100 amps going through the house which is part of the problem, but that there is also something wrong with the heating element. My question is, if it heats up properly, what could be wrong with the heating element? I do not mind getting a new one I just want to make sure that it is indeed the problem.
    President:
  • Whirlpool Master
  • 1,922 Answers
First,remove front cover,then remove wires to the heater element and tape them so they cant short out to the case or together,then start the dryer and see if it stays operating,if so then the element is shorted to the element housing and tripping the breaker/fuse,if it still trips the power,then it could be the motor is tightening up from old age and drawing too much current and tripping the power
Posted on Dec 07, 2012
  • 156 Answers
SOURCE: Newer Whirlpool Dryer Heat Element keeps breaking
  • clean out the dryer vent make sure hose behind dryer not pinched close ck the temp comeing out bac k dryer should be around 160
Posted on Mar 06, 2008
protek480
  • 1714 Answers
SOURCE: whirlpool leb6000pq1 not heating
Thermostat controls heat. There is also a
motor centrifulgal switch, in the element
circuit, that the motor closes to insure
the motor is turning. Try another heat
setting. There is more than one
thermostat. You may have blown the
'thermal fuse' too, which requires
replacement. The elecment has a contact in
the 'timer' circuit too.
It is possible that your element has
failed also.
Tripped high limit. Must clean the lint
filter and the exhaust vent tube and all
the way in to the dryer. Hot air exit is
restricted.
Posted on Jul 12, 2009
aasc
  • 1606 Answers
SOURCE: Gas dryer not maintaining heat. 70 Series Kenmore/Whirlpool 76722
Fuse is ok . Problem is the soils on the burner valve . If the dryer heats when started , the electricity goes thru the coils to open the valve . Once the coils get warm , 1 will open (short) until it cools back down . The coils can be replaced just by removing the front panel . Only 2 screws hold the coils in place . No turning off gas , dissasembling dryer .
Posted on Jul 19, 2009
hiltonjug
  • 612 Answers
SOURCE: LER4634EQ2 whirlpool electric dryer. heating
I know this might sound stupid but try this. Find your fuse box, locate the breaker that runs your dryer. Flip it off and then back on. If i'm correct, it will work. Everything on your dryer works off of one leg of the 220v. The other leg goes to the other side of the element. If you have a meter. check for 220v at the plug. Everything you listed is what makes the dryer heat other than the thermostats. Check the cycling thermostats like you did the other pieces. They look like the thermal cut off. They have two wires and they are round.
Posted on Oct 10, 2009
sleprocks
  • 147 Answers
SOURCE: My Whirlpool Dryer LER4634JQ1 (no heat)
most likely a thermostat that has failed, I'm having same problem and am just now learning how to test. research " testing dryer thermostats and fuses online"
Posted on Oct 21, 2009
Whirlpool electric dryer will not start when start knob is pushed
First check beaker flip it off than back on next check the door switch if tab missing or loose it should spring back when pressed next the dryer may have over heated the thermal fuse may have blown
Nov 03, 2015 | Whirlpool LER4634J Electric Dryer
It will not turn on...we have flipped the breaker and also checked the wiring and made sure it was completely plugged in.
If your dryer's door switch is defective, it will not allow your dryer to start. Test your dryer's door switch. If it is defective, replace it. A dryer cannot start if its start switch is defective. Test your dryer's start switch. If it is defective, you will have to replace it for your dryer to start again A thermal fuse is a heat-sensitive fuse attached to your dryer's exhaust duct (in most models) that is designed to blow if the dryer overheats. A blown fuse would cause your dryer to not heat, or to not work at all. Open up your dryer's cabinet and locate its thermal fuse. Test the component. If it has blown, replace it. These are the first things you want to check , once you have,, or if you need help in knowing how to check them, feel free to contact me here,, and I'll help you with that , its fairly easy
Jun 09, 2011 | Whirlpool LER8648P Electric Dryer
Whirlpool AWZ7303 condensing tumble dryer . Drum not turning although it is heating
If your Whirlpool dryer has mysteriously stopped producing heat, a blown thermal fuse may be the cause of your problem. In Whirlpool dryers, thermal fuses are safety switches that are designed to disrupt the flow of electricity to your dryer's heating mechanisms once the dryer reaches a predetermined maximum temperature, usually somewhere around 180 degrees F. Thankfully, troubleshooting the thermal fuse in a Whirlpool dryer is easier than it sounds. Instructions:
  • Clean out the lint screen in your Whirlpool clothes dryer. Lint buildup can cause your dryer to overheat, triggering the thermal fuse to disrupt power to your dryer's heating mechanisms. Take the lint screen out of your Whirlpool dryer and wash it in warm water. Dry the screen thoroughly before replacing it.
  • Look behind the dryer to check its flexible exhaust hose for kinks or obstructions. Disconnect the exhaust hose from the back of your dryer and clean out any lint that has built up.
  • Go outside and check your Whirlpool dryer's exhaust vent for obstructions. Lint buildup, bird nests or other obstructions in the outside exhaust vent can trigger your dryer's thermal fuse.
  • Disconnect your dryer from its power source before attempting to access its thermal fuse.
  • Access the thermal fuse in your Whirlpool dryer by removing the back panel. Remove the screws that hold the back panel in place and it should easily come free.
  • Look between the dryer's blower housing and exhaust to locate its thermal fuse. The thermal fuse in a Whirlpool dryer looks like a white plastic strip that has two wires connected to it.
  • Bypass the thermal fuse in your Whirlpool dryer while you perform a quick diagnostic test. Use electrical tape to tape together the two wires connected to the thermal fuse. Reassemble your dryer and plug it back in. Set the dryer to a timed heated drying cycle and press "Start." If the dryer produces heat with its thermal fuse bypassed, it means the thermal fuse needs to be replaced.
  • Replace a blown thermal fuse in your Whirlpool dryer. Disconnect the power and remove the back panel. Remove the electrical tape that you used to perform the diagnostic test and disconnect the wires from the thermal fuse. Remove the screws that secure the thermal fuse to the dryer and discard the blown fuse. Attach the replacement thermal fuse by replacing and tightening the screws. Attach the wires to the new thermal fuse.
  • Apr 20, 2011 | Whirlpool AWZ7303 Electric Dryer
    Quit heating. when we flipped main breaker and turned it back on the power is not getting from outlet to dryer. What can we do?
    This is the most common locations for thermal fuses and heating element on Whirlpool,Kenmore,Estate dryers. Check these fuses for continuity and replace the one that does not have continuityseth765.jpgseth765_0.jpg
    Jan 22, 2011 | Whirlpool LER4634J Electric Dryer
    Won't heat
    Visually verify household fuse blown or a circuit breaker tripped.
    The drum may be turning, but you may not have heat. Electric dryers use 2 household fuses or circuit breakers. Replace the fuse or reset the circuit breaker.
    If the problem continues, call an electrician.
    Good Luck and have a nice day.
    Rating the solution is highly appreciated.
    Jun 16, 2010 | Whirlpool LER5636P Electric Dryer
    Dryer heat not working
    Jun 16, 2010 | Whirlpool GEW9200L Electric Dryer
    Whirlpool 465 electric range won't heat but has lights
    make sure the wires going into the breaker box for the oven are TIGHT. there should be one screw for each of the 4 wires. two on the breaker and two on the busbar. if they are tight, get a meter and measure the voltage coming out of the breaker. measure across the two screws that you checked for tightness earlier. it should be about 220 to 240 volts. if this all checks out the problem is most likely at the range or the connections there. just make sure you shut off the power to the breaker when you tighten the screws with a flat blade screwdriver.
    Oct 10, 2009 | Whirlpool Kitchen Ranges
    LER4634EQ2 whirlpool electric dryer. heating element,thermal cut-off, and high limit are all getting continuity, but heating element still will not heat up.
    Oct 09, 2009 | Whirlpool LER4634J Electric Dryer
    Jul 14, 2009 | Whirlpool Dryers
    Whirlpool Dryer not heating
    first check the circuit breaker in the house, turn it off then back on. if that does not do it then let me know so we can go to the next step. Mike
    Jul 14, 2008 | Whirlpool LER4634J Electric Dryer
    Dryers Logo
    Top Whirlpool Dryers Experts
    Dan Webster
    Dan Webster
    Tim Whalen
    Sal DeAngelo
    Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
