Question about Dryers
No heat there is no heat in my whirpool tumble dryer, it still goes round, i cant remember the model, its about 5/6 yrs old and has a solid white front door, its either 6 or 7 kg load, is it anything major? and is it worth getting it repaired, or is there anything i can try?
  • 5,911 Answers
The following link will explain the most common causes of a dryer "no heat" problem:
http://www.fixya.com/support/r630242-dryer_runs_but_not_heat
To answer your question, "yes", this is a problem that is worth your effort repairing. This should not be a difficult repair and can be accomplished by the average do-it-yourselfer with just a little guidance. Read through the link I provided you, thoroughly. Pay particular attention to the paragraph that discusses proper ventilation as most dryer heat related problems are attributed to poor (or clogged) ventilation. In general, most commonly, if the heating circuits fail, its for a reason. This is usually caused by overheating due to poor air flow. If you cannot remember the last time your dryer heat ducting was inspected or cleaned, it may be a good time to do so now. If you do not ensure the dryer has proper air flow, replacing parts could become futile as these same components will more than likely fail again. If you have questions, or require addtional assistance please let me know. I hope this helps you.
PS Check your thermal cut-out (TCO) first. This component acts as a fuse and is usually the first to go bad when a dryer fails. If the TCO fails, it is strongly recommended that you replace the hi-limit thermostat at the same time. These components are commonly sold as a set. Failure to do so may result in premature failure of any replaced parts. NOTE: Do all components checks with the dryer UNPLUGGED. Dangerous voltages are still present even with the dryer turned off.
Posted on Jan 13, 2009
I HAVE A AEG LAVATHERM 500 R TUMBLE DRYER 25 YRS OLD IT START RUNS ITS CYCLE BUT NO HEAT
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check out this electric no heat tip...
heatman101
Sep 19, 2010 | AEG Dryers
Yesterday the trip switch for the downstairs mains sockets tripped. When i reset it and plugged switched on my White Knight 44AW drier it span as usual but now there is no heat.
How to Replace A White Knight Tumble Dryer Heating Element Heater and Thermostat
For a full list of appliance Video Repair help see our video section
White knight tumble dryer not heating this video show you how to change and fit a new heating element and thermostats can be used on Ariston, Electrolux, Ignis, Neutral, Tricity Bendix, Whirlpool,
Here is the element in this video
For all you tumble dryer spare parts click here
The easiest way to find you part is put your model number into our search bar at http://www.apart4u.co.uk/ TEL 08455218000
http://www.apart4u.co.uk/news/category/questions-and-answers/diagrams/
Jan 19, 2010 | Abbaka White Knight 44AW Electric Dryer
No heat from dryer
Common faults -
1 The heating elements can fail (meaning open circuit)
2 There are cut-outs (T.O.C's) that might need resetting
3 The thermostats (stats) can trip out or burn out (meaning opencircuit)
4 Moderntumble dryers also have sensors and pcb's (Printed circuitboards) thesehave programs that can fail and circuitry although most should produce an errorcode showing you were the fault is.
5 Faultyconnections and burned wires may also be the fault.
Free tumble dryer repair videos
We have a Free full video library on appliance repair video’s
Nov 03, 2009 | Amana ALE331RAW Gas Dryer
GE Adora Dryer spins but no heat
Aug 05, 2009 | GE WSXH208A Front Load Washer
Zanussi tumble dryer spinning but not heating up
I have same problem and been tol its either the heater or the thermostat inside the front of the drum open circuit hope that helps
Apr 13, 2009 | Asko T701 Electric Dryer
Tumble dryer drum only starts when i start it first by hand
starter capacitor went bad on motor... replace
Mar 12, 2009 | Dryers
ELECTRIC DRYER WON'T TUMBLE
Possibly the belt assembly. if you open the door and try to turn the drum does it turn with a little resistance, noises? this model has rollers, pulley, and a four groove belt 92 1/4" , sometimes the pulley sticks after yrs of use, belts wear, drum misaligns. the humming should be the motor trying to work.
Feb 03, 2009 | Whirlpool LER7646E Dryer
MAYTAG GAS DRYER TUMBLES BUT NO HEAT (FRONT LOADER 6 YRS. OLD)
Hello maryfitgera,
It certainly sounds like you are not getting a flame established in your dryer. That can be one of several components such as a non-resettable thermal fuse, gas valve assembly or control relay to that gas valve assembly. Unless you are well versed on how to work on these kinds of components, I suggest you just call in an appliance tech or.. let me know if you want to attempt diagnosing and repairing it yourself. Be advised that there are elements of danger in so doing. Let me know how you want to procede on this and I'd be happy to walk you thru it..
Regards,
Rick
Nov 23, 2008 | Maytag MDG7600AW Gas Dryer
Frigidaire Dryer WOn't Heat
I have a frigidaire frontal dyer that is 3 yrs old. The dryer works properly, it tumbles, but it is only cold air ???? What's the problem ?
Mar 15, 2008 | Frigidaire GLER642A Electric Dryer
Dryers Logo
61 people viewed this question
Top Dryers Experts
