Question about Car Audio & Video
How to wire up my clarion amplifer vnet series 275
I need a wireing diagram to help me install this amp and sony cdx-gt280 car stereo into a vt commadore ute 2 speakers and 1 sub woofer
mixmaster
  • 626 Answers
SOURCE: i need a wireing diagram for sony cdx-l580x
Found it HERE.
Best of Luck.
Please RATE my solution BELOW.
Posted on Nov 28, 2007
Cerfer39
  • 709 Answers
SOURCE: sony cdx-gt170
Hi MalJars,
Clarion normally uses the following colors for each channel.
Front Right Gray and Gray/Black -
Front Left White and white/black
Rear Right Purple and purple/black
Rear Left Green and Green / black
Yellow is memory backup Stays at 12 volts all the time
Red is Switched power and comes on only with Key on.
Posted on Nov 30, 2007
perryhawk
  • 13 Answers
SOURCE: Got a used Audiobahn A1300HCX
get in touch with a pro! that lot needs to be fitted properly
good luck
Posted on Aug 05, 2008
  • 33 Answers
SOURCE: I need a wiring diagram for a Sony CDX-GT320 car
Sony has manuals on their webiste.
http://esupport.sony.com/US/perl/model-documents.pl?mdl=CDXGT320&LOC=3
Posted on Mar 02, 2009
etirbynnor
  • 655 Answers
SOURCE: Subwoofers won't work and they are brand new
I've got a pair of these MTX's subs powered from a Fusion 450 watt 2-channel amp. For the price, they are great. By the way, they are 4-ohm.
My first suspicion would be that something in the first incorrect wiring damaged either the amp or the subs. Can you explain specifically what the "installing the subs incorrectly" means? Was the amp output shorted out at any time or was it operated without a load? Either of these conditions will fry an amp and sometimes, the protection circuitry doesn't work either.
First make sure that your amp is still working. Check both the primary power fuse, usually located near the vehicle battery, and the fuses on both sides of the amp. Make sure that when you turn the system on, the power light comes on steady (blinking is protection mode). Test your subs one at a time on a speaker output.
Posted on Mar 30, 2009
12 volts to amp, when connected no volts, it turns on in my friends car.
The ampliflier require an amount to power volts to perfrom. You friends car may have a power stabilier installed to produce appropiaet supply to stereo systesm. usually, a direct wire from the engine to the amplifer may least function as manufacturers default specifcation. If the amplifer performs at all, a fuse is blown to protect the devices in wiring cuircuits. if the device functioned in another car, it is not damaged. Consult with an auto electrician to attain appropiate wirign or acqurire the component parts to wire the vehicle. Important notes. Each device usually will have an instruction on installing. However, the power source from engine depending on type of vehicle may require regulators to share the current to stereos amplifiers and speakers.
Jan 29, 2011 | Clarion APA450 Car Audio Amplifier
CDX-RA700 CD Player: My wires on my sony CDX-RA700 do not match my 2005...
The following should help you. Good luck. Please rate. Radio 12v orange + radio harness Radio Ground black/orange - radio harness Radio Ignition yellow + radio harness Radio Illumination brown/white + radio harness Factory Amp Turn-on lt. green + radio harness Power Antenna gray + radio harness LF Speaker +/- tan - black +,- radio harness Notes: If equipped, the amplifier is in the passenger side of the trunk. RF Speaker +/- blue - red +,- radio harness LR Speaker +/- white - brown +,- radio harness RR Speaker +/- orange - green +,- radio harness
For the stereo the following will work.
May 07, 2010 | Sony CDX-RA700 CD Player
I need wiring diagram for CDX 4000X
Here is a link to Sony for your CDX-4000X wiring pin outs with color code.
http://www.docs.sony.com/release/specs/CDX-4000X_Spec_Sheet.pdf
Dec 06, 2009 | Sony CDX-4000X CD Player
Clarion stereo in1997 mercury marquis wiring hook up to amplifer
make sure the speaker wires in the car do not have one side grounded.the output on the clarion is a floating output and cannot be grounded.the best solution is to look at the wiring on each of the speakers,and match them out to the ones on the clarion.the most common colr code is white front left,gray front right green rear left and purple rear right.each speaker has a plus and minus.mixing them up will result in the speakers being out of phase and result in poor bass performance.i would wire the wires directly to the clarion using crimp connectors.the first thing i would do is power up the stereo out of the car to 12 volts,and using a speaker make sure you have sound coming out.the yellow wire which is the clock/memory is a must to be connected to constant 12 volts or no sound can result
May 26, 2009 | 1997 Mercury Grand Marquis
Help
If you are looking for wiring diagram of CDX-F7005X..
Click Sony Support to download required wiring diagram.
If Sony car stereo model is different, let me know to help you out.
Feb 14, 2009 | Sony CDX-F7005X CD Player
Clarion radio wiring diagram
please help what wire goes where?? need a wiring diagram or manuel to install. clarion xmd1 marine am fm cd player
Mar 18, 2008 | Clarion DB245 CD Player
Sony cdx-gt170
Hi MalJars,
Nov 30, 2007 | Car Audio & Video
Wiring diagram for a ford raider
According to FCC law all aftermarket sterio equipment has to have the same code, they may be diffrent
as for the ford
Black Wire - Ground Black With White Stripe Wire - Right Rear Speaker Light Blue With Red Stripe Wire - From Light Switch To Radio (light) (Headlights) Light Green With Yellow Stripe Wire - Hot At All Times To Radio Orange With Black Stripe Wire - From Light Switch To Radio (Light) (Parking) Orange With Red Stripe Wire - Right Rear Speaker Red Wire - To Ground With Black Wire Yellow With Black Stripe Wire - Hot In Accessory Or Run To Radio
Nov 30, 2007 | Clarion DRX5575
Car Audio & Video Logo
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
