I returned two Lionel Thomas Remote O gauge train sets because they did not respond to commands. I am keeping the third replacement because it at least goes forward and reverse. The chuff off switch does not work. I also found the worm gear had no grease. The grease was on the chassis. They aimed the grease squirt wrong. I suggest you only buy from a dealer that tests it in front of you before you take it out of the store.
SOURCE: lionel train won't reverse
there should be a switch under or in the cab section that turns off/on the reverse function.
SOURCE: Have lost instruction manual for THOMAS ULTIMATE TRAIN SET byTOMY
http://www.tomy.co.uk/webcare/product-instructions/track-master-tmrr-instructions/
SOURCE: The train is not responding to the remote.
I had a similar problem with my 11000 Holiday Tradition Express. I cleaned the track with an eraser (pencil-type) and then used a soft cloth to clean any possible residue. After doing this twice, my train is now running.
SOURCE: WE are trying to get our lionel holiday train
There is no on/off switch. Remote will give no indication of working. Try putting engine and coal car only and try. I have had this train set for two years and the remote tends to work whenever it wants.
SOURCE: remote control train won't work
The wires will have pulled off the circuit board inside.
Remove screws (force a hex driver in there) and solder wire back on.
Train surgey (geddit) is very fiddly. Have a drink first! ;-)
