Question about Hotpoint Washing Machines
Why will my hotpoint ultima WT640 not spin propley
4 Suggested Answers
HansPP
  • 2510 Answers
SOURCE: Hi we have a hotpoint
That fault code means "Short circuit motor triac" and the given solution is "Book a washing machine repair"
Posted on Feb 17, 2011
Daniel S
  • 4323 Answers
SOURCE: hotpoint ultima wt640 am getting
Hi Error F5 means that the pressure switch is jammed on full. This may have happened due to blockage or obstruction in drain hose. To be sure check whether hose is plugged, if not then remove lower rear panel of the washer. Now you would be able to see drain pump and a large black hose on bottom of drum. Remove the hose from the pump; remember to keep a container near you to collect the water from the filter/pump. Remove and clean the drain filter connected with the pump and hose. Clean the pump and let it dry for a while. Now restart the washer after 2-5 minutes and your issue would be resolved. Please post back for further assistance. Hope this helps... Daniel
Posted on Mar 26, 2011
ZJLimited
  • 17970 Answers
SOURCE: What does the code f-05
F05 measn some blockage, check and clean the filter at the front; remove the top cover of the machine,(power off) and disconnect the flexible hoses from the dispenser. Check if theyre blocked. The dispenser itself can be seperated - generally held together with plastic clips. Clean out any crud or hardened detergent.
Fabric conditioner is taken from the detergent tray by siphon action. Most likely flexible siphon pipe is blocked. Remove machine top, identify the pipe coming from the softener compartment, detach and clean.
Hope helps.
Posted on Apr 15, 2011
Model number wt640 is flashing f-02
This is a overheated pump replace pump or clear blockage to let pump run faster as slow pump can give a f-02 fault
May 12, 2014 | Hotpoint Ultima WF865 Front Load Washer
WT640 Not completing spin cycle.
thats a front loader
the user manual might have the error codes listed
think its a direct drive model
only part of that description suggests its the printed circuit board
are you using a surge protector at the wall power point
Hotpoint WT640 Instructions For Installation And Use Manual
Apr 01, 2017 | Washing Machines
Hotpoint washer wt640 front filter cover stuck
We had to use brute force, pliers and lots of wiggling back and fore. When we eventually got it out, about a pounds worth of small change and lots of gunk blocking the way.
Spin now working, f05 gone. Very happy as hotpoint wanted 95 pounds for a call out.
Good luck all.
Jul 29, 2012 | Hotpoint Washing Machines
Hotpoint ultima wt640 am getting a flash code f-05 clothes still wet appears not to spin
Mar 26, 2011 | Hotpoint Washing Machines
My Hotpoint wt640 has an error code F-05, what does this mea and what should i do??
My Hotpoint wt640 has an error code F-05, what does this mean and what should i do??
Feb 21, 2011 | Hotpoint Washing Machines
My wt640 hotpoint washing machine wont spin and says f-05
F05 - Pressure switch jammed on full - Check pump for blackages. Also check the drain pipe 2 so that it can drain out. if you have checked for blockages and can not find any reset machine by switching off at plug for 5 mins then back on and try again hope this helps.
Sep 28, 2010 | Hotpoint WF645 Front Load Washer
On the final spin the washing machine is so loud you cant even be in the same room as it, it is not vibrating externally as far as i can tell
Remove rear access panel, and remove the drive belt.
Spin drum by hand, and if it feels rough or noisy, then the main drum bearings have failed, if no noise, then check motor for noise, if no noise, check the concrete wieghts are not loose, and that the dampers are not broken or worn.
Please rate my solution.
Thanks.
Nov 07, 2009 | Hotpoint Aquarius WD640 Front Load...
Washing Machines Logo
13 people viewed this question
Top Hotpoint Washing Machines Experts
puggy666
Level 1 Expert
ptpumpman
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
